davenull
can't find i2c-0 GPIO pins any more
Sat Feb 20, 2016 11:11 am
hey,
I can't find i2c-0 (SDA-0 + SCL-0) GPIO pins on B+ or 2B header any more - all the numberings and pin-out diagrams are unbearably messed up and incomplete.
Can someone help me please?
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
PeterO
Re: can't find i2c-0 GPIO pins any more
Sat Feb 20, 2016 11:18 am
The I2C pins have not moved :roll: What does that tell you ?
(Out of date link removed)
PeterO
davenull
Sat Feb 20, 2016 11:19 am
no, but I can't find the numbering.
GPIO 28 ?
GPIO 29 ?
or different ones?
which is SDA-0 ?
which is SCL-0 ?
the search function does not help at all!
No posts were found because the word sda-0 is not contained in any post.
No posts were found because the word i2c-0 is not contained in any post.
No posts were found because the word scl-0 is not contained in any post.
WTF! :evil:
davenull
Sat Feb 20, 2016 11:25 am
hmm... think I found something
GPIO 28: level=1 fsel=4 alt=0 func=SDA0
GPIO 29: level=1 fsel=4 alt=0 func=SCL0
PeterO
Sat Feb 20, 2016 11:26 am
I2C-0 Is not available for users, it is dedicated to the HAT interface. The I2C pins are still 3 and 5 but are now connected to I2C-1
PeterO
davenull
Sat Feb 20, 2016 11:29 am
CMIIW, but I think that is not correct:
enabling is possible by
sudo nano /boot/config.txt
# add at the end:
dtparam=i2c_vc=on
davenull
Sat Feb 20, 2016 11:30 am
GPIO pinout:
(deleted, messed up pin numbering scheme.)
davenull
Sat Feb 20, 2016 11:32 am
correct ?
PeterO
Sat Feb 20, 2016 11:36 am
davenull wrote:CMIIW, but I think that is not correct:
# add at the end:
dtparam=i2c_vc=on
And what advice was given about using that configuration ?
PeterO
davenull
Sat Feb 20, 2016 11:43 am
you'll surely tell me immediately .... :shock:
davenull
Sat Feb 20, 2016 11:47 am
so what may go wrong?
I won't ever use HATs for example...
but I'll need 2 i2c ports !
Goraxium
Mon Feb 22, 2016 7:47 am
davenull wrote:but I'll need 2 i2c ports !
Unless you've got devices using the same address on the same I2C channel, you won't need to use I2C0. For that, I give you two questions:
Do you know what addresses your devices use?
Can you change the addresses by grounding pins?
davenull
Mon Feb 22, 2016 8:32 am
it's most of all a matter of communication speed and perhaps clock-stretching issues. Some devices need very quick response (1-2 hooked-up Arduino DUEs used as customized multiplexer boards) and other devices are polled not so frequently (IMU sensor, GPS, RTC to synchronize, perhaps a LIDAR, and more). But the more devices are hooked up simultaneously, the slower will be the bus for the fast Arduino communications.
That's why 2 independent i2c ports would be needed.
Anyway, my question is not about my current device setup but it's just about additional i2c-0 use in principle:
myoung008
Fri Feb 26, 2016 1:49 am
I use i2c-0 for non-HAT purposes. In config.txt:
dtparam=i2c0=on
dtparam=i2c1=on
force_eeprom_read=0
bcm_2708.vc_i2c_override=1
This is for a bcm2708/devicetree kernel, not the newer bcm2835. I don't know if it would make a difference. Anyway, both buses show up and work fine. I'm using a Pi 2B, but it should work on A+/B+/zero as well.
The last two lines disable the vc eeprom scan (for HATs) at boot time. I've not had any problems with the scan but boot time was a major factor in my application and it seemed prudent.
Pin 27 = GPIO0 = SDA0
Pin 28 = GPIO1 = SCL0
There are no pull-ups on those pins so you will need external resistors to pull to 3v3. I use 2.2K.
Hope this helps.
davenull
Fri Feb 26, 2016 7:52 am
thank you, but I know that already meanwhile, please read through the complete topic!
