jj2127
IDE for C
Thu Aug 02, 2012 9:09 pm
Is there a built in IDE for C in debian squezze or do I have to install one?
jdbennet
Re: IDE for C
Thu Aug 02, 2012 9:34 pm
Just use any text editor??
Geany etc....
jj2127
Re: IDE for C
Thu Aug 02, 2012 9:35 pm
jdbennet
Re: IDE for C
Thu Aug 02, 2012 9:40 pm
Geany has syntax highlighting, terminal, todo list, function/class browser, etc... basically a more powerful gedit.
If you want a real *IDE* try Code::Blocks or QTCreator etc... but I dont know if they will run fast enough...
jj2127
Re: IDE for C
Thu Aug 02, 2012 9:44 pm
I go with geany i think
scottscreations
Re: IDE for C
Fri Aug 03, 2012 2:36 pm
if you like kde apps (Qt based), kwrite or kate is good. For gnome (Gtk+ flavor) try gedit. Those are light weight.
glframebuffer
Re: IDE for C
Mon Aug 13, 2012 2:20 pm
There are two different possible scenario here ; let em know if it is helpful for you
1) IDE for Raspberry Pi development on device itself
I have tried many IDEs on device but i found http://www.geany.org is lite-weight and fast.
other IDE s tried Eclipse, code block etc ,
2) IDE for raspberry Pi development on PC
you can use your fav. one mine is Eclipse :)
Return to “C/C++”
