Tx_master008: libshapes.c:571: End: Assertion `vgGetError() == VG_NO_ERROR' failed.
as long the function runs in main in an endless loop it works though -
what do I have to do?
I need the graphic window functionality also in pthread tasks...
/* Tx master
* Raspberry Pi
* ver 0008
* Rasbian 8.0
// (C) Helmut Wunder (HaWe) 2015
// freie Verwendung für private Zwecke
// für kommerzielle Zwecke nur nach Genehmigung durch den Autor.
// Programming language: gcc C/C++, Geany IDE
// protected under the friendly Creative Commons Attribution-NonCommercial-ShareAlike 3.0 Unported License
// http://creativecommons.org/licenses/by-nc-sa/3.0/
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <math.h>
#include <fcntl.h>
#include <string.h>
#include <sys/ioctl.h>
#include <stdint.h>
#include <errno.h>
#include <pthread.h>
#include <termios.h>
#include "VG/openvg.h"
#include "VG/vgu.h"
#include "fontinfo.h"
#include "shapes.h"
#include "shapes_plus.h"
#include <wiringPi.h>
#include <wiringSerial.h>
#define byte uint8_t
const uint32_t UARTclock=115200;
char * uart = "/dev/ttyAMA0";
int Serial1;
// C TOOLS
// timer
// millis()
// micros()
int kbhit(void)
struct termios oldt, newt;
int ch;
int oldf;
tcgetattr(STDIN_FILENO, &oldt);
newt = oldt;
newt.c_lflag &= ~(ICANON | ECHO);
tcsetattr(STDIN_FILENO, TCSANOW, &newt);
oldf = fcntl(STDIN_FILENO, F_GETFL, 0);
fcntl(STDIN_FILENO, F_SETFL, oldf | O_NONBLOCK);
ch = getchar();
tcsetattr(STDIN_FILENO, TCSANOW, &oldt);
fcntl(STDIN_FILENO, F_SETFL, oldf);
if(ch != EOF)
ungetc(ch, stdin);
return 1;
return 0;
// openvg + shapes_plus
int _scrwidth_, _scrheight_;
#define vgHidewindow HideWindow
#define vgShowwindow End
#define vgcls() ClearWindowRGB(_scrwidth_, _scrheight_, 0, 0, 0);
#define vgInit() init(&_scrwidth_, &_scrheight_)
#define vgStart() Start(_scrwidth_, _scrheight_)
#define vgCleanup finish
#define vgSetcolor Stroke
#define vgFill Fill
int _fontsize_ = 10;
Fontinfo _font_ = MonoTypeface;
inline void vgSetfontsize(int size) { _fontsize_ = size; }
inline void vgSetfonttype(Fontinfo myfont) { _font_ = myfont; }
inline void lcdprintxytop(float x, float y, char * buf) {
Text(x, _scrheight_-y, buf, _font_ , _fontsize_);
inline void lcdprintxy(float x, float y, char * buf) {
Text(x, y, buf, _font_ , _fontsize_);
void vgInitgraph() {
vgInit();
vgStart();
vgcls();
vgSetcolor(255, 255, 255, 1); // Set these at the start, no need to
vgFill(255,255,255, 1); // keep calling them if colour hasn't changed
vgSetfonttype(MonoTypeface);
vgSetfontsize(10);
// DATA PACKAGES
#define MAXMOTORS 6 // maximum number of encoder motors
#define MAXANALOG 12 // maximum number of analog sensors
#define MAXDIGPINS 16 // maximum number of digital pins
#define OUT_REGSTATE_NUL 0
#define OUT_REGSTATE_COAST 2
#define OUT_REGSTATE_BRAKE 3
#define OUT_REGSTATE_EMERG_STOP 5
#define OUT_REGSTATE_ON 8
#define OUT_REGSTATE_PIDIDLE 15
#define OUT_REGSTATE_PIDACTIVE 16
#define OUT_REGSTATE_PIDRELATIVE 17
#define OUT_REGSTATE_PIDABSOLUTE 18
#define OUT_REGSTATE_PIDHOLD 19
#define OUT_REGSTATE_PIDHOLDCLOSE 20
#define SYNCSLOT 0 // start of this Msg
#define CKSSLOT 1 // chksum this Msg
#define DIGSLOT 2 // 2,3: digital Data bitpattern
#define ENCSLOT0 4 // motor 0 -7: 4,8,12,14,16,18,20,22
#define ENCSLOT1 8 // motor 1
#define ENCSLOT2 12 // motor 2
#define ENCSLOT3 14 // motor 3
#define ENCSLOT4 16 // motor 4
#define ENCSLOT5 18 // motor 5
#define ENCSLOT6 20 // motor 6 / optional: float 0
#define FLOATSLOT3 20 // optional: float3
#define ANASLOT0 24 // 24,26,28,30,32,34,36,38,40,42,44,46
#define ANASLOT10 44 // analog 10+11 / optional: float 1
#define FLOATSLOT4 44 // optional: float4
#define PWMSLOT0 24 // 24-39, pwm Dpin: D0-D16
