Re: HDMI graphic lib: openvg syntax questions
ps, edit:
of course I tried it already passing the macro to the function call but that does not work
no one around here who did this before, by passing color names to the Stroke or Fill functions and so on?
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
Since Stroke() is expecting 4 parameters your code would have to bedavenull wrote:next question:
what would be the best way to pass "real color names" to the Stroke(r, g, b, x) function?
#define BLACK {0, 0, 0, 1}
#define WHITE {255,255,255, 1}
is this correct?
Stroke( WHITE );
analoguesly, e.g. for:
#define RED ...
#define BLUE
#define GREEN
#define YELLOW
#define MAGENTA
#define BROWN
#define LIME
#define GRAY
- is there already a list of common widely used colors predefined in openvg ?
#define WHITE 255, 255, 255, 1
Stroke( WHITE );
She who travels light — forgot something.
Please note that my name doesn't start with the @ character so can people please stop writing it as if it does!
thank you,
I never expected
to work lising 5 parameters without a brace around the last 4 ones
are those r,g,b,x coded colors a common color code? Is there a name for this color code like it's common for RGB (or RGBA or CMYK - or is this actually one of these)?
I never expected
#define when used like that just replaces all occurences of the first identifier with a list of the remaining identifers.davenull wrote:thank you,
I never expected
to work lising 5 parameters without a brace around the last 4 ones![]()
Where did you get X for the last value, it's A. Standard RGBA although I do find ajstarks' usage of int [0, 255] for RGB and then float [0.0, 1.0] for alpha to be confusing, OpenVG uses float [0.0, 1.0] for all four.
indeed, I didn't understand that
was actually a defamiliarized RGBA coding. That's why I paraphrased the float parameter by an "x" which is often used in analysis for Real numbers, opposite to Natural numbers.
So by Google search I found the keyword "CSS3 RGBA" which is using the same parameters as ajstarks is using, and additionally color palette tools:
http://www.css3-generator.de/rgba.html
https://developer.mozilla.org/de/docs/W ... l_werkzeug
Using this tool it should be possible to generate customized color name codes (I hope).
BROWN 100, 50, 15, 1
VIOLET 200, 20, 130, 1
nevertheless, having standardized name-code relations would be very much appreciated!
edit: found some:
http://www.december.com/html/spec/colorrgbadec.html
http://www.december.com/html/spec/colordec.html
http://www.colorcombos.com/light-blue-c ... hemes.html
some important ones missing >>> ?
edit: found some:
// defining just RGB values one could use a variable alpha luminiscence value by e.g.,
Stroke( RED, 0.5);
#define RED 255, 0, 0
#define DEEPPINK 255, 20, 147
#define PINK 255, 192, 203
#define ROSE 255, 0, 204
#define MAGENTA 238, 0, 238
#define FUCHSIA 255, 0, 255
#define PURPLE 160, 32, 240
#define YELLOW 255, 255, 0
#define PAPAYA 255, 255, 126
#define SIGNYELLOW 255, 209, 22
#define ORANGE 255, 102, 0
#define LIME 0, 255, 0
#define GREEN 0, 128, 0
#define DARKGREEN 47, 79, 47
#define CYAN 0, 255, 255
#define BLUE 0, 0, 255
#define ULTRAMARINE 18, 10, 143
#define AQUA 0, 255, 255
#define BROWN 128, 42, 42
#define SIGNBROWN 96, 51, 17
#define OCHRE 204, 119, 34
#define GRAY25 64, 64, 64
#define GRAY50 127, 127, 127
#define GRAY75 191, 191, 191
#define BLACK 0, 0, 0
I've updated my version for ajstatks' library to add in the outlined shapes and also functions to allow setting a window smaller than he screen that can be placed anywhere as long as at least 1 pixel is on screen. The window also has the ability to change it's transparency without clearing the screen like my early hack did.
In the Code he does have colours picked by their names, I could implement a similar system, keep a few common ones already set up as PaintTypes in a list the you could add to do save keeping creatimg and destroying paints.
