dimckissickjr
Using namespace c++
Sat Mar 05, 2016 10:59 pm
Hello I'm trying to wrap my head around how namespace works. After reading about it I build a super simple program to test my understanding. Unfortunately I'm getting a multiple definition error and not sure why. Here is my program.
include <iostream>
include "file_one.cpp"
using namespace std;
int main()
    int x = 2;
    int y = 1;
    cout << file_one::addNum(x,y);
* file_one.cpp
namespace file_one{
    int addNum(int num1, int num2){           <<<** getting the error here**
        int total;
        total =  num1 + num2;
        return total;
AndyD
Re: Using namespace c++
Sat Mar 05, 2016 11:23 pm
Why are you trying to insert one C++ source file into another using #include? This is not the usual practice. Normally, you #incldue a header file with class and function declarations and template definitions.
However, It works for me.
How are you compiling? If the file with main in it is called main.cpp. If you compile
g++ -Wall main.cpp -o main
It works
If you are trying to compile with
g++ -Wall main.cpp file_one.cpp -o main
You get link errors because addNum is compiled in main.cpp and file_one.cpp
/tmp/ccoMoDHV.o: In function `file_one::addNum(int, int)':
file_one.cpp:(.text+0x0): multiple definition of `file_one::addNum(int, int)'
/tmp/ccXTf1Se.o:main.cpp:(.text+0x0): first defined here
collect2: error: ld returned 1 exit status
dimckissickjr
Sun Mar 06, 2016 6:15 pm
Oh crap your right it does work. I wasn't using a terminal to compile the code, I was using CodeBlocks IDE on my windows machine.
I had a feeling that was kind of weird. I did a YouTube search trying to get more information on what a namespace was and that was how the video demonstrated it.
Thanks for your replay :P
swampdog
Fri Mar 11, 2016 1:01 am
The namespace exists to stop things getting polluted. If I wrote a function called foo() and someone else writes another function called foo() they'd collide in what (iirc) is called the global namespace.
#include <iostream>
namespace a {
void foo(){std::cout<<"a::foo\n";}
}//namespace a
namespace b {
void foo(){std::cout<<"b::foo\n";}
}//namespace b
void foo(){std::cout<<"::foo\n";}
int
main(void)
 #if defined(OK)
 a::foo();
 b::foo();
 foo();
 #endif
 #if defined(ERR)
 using namespace a;
 using namespace b;
 foo();
 #endif
 #if defined(FIX)
 using namespace a;
 using namespace b;
 a::foo();
 b::foo();
 ::foo();
 #endif
 return 0;
Tip: Always write the closing brace and put a comment on it like I have above immediately you write the initial "namespace blah {" otherwise you'll lose it(*).
$ g++ -o a -DOK a.cc && ./a
$ g++ -o a -DERR a.cc && ./a
$ g++ -o a -DFIX a.cc && ./a
1st and 3rd compile. 2nd one won't. It's okay to have "using namespace blah" inside a source file but never put one into a header file (because it will affect everything that #include's it).
(*) Look what happens when I delete the closing brace for "namespace b"..
a.cc: In function ‘void b::foo()’:
a.cc:11: error: redefinition of ‘void b::foo()’
a.cc:8: error: ‘void b::foo()’ previously defined here
a.cc: At global scope:
a.cc:37: error: expected ‘}’ at end of input
..you'll never find that in a large compilation unit. It could be a missing closing brace for anything where you can use "{" ;-)
Return to “C/C++”
