davenull
any advantage for compiling by -std=c++11 ?
Mon Apr 25, 2016 10:06 am
hello,
is there any advantage for compiling by -std=c++11 currently ?
(which is the current gcc/g++ version provided by Jessie?)
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
AndyD
Re: any advantage for compiling by -std=c++11 ?
Mon Apr 25, 2016 11:49 am
davenull wrote:Which is the current gcc/g++ version provided by jessie?
4.9.2
davenull wrote:Is there any advantage for compiling by -std=c++11 currently ?
I am assuming that your question is, "Given a valid C++03 program is there any advantage to compile using the g++ -std=c++11 flag?"
The program may gain some improved performance from the C++11. For a detailed discussion see Can modern C++ get you performance for free? on stackoverflow.
davenull
Mon Apr 25, 2016 4:42 pm
thanks for your reply!
Actually it was not just about speed but also about different features or advantages when using c11 instead of c2003, e.g. useful new functions or functionalities, important bug fixes, and so on.
E.g., eventually I have a program code which was recommended to be compiled by -std=c++11 although compilation also worked without it (no idea what makes a difference though, as both executables failed to run then accordingly).
Just computational speed is not so extremely important to me.
Paeryn
Mon Apr 25, 2016 6:03 pm
davenull wrote:Actually it was not just about speed but also about different features or advantages when using c11 instead of c2003, e.g. useful new functions or functionalities, important bug fixes, and so on.
There are a fair few changes brought in C++11, https://en.wikipedia.org/wiki/C%2B%2B11 gives a decent breakdown of what the changes are.
And you shouldn't refer to C++11 as C11, they are different standards for different languages. Nor should you use C2003 when you mean C++03, though since C never had C03 (the previous was C99) it's less ambiguous.
She who travels light — forgot something.
Please note that my name doesn't start with the @ character so can people please stop writing it as if it does!
davenull
Mon Apr 25, 2016 6:19 pm
ok, thank you, I didn't know that, I always assumed C was just a subset of C++.
Paeryn
Mon Apr 25, 2016 7:46 pm
davenull wrote:ok, thank you, I didn't know that, I always assumed C was just a subset of C++.
No, C++ is based on C (C++ was originally called "C with Classes"). C isn't a subset of C++ as you can write perfectly valid C code that will not compile under C++.
davenull
Mon Apr 25, 2016 8:19 pm
...perfectly valid C code that will not compile under C++.
do you have a source code example? 8-)
jahboater
Mon Apr 25, 2016 9:54 pm
The "restrict" keyword in C is not understood by C++.
Obviously C++ keywords should be avoided.
Not sure what else there is?
Pi4 8GB running PIOS64 Lite
Paeryn
Tue Apr 26, 2016 12:20 am
void *func()
  return 0;
struct foo {
  int a;
typedef long foo;
int main()
  int old = 0;
  int new = 1;
  int *err = func();
  struct foo bar;
  foo humbug;
  bar.a = 4;
  foo = 5;
  printf("Hello\n");
  return 0;
That has four different errors that C++ will fail on.
1) new is a keyword in C++ so can't be used as a variable name.
2) C++ doesn't allow automatic pointer conversion.
3) C++ doesn't allow you to call undeclared functions.
4) in C++ struct and typedef have the same scope so the same identifier can't be used for each, in C they are separate.
yodermk
Tue Apr 26, 2016 1:14 am
If you're compiling existing code, find out from the author which --std it requires, or try it with various options and see what works.
If you're writing new code, you absolutely should be using --std=c++11 or better yet --std=c++14 when it's available on the Pi. It's a night & day better language. *Please* don't write new C++ code with the pre-11 way of doing things (like manual pointers & such).
ejolson
Tue Apr 26, 2016 2:44 am
jahboater wrote:The "restrict" keyword in C is not understood by C++.
Almost all extensions to ANSI-C starting with C99 and then C11 are incompatible with C++. In addition to the already mentioned semantics involving pointer aliasing, the implementation of stack-allocated variable length arrays, complex numbers and declarations of counter variables in for loops are all done differently.
jahboater
Tue Apr 26, 2016 7:48 am
ejolson wrote:Almost all extensions to ANSI-C starting with C99 and then C11 are incompatible with C++. In addition to the already mentioned semantics involving pointer aliasing, the implementation of stack-allocated variable length arrays, complex numbers and declarations of counter variables in for loops are all done differently.
"for( int i = 0; i < 50; ++i )" is the same - how is it different in C++?
I assume you mean:
"char * ptr = (char*)malloc()" - you don't need the cast in C but its perfectly valid.
???? for example? in fact some of them are obviously intended to make the languages compatible.
How do stack allocated variable length arrays differ? They compile cleanly in both languages.
I admit I don't know about complex numbers in this respect.
jahboater
Tue Apr 26, 2016 8:02 am
Paeryn wrote:
void *func()
  return 0;
struct foo {
  int a;
typedef long foo;
int main()
  int old = 0;
  int new = 1;
  int *err = func();
  struct foo bar;
  foo humbug;
  bar.a = 4;
  foo = 5;
  printf("Hello\n");
  return 0;
Obviously - as mentioned.
It does allow "int *err = (int*)func();" which is perfectly valid in both languages.
You wont get very far in C nowadays doing that. You get all sorts of warning messages that are hard or impossible to turn off. A well written C program has no problems.
4) in C++ struct and typedef have the same scope so the same identifier can't be used for each, in C they are separate.[/quote]That's a good point. Though easily avoided.
davenull
Tue Apr 26, 2016 8:05 am
ok, thanks to all, it's already quite a bunch of details which had to be considered, but some or even most of them are at a really sophisticated level which admittedly exceed my programming skills (currently).
Return to “C/C++”