Documentation is lacking at the moment, I've issued a pull request to ajstarks, my version can be taken from https://github.com/paeryn/openvg
that sounds amazing! Thank you very much for your efforts!
Now having also a smaller screen besides the other ones on the desktop is really an outstanding feature!
I just had my first look at it, it looks almost as if it's the complete entire openvg system like already ajstarks provided before?
Now if I wish to run your updated version, should I delete all files from ajstarks before?
Or do I only have to copy your files over / into the existing ones?
As working with Linux libs is really completely new to me:
What would you suggest, step by step,
how I can use your new API functions?
I have internet on my raspi, and an USB HD drive for my windows files which I can plug to my raspi too (and mounted there).
You might recognize that not just my Linux skilla but also my English is very poor indeed
Neither is the complete OpenVG system. They are both layers on top of OpenVG providing a few extra features. Mine looks so similar to ajstarks' because it is an extension of it, I made a few changes and added the extras. I sent a pull request so ajstarks can incorporate as much or as little of my changes to his version.
Since it is a direct replacement you can install it over the top as it will overwrite the exact same files. Reinstalling ajstarks' version will likewise overwrite mine.
Sorry about the lack of documentation, it was bed time and I forgot to add it in. I'll try and do it later today but basically (off the top of my head) the extra functions are :-
Edited - I originally wrote WindowMove() whereas the function is called WindowPosition().
// request window size and position on screen,
// call before init(), size cannot be altered after opening.
initWindowSize(x, y, w, h);
// clears the window to the last colour given to Background() so
// call that once right at the start (or whenever you want to change
// the background colour)..
// Use in place of Start() to clear the full window and nothing else.
WindowClear();
// Move window to given coordinates, -ve values upto -width,-height allow the window to be partially off the left/top of the screen.
WindowPosition(x, y);
// Set opacity of window, ranges between
// 0 = fully transparent and 255 = fully opaque.
WindowOpacity(alpha);
// All shapes that didn't have outline versions now do by adding Outline e.g.
// Rect() now has equivalent RectOutline()
hey,
the last install procedure for your extended libs were:
for the compiler: additionally
-lshape_plus
for the program: additionally
#include "shapes_plus.h"
what has to be changed now for a new install?
BTW,
what do you think about adding
vg********
before each of the openvg function calls?
e.g.
IMO that will make the API functions more clear to be related to openvg libs, opposite to different libs doing something important for different "windows".
Additionally, for having
wget https://www.dropbox.com/s/h37po1q305eab17/shapes_plus.tar.gz
tar xvf shapes_plus.tar.gz
sudo rm shapes_plus.tar.gz
cd shape_demo
make
sudo make install
-lshape_plus
BTW,
vg********
e.g.
vgInitWindowSize
vgWindowMove(x, y);
#define vgHidewindow HideWindow
#define vgShowwindow End
#define vgcls() ClearWindowRGB(_scrwidth_, _scrheight_, 0, 0, 0);
#define vgStart Start
#define vgInit init
#define vgCleanup finish
You don't need shapes_plus anymore, everything is in libshapes.
Personally I'm against prefixing with vg as they denote openvg's libs.
so I can delete the shapes_plus folder, but now how to install your libs instead?
I don't understand what to do unfortunately.
Same way as before, from within the (new) openvg directorydavenull wrote:so I can delete the shapes_plus folder, but now how to install your libs instead?
make
sudo make install
I don't even have the new openvg on my SD card - how do I get it there? (sorry, for Windows it would be easy, just
download zip,
unzip,
copy unzipped folder over existing openvg folder
but by linux ???
download zip,
unzip,
but by linux ???
You can do that on linux as well, if you're doing it from the command line you can download it withdavenull wrote:I don't even have the new openvg on my SD card - how do I get it there? (sorry, for Windows it would be easy, just
download zip,
unzip,
but by linux ???
wget https://github.com/paeryn/openvg/archive/master.zip
I'll try and keep my version as compatible as possible to the extent that any code that uses his original library will work without modification if linked with my fork. The main intention is that ajstarks can easily incorporate any modifications I make into his main version if he wishes to do so.