As I have statet already quite at the top:
davenull wrote:enabling is possible by
    # add at the end:
    dtparam=i2c_vc=on
My last question was just about PeterO's statements (after enabling i2c-0):
PeterO wrote:I2C-0 Is not available for users, it is dedicated to the HAT interface. The I2C pins are still 3 and 5 but are now connected to I2C-1
But I actually have no idea what may go wrong as I never will use HATs, and honestly:
what is so special on my Pi that it just would work with HATs on i2c-0?
Finally i2c is a free bus system by international standards!
So what may go wrong using it eventually?
FTrevorGowen
Fri Feb 26, 2016 10:14 am
davenull wrote: My last question was just about PeterO's statements (after enabling i2c-0):
You're missing the point (which has nothing to do with "international standards"). Like the GPIO's used for the display and camera ports, I2C-0 is (now) reserved for hat use (and thus for those folks designing hats). Whilst it is possible for you to use it for your own (non-hat) purposes this would be considered "poor practice" and potentially prevents any of your code/hardware ideas being (reliably) usable by others (who, unlike you, may want to use a hat). In other words "go with the flow" not "against it" (and I'm sure there are other solutions to your "needs" expressed in other posts).
Trev.
davenull
Fri Feb 26, 2016 10:26 am
what do you mean by "reserved" ?
it's my Raspi, why can't I use my i2c ports on it for my purposes by standard libs?
who has the right to "reserve" my GPIO ports for 3rd party accessories?
I bought the Pi 2B because it has 40 pins providing 2 i2c ports, and in no desription was written "just 1 i2c available" !
I also would never connect additional displays, as I am using just 1 HDMI full HD display!
So I demand to be able to use all GPIOs freely, without any restrictions!
If I wanted to enable HATs to use my Raspi, it's my personal decision - to do it or not - but not of the HAT company or Raspi org!
FTrevorGowen
Fri Feb 26, 2016 10:38 am
davenull wrote:what do you mean by "reserved" ?
Quite simply it's "reserved" via the firmware provided by the designers of the Pi.
Trev.
davenull
Fri Feb 26, 2016 10:39 am
Objection!
that is an undue restriction of my usage rights!
And to top it all, not even C / C ++ libs are available for HATs! What a nonsense!
Massi
Fri Feb 26, 2016 11:29 am
davenull wrote:that is an undue restriction of my usage rights!
:lol:
btw, i think your pinout schema is deadly wrong (those are not the i2c-0 gpios)
davenull
Fri Feb 26, 2016 11:36 am
edit:
you're right!
it's been messed up pin numbering schemes!
(this is an intolerable Suck with these pin-numberings!)
Fri Feb 26, 2016 11:44 am
davenull wrote:Objection!
The pins are reserved for use by HATs, but that doesn't mean you cannot use them, providing you have no expectation of them then working when a HAT is used, simply because the HAT wants to use those pins as well.
The term 'reserved' is very common in computing to indicate that there is a 'standard' way of using something, that you may use if you wish, but it will be then become non-standard.
Nothing to get all het up about.
davenull
Fri Feb 26, 2016 11:48 am
ok, I'm not interested in "reserved" when it's actually "not reserved" after all.
So it doesn't interest me if anyone has "reserved" it for HATs, as I don't use them at all (and even can't at all, even if I wished to, because there are no C/C++ libs at all for HATs).
I just want to use i2c-0 just exactly like i2c-1, and eventually by wiringPi API functions.
Fri Feb 26, 2016 11:56 am
davenull wrote:ok, I'm not interested in "reserved" when it's actually "not reserved" after all.
Fill yer boots.
As for C/C++ libs for HAT's, sounds like a gap in the market. Although since all HAT's are different, it might not actually be possible to write a generic library anyway. The only thing generic about them is the identification eprom, a library to recover that information would not be difficult I suppose. You'd still need to write your own code to drive the particular HAT HW.
Massi
Fri Feb 26, 2016 12:00 pm
davenull wrote:I just want to use i2c-0 just exactly like i2c-1, and eventually by wiringPi API functions.
even if i do not agree with your methods, this is after all a good and interesting way of using the pi and of learning something
let us know if you can get it to work :)
remember the external pullup (somewhere around 2k, the internal pullups are too weak)
Return to “C/C++”
