davenull
a few hints needed: reading input string, parse to ints
Fri Apr 22, 2016 7:00 pm
hi,
I would need a few hints about how to read an input string, parse several substr data to ints, then pass them to a function.
I have a RTC and I want to read a new time+date string, parse the time data to ints, and pass them to a set_time function
edit,
I now made it this way, it works not perfect but reasonable:
 * RTC DS3231
 * test demo
 * ver 0001
#include <string.h>
#include <unistd.h>
#include <errno.h>
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <linux/i2c-dev.h>
#include <sys/ioctl.h>
#include <fcntl.h>
#include <unistd.h>
#include <wiringPi.h>
#include <wiringPiI2C.h>
#define  byte  uint8_t
// RTC DS3231
#define ADDR_RTCDS3231 0x68
int     frtcds3231;
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val) {  return( (val/10*16) + (val%10) );  }
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)  {  return( (val/16*10) + (val%16) ); }
void setDS3231time( byte year, byte month, byte dayOfMonth, byte hour, byte
minute, byte second, byte dayOfWeek)
  // sets time and date data to DS3231
  wiringPiI2CWriteReg8(frtcds3231, 0, decToBcd(second));      // set seconds
  wiringPiI2CWriteReg8(frtcds3231, 1, decToBcd(minute));      // set minutes
  wiringPiI2CWriteReg8(frtcds3231, 2, decToBcd(hour));        // set hours
  wiringPiI2CWriteReg8(frtcds3231, 3, decToBcd(dayOfWeek));   // ( 1=Sunday, 7=Saturday)
  wiringPiI2CWriteReg8(frtcds3231, 4, decToBcd(dayOfMonth));  // set dayOfMonth (1 to 31)
  wiringPiI2CWriteReg8(frtcds3231, 5, decToBcd(month));       // set month
  wiringPiI2CWriteReg8(frtcds3231, 6, decToBcd(year));        // set year (0 to 99)
int main() {
   int  year, month, dayOfMonth, hour, minute, second, dayOfWeek;
   int i=0, check;
   char sbuf[100];
   frtcds3231 = wiringPiI2CSetupInterface( "/dev/i2c-0",  ADDR_RTCDS3231 );
   printf(" RTC DS3231 \n");
   printf("Set new Date/Time:   enter 1\n");
   printf("else:   display time\n\n");
   i = getchar();
   //debug
   //printf("%d \n", i);
   while (i=='1') {
      // get string yy mm dd hh mm ss dw : gets() ?
      printf("yy mm dd hh mm ss dw (DayOfWeek) \n");
      check=scanf("%d %d %d %d %d %d %d", &year, &month, &dayOfMonth,  &hour, &minute, &second, &dayOfWeek);
      getchar();
      printf("check=%d\n", check);
      if(check==7) {
		 printf("%d \n", year);
		 printf("%d \n", month);
		 printf("%d \n", dayOfMonth);
		 printf("%d \n", hour);
		 printf("%d \n", minute);
		 printf("%d \n", second);
		 printf("%d \n", dayOfWeek);
         setDS3231time( year, month, dayOfMonth, hour, minute, second, dayOfWeek );
      }      // parse string to decimal values: scanf() ?
      // pass values to setDS3231time()
      i=0;
      i = getchar();
   while(1) {
     second =     bcdToDec(wiringPiI2CReadReg8 (frtcds3231, 0) & 0x7f );
     minute =     bcdToDec(wiringPiI2CReadReg8 (frtcds3231, 1) );
     hour =       bcdToDec(wiringPiI2CReadReg8 (frtcds3231, 2) & 0x3f );
     dayOfWeek =  bcdToDec(wiringPiI2CReadReg8 (frtcds3231, 3) );
     dayOfMonth = bcdToDec(wiringPiI2CReadReg8 (frtcds3231, 4) );
     month =      bcdToDec(wiringPiI2CReadReg8 (frtcds3231, 5) );
     year =       bcdToDec(wiringPiI2CReadReg8 (frtcds3231, 6) );
     sprintf(sbuf, "20%02d/%02d/%02d  %02d:%02d:%02d", year, month, dayOfMonth, hour, minute, second);
     printf(sbuf);
     printf(" Day of week %1d: ", dayOfWeek);
     switch(dayOfWeek){
     case 1:
       printf("Sunday");
       break;
     case 2:
       printf("Monday");
       break;
     case 3:
       printf("Tuesday");
       break;
     case 4:
       printf("Wednesday");
       break;
     case 5:
       printf("Thursday");
       break;
     case 6:
       printf("Friday");
       break;
     case 7:
       printf("Saturday");
       break;
     printf("\n");
     delay (1000);
  return (0);
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
davenull
Re: a few hints needed: reading input string, parse to ints
Fri Apr 22, 2016 8:14 pm
- resolved, more or less -
swampdog
Sat Apr 23, 2016 11:03 am
This is how to load a file into memory, with & without exceptions...
bool FC
sdFileLoad(
sdConStr * cs,
const sdStr & fname,
bool append,
BARF barf
) SD_THROW ((sde_Null,sde_File))
SDE_NULL(cs);
sdBifs ifs (fname.c_str());
sdStr s;
if (!ifs) {
if (barf)
throw sde_File(SD_SFL(sdFileLoad),fname)
return false;
if (!append)
cs->clear()
while (std::getline(ifs,s))
cs->push_back(s)
if (ifs.bad()) {
if (barf)
return false;
return true;
..it shows all the tests. Fwiw "sdConStr" is an array of deque strings (actually a template)
Return to “C/C++”