#define MCMDSLOT0 40 // 40-47, motor cmd bytes by master, pwm -100..0..+100,
// brake -128 emergStop -127
// PID rotate: abs./float 120 /stop 121 rel./float 122 /stop 123 /hold 124
#define MRUNSLOT0 48 // 48-55, motor runstate bytes returned to master
#define LAST8SLOT 55 // custom: float0 or int32
#define LAST4SLOT 59 // custom: float1 or int 32
volatile int8_t digval[MAXDIGPINS];
volatile int16_t anaval[MAXANALOG];
volatile int32_t motenc[MAXMOTORS];
// PARSER
// bit and byte and pin operations
// convert byte arrays to int
inline int16_t ByteArrayToInt16(uint8_t array[], uint8_t slot) {
return ((array[slot + 1] << 8) + (array[slot]));
inline long ByteArrayToInt32(uint8_t array[], uint8_t slot) {
return ( (array[slot+3]<<24) + (array[slot+2]<<16) + (array[slot+1]<<8) + array[slot] );
// convert int to byte arrays
inline void Int16ToByteArray(int16_t integer, uint8_t *array, uint8_t slot) {
array[slot] = (integer & 0xFF); // loByte
array[slot + 1] = (integer >> 8); // hiByte
inline void Int32ToByteArray(int32_t int32, uint8_t *array, uint8_t slot) {
array[slot] = (int32 & 0xFF); // loByte 8
array[slot + 1] = ((int32 >> 8) & 0xFF); // intByte 16
array[slot + 2] = ((int32 >> 16) & 0xFF); // longloByte 24
array[slot + 2] = ((int32 >> 24) & 0xFF); // hiByte 32
// read+write bits in numbers
#define bitRead(source, bit) ( ((source) >> (bit)) & 0x01 )
#define bitSet (source, bit) ( (source) |= (1UL << (bit)) )
#define bitClear(source, bit) ( (source) &= ~(1UL << (bit)) )
#define bitWrite(source, bit, bitvalue) ( bitvalue ? bitSet(source, bit) : bitClear(source, bit) )
void parsercvbuf(byte * arr) {
int i;
for( i=0; i<8; ++i) {
digval[i] = bitRead( arr[DIGSLOT], i);
digval[i+8] = bitRead( arr[DIGSLOT+1], i);
motenc[0] = ByteArrayToInt32(arr, ENCSLOT0);
motenc[1] = ByteArrayToInt32(arr, ENCSLOT1);
for( i=2; i<MAXMOTORS; ++i) {
motenc[i] = ByteArrayToInt16(arr, ENCSLOT3+i-2);
for( i=0; i<MAXANALOG; ++i) {
anaval[i] = ByteArrayToInt16(arr, ANASLOT0+i);
// DISPLAY
void displayvalues(int line, uint8_t array[]) {
int cnt;
char sbuf[128];
vgcls();
sprintf(sbuf, "Received:");
lcdprintxytop(60, line+20, sbuf);
//printf(sbuf); printf("\n");
for(cnt=0; cnt<16; ++cnt) {
sprintf(sbuf, "%3d ", cnt); // print cnt on TFT
lcdprintxytop( (cnt+1)*60, line+40, sbuf);
//printf(sbuf);
lcdprintxytop(60, line+80, "sync chksum TC bytes");
for(cnt=0; cnt<2; ++cnt) {
sprintf(sbuf, "%3d ", array[cnt]); // print dig bitbytes on TFT
lcdprintxytop( (cnt+1)*60, line+100, sbuf);
//printf(sbuf);
lcdprintxytop(60, line+140, "digital bits/bytes");
for(cnt=2; cnt<4; ++cnt) {
sprintf(sbuf, "%3d ", array[cnt]); // print dig 0-7 on TFT
lcdprintxytop( (cnt+1-2)*60, line+160, sbuf);
//printf(sbuf);
sprintf(sbuf, "%3d ", digval[cnt] ); // print dig 8-15 on TFT
lcdprintxytop( (cnt+1)*60, line+175, sbuf);
//printf(sbuf);
lcdprintxytop(60, line+200, "encoder bytes #0-2 2x long 1x short // #3-7 5x short");
for(cnt=4; cnt<14; ++cnt) {
sprintf(sbuf, "%3d ", array[cnt]); // print enc bytes
lcdprintxytop( (cnt+1-4)*60, line+220, sbuf);
//printf(sbuf);
for(cnt=14; cnt<24; ++cnt) {
lcdprintxytop( (cnt+1-14)*60, line+235, sbuf);
//printf(sbuf);
for(cnt=0; cnt<MAXMOTORS; ++cnt) {
sprintf(sbuf, "%+010ld ", (long)motenc[cnt]); // print enc
lcdprintxytop( 3+(cnt+1)*120, line+260, sbuf);
//printf(sbuf);
lcdprintxytop(60, line+280, "analog bytes #0-5x int // #6-11x int");
for(cnt=24; cnt<36; ++cnt) {
sprintf(sbuf, "%3d ", array[cnt]); // print analog bytes 0-5
lcdprintxytop( (cnt+1-24)*60, line+300, sbuf);
//printf(sbuf);
for(cnt=36; cnt<48; ++cnt) {
sprintf(sbuf, "%3d ", array[cnt]); // print analog bytes 6-11
lcdprintxytop( (cnt+1-36)*60, line+315, sbuf);
//printf(sbuf);
