JGPIO
RPi3 macros
Thu Aug 25, 2016 10:54 am
I've just received an RPi3 and I'm a little surprised that __ARM_ARCH_6__ is defined rather than __ARM_ARCH_7__
Have I misunderstood something or is this wrong?
Many thanks.
jahboater
Re: RPi3 macros
Thu Aug 25, 2016 11:08 am
It should actually be __ARM_ARCH_8A__ for the cortex-a53.
But remember the Rasbian distribution is backwards compatible all the way to the PiZero which is V6.
You can build your own compiler of course (gcc 6.2 is the latest).
JGPIO
Re: RPi3 macros
Thu Aug 25, 2016 11:10 am
Well yes, I was actually expecting __ARM_ARCH_8__ to be defined.
jahboater
Re: RPi3 macros
Thu Aug 25, 2016 11:56 am
If you give the correct options for the Pi3 CPU (which are: -mcpu=cortex-a53 -mfpu=neon-fp-armv8 ) you will have __ARM_ARCH_8A__ defined, even with the old compiler.
JGPIO
Re: RPi3 macros
Thu Aug 25, 2016 12:33 pm
jahboater wrote:If you give the correct options for the Pi3 CPU (which are: -mcpu=cortex-a53 -mfpu=neon-fp-armv8 ) you will have __ARM_ARCH_8A__ defined, even with the old compiler.
Nice! I just tried it. Thank you very much for that.
Re: RPi3 macros
Thu Aug 25, 2016 1:37 pm
JGPIO wrote:Well yes, I was actually expecting __ARM_ARCH_8__ to be defined.
Compiler defaults to lowest common denominator - the Pi1/0. You need to manually set it higher if targeting specifically the Pi3. As mentioned above.
JGPIO
Re: RPi3 macros
Thu Aug 25, 2016 2:50 pm
Thank you all for your help.
I haven't used gcc since my SCO Unix days in the second half of the 1990's.
Much re-learning to do!
Return to “C/C++”
