SDL2+GLES20 issues...
Posted: Tue Sep 13, 2016 10:19 pm
by marksibly
Just got a new raspberry pi3 and loving it so far!
However, I am trying to get an SDL2/GLES20 based project going and am having some problems.
For starters, it wont run at all. SDL_CreateWindow always fails with 'Could not get EGL display'.
Could this be because I'm running the app from the 'desktop' and I should be running it gui-less?
If so, does this mean we only get accelerated GLES20 in 'fullscreen' mode, not in a desktop window?
I did have some luck with a plain OpenGL build, but of course it's software emulated and VERY slow. Tried the experimental HW driver for GL too, and it worked (once) but was a bit glitchy. Besides, the GLES20 HW driver should be the cleanest/fastest, right?
Any clues greatly appreciated!
Bye,
Mark
Re: SDL2+GLES20 issues...
Posted: Thu Sep 15, 2016 12:02 am
by marksibly
Well, gave up on accelerated GLES20 on the desktop and managed to get 'fullscreen' working.
However, there's another problem here - once I've gone into fullscreen, I can't go into fullscreen again.
For example the 'parent' app goes into fullscreen, then attempts to launch a 'child' app (process) which also tries to go fullscreen but failing to do so.
Is this something to do with the dispmanx 'layer'? SDL2 uses a constant '10000' for this so I was thinking maybe you can only have one thing per layer? I did try to set the child layer to '10002' but that didn't help.
Is this even possible?
Posted: Sun Sep 18, 2016 9:48 pm
by raysan5
Hello marksibly,
Maybe you can try using raylib (www.raylib.com). It doesn't work on desktop, only fullscreen, and does not depend on X-Windows.
More info here: https://github.com/raysan5/raylib/wiki/ ... spberry-Pi