for(cnt=0; cnt<MAXANALOG; ++cnt) {
sprintf(sbuf, "%+06d ", anaval[cnt]); // print analog values 0-11
lcdprintxytop( (cnt+1)*60, line+340, sbuf);
vgShowwindow(); // Show the graphic screen
//printf("\n");
// SERIAL COMM
const uint8_t MSGSIZE = 64;
uint8_t bsync=255;
uint8_t sendbuf[MSGSIZE];
uint8_t recvbuf[MSGSIZE];
uint8_t calcchecksum(uint8_t array[]) {
int32_t sum=0;
for(int i=2; i<MSGSIZE; ++i) sum+=(array[i]);
return (sum & 0x00ff);
bool checksumOK(uint8_t array[]){
return (calcchecksum(array)==array[1]);
bool addToBuffer( uint8_t buf[], uint8_t *cnt, uint16_t timeout){
bool inSync = *cnt>0;
unsigned long start=millis();
while((*cnt<MSGSIZE)&&(millis()-start<timeout)){
if( serialDataAvail( Serial1 ) ) { // grab new char, test for sync char, if so start adding to buffer
buf[*cnt] = (uint8_t)serialGetchar( Serial1 );
if(inSync) *cnt += 1; // my origional *cnt++ was updating the pointer address, not
// the pointed to sendbuffer
else{
if(buf[*cnt]==0xFF){
inSync = true;
*cnt +=1;
return (*cnt==MSGSIZE);
bool receive(uint8_t * buf, uint16_t timeout, uint8_t *cnt){ // by passing cnt in and out,
// i can timeout and still save a partial buffer, so a resync costs less (less data lost)
bool inSync=false;
uint8_t * p; // pointer into buf for reSync operation
bool done=false;
do{
done = addToBuffer(buf,cnt,timeout); // if this return false, a timeout has occured, and the while will exit.
if(done){ // do checksumOK test of buffer;
done=checksumOK(buf);
if(!done){ // checksumOK failed, scan buffer for next sync char
p = (uint8_t*)memchr((buf+1),0xff,(MSGSIZE-1)); //forgot to skip the current sync at 0
if(p){ // found next sync char, shift buffer content, refill buffer
*cnt = MSGSIZE -(p-buf); // count of characters to salvage from this failure
memcpy(buf,p,*cnt); //cnt is now where the next character from Serial is stored!
else *cnt=0; // whole buffer is garbage
} while(!done&&(millis()-start<timeout));
return done; // if done then buf[] contains a sendbufid buffer, else a timeout occurred
// TASKS
void* thread1_UART(void *)
char sbuf[128], ch, resOK;
static uint8_t cnt=0;
uint8_t cbuf[MSGSIZE], chk;
while(1) {
// send to Rx slave Arduino
//Serial.println();
sendbuf[0]=bsync;
sendbuf[1]=calcchecksum(sendbuf);
write( Serial1, sendbuf, MSGSIZE ); // Send values to the Rx Arduino
//serialFlush( Serial1 ); // clear output buffer
//displayvalues(20, "Transmitted...: ", sendbuf);
//sprintf(sbuf, "%4d %4d", sendbuf[4], sendbuf[6]);
// Receive from Rx slave Arduino
memset(cbuf, 0, sizeof(cbuf));
resOK = receive ( cbuf, 10000, &cnt);
if( resOK ) { // byte 0 == syncbyte ?
cnt=0;
memcpy(recvbuf, cbuf, sizeof(cbuf));
parsercvbuf(cbuf);
displayvalues(10, cbuf);
// debug: change values to send back!
memcpy(sendbuf, recvbuf, sizeof(sendbuf)); // copy inbuf to outbuf
//sendbuf[4]+=1; // change [4] to send back
// debug...: careful! effing slowing down!
if( kbhit() ) {ch=0; while(ch!='\n') ch=getchar(); }
void* thread2_BUF(void *)
return NULL;
int main() {
unsigned long timesav;
char sbuf[128];
char instr[128];
pthread_t thread1, thread2;
//printf("initializing..."); printf("\n");
// UART Serial com port
Serial1 = serialOpen (uart, UARTclock); // for Arduino code compatibility reasons
// graphic screen
vgInitgraph();
vgHidewindow(); // Hide the graphic screen
// debug
// lcdprintxytop(50, 50, "press key to proceed");
// vgShowwindow(); // Show the graphic screen
// getchar();
vgcls();
pthread_create(&thread1, NULL, thread1_UART, NULL);
pthread_create(&thread2, NULL, thread2_BUF, NULL);
//wait for threads to join before exiting
pthread_join(thread1, NULL);
pthread_join(thread2, NULL);
serialClose( Serial1);
vgCleanup();
exit(0);
