davenull
new Geany version 1.27
Fri May 13, 2016 12:02 pm
hello,
as I am not experienced with update procedures:
I currently have Geany 1.24
for upgrade to 1.27:
can I just use
sudo apt-get install geany
for a new complete installation,
or do I have to uninstall before,
or did I miss a simple update command?
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
ShiftPlusOne
Re: new Geany version 1.27
Fri May 13, 2016 12:06 pm
davenull wrote:hello,
can I just use
Jessie only has 1.24.
davenull
Fri May 13, 2016 12:08 pm
sorry, but the new Raspbian info also pointed out to 1.27:
https://www.raspberrypi.org/blog/anothe ... -raspbian/
Geany
One of the tools which is really useful for professional programmers is a good text editor – the simple editor provided with LXDE is fine for small tasks, but not really suitable for serious work.
geany
The image now includes the Geany editor, which is much better suited to big projects – it offers features like syntax highlighting, automatic indentation and management of multiple files. There’s good online help built into the program itself, or have a look at the Geany website.
Do I miss something?
B.Goode
Fri May 13, 2016 12:13 pm
davenull wrote:sorry, but the new Raspbian info also pointed out to 1.27:
Where, exactly? The screenshot clearly shows an instance of v1.24
davenull
Fri May 13, 2016 12:18 pm
oh, that was too tiny at the bottom bar
What I read was: "have a look at the Geany website http://www.geany.org/"
and there is written:
latest version is: 1.27
stephj
Sat May 14, 2016 4:45 pm
If you really must have the latest version, then your only option is to drag down the source code from the official Geany site and compile it on your Pi. Possible, but not for the faint hearted. For reasons of stability some of the packages in Raspbian are a version or two behind the curve. It makes sense to include stable, tried and tested versions in the repository, rather than the latest, whizzo, must have version, with its possible extra "features" that still need ironing out.
It's your Pi, if you want to build 1.27 on it, then go for it. Good luck!
davenull
Sat May 14, 2016 4:51 pm
no, I misunderstood the announcement.
I faultily assumed that the new Geany features are provided by the newest version as it was published in the Raspian 2016-04-10 blog.
And then it was linked to the Geany website, where they talk about the 1.27.
So I concluded that the 1.27 would be needed then, not knowing that the Raspian version with the "new features" actually is using an already outdated 1.24 version, but nevertheless providing those "new features".
Return to “C/C++”