Just to clarify about the windowed mode in my version - if you're using the desktop it's not a window that the X window manager knows about in the sense that you can't move it on the desktop with your mouse and there won't be any title bar or borders. Movement can only be done directly by calling the WindowPosition() function in your own program.
ok, I made a copy of openvg called openvg_sav
then
ok
now: master.zip is in the pi folder.
how to get it to the correct folder openvg ?
what next?
Linux is really the 7th hell to me...
then
pi@raspberrypi ~ $ wget https://github.com/paeryn/openvg/archive/master.zip
what next?
Unzip it with (I'm sure the rpi has unzip by default)
That should create the new openvg directory with everything in it.
unzip master.zip
and the old directory of the same name (openvg) which is still existing has to be deleted before or should I just keep it as it is?
You could delete the old one as long as you copied everything including subdirectories. But you should be fine just letting it overwrite the current.
thank you, I recall:
correct? (dude, how I LOVE Windows!)
unzip master.zip
cd openvg
make
sudo make install
after
unzip master.zip I suddenly have a
openvg-master
dirctory
openvg-master
dirctory
Looks good to me.
You can't compare the linux command line to windows (unless you compare it to windows' command line).
Edit: okay, it's added the branch name to the directory name... I didn't realise github would do that.
the fontinfo files are not in your folder, but in the old one.
I'll copy just your files over the other ones...
indeed, how would I love to have a setup.exe program which installs all the files, all the folders, all the settings and all the drivers...
now this program don't work any more (it compiles fine though):
// shapedemo: testbed for OpenVG APIs
// Anthony Starks (ajstarks@gmail.com)
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <fcntl.h>
#include "VG/openvg.h"
#include "VG/vgu.h"
#include "fontinfo.h"
#include "shapes.h"
// randcolor returns a random number 0..255
unsigned int randcolor() {
return (unsigned int)(drand48() * 255.0);
// randf returns a floating point number bounded by n
VGfloat randf(int n) {
return drand48() * n;
// coordpoint marks a coordinate, preserving a previous color
void coordpoint(VGfloat x, VGfloat y, VGfloat size, VGfloat pcolor[4]) {
Fill(128, 0, 0, 0.3);
Circle(x, y, size);
setfill(pcolor);
// grid draws a grid
void grid(VGfloat x, VGfloat y, int n, int w, int h) {
VGfloat ix, iy;
Stroke(128, 128, 128, 0.5);
StrokeWidth(2);
for (ix = x; ix <= x + w; ix += n) {
Line(ix, y, ix, y + h);
for (iy = y; iy <= y + h; iy += n) {
Line(x, iy, x + w, iy);
// gradient demos linear and radial gradients
void gradient(int width, int height) {
VGfloat x1, y1, x2, y2, cx, cy, fx, fy, r;
VGfloat w = (VGfloat)width;
VGfloat h = (VGfloat)height;
VGfloat dotcolor[4] = {0, 0, 0, 0.3};
VGfloat stops[] = {
0.0, 1.0, 1.0, 1.0, 1.0,
0.5, 0.5, 0.5, 0.5, 1.0,
1.0, 0.0, 0.0, 0.0, 1.0
x1 = w/8;
x2 = (w*3)/8;
y1 = h/3;
y2 = (h*2)/3;
cx = (w*3)/4;
cy = (h/2);
r = (x2-x1);
fx = cx + (r/4);
fy = cy + (r/4);
Start(w, h);
Background(128, 128, 128);
FillLinearGradient(x1, y1, x2, y2, stops, 3);
Rect(x1, y1, x2-x1, y2-y1);
FillRadialGradient(cx, cy, fx, fy, r, stops, 3);
Circle(cx, cy, r);
RGBA(.5, 0, 0, 0.3, dotcolor);
setfill(dotcolor);
Circle(x1, y1, 10);
Circle(x2, y2, 10);
Circle(cx, cy, 10);
Circle(cx+r/2, cy, 10);
Circle(fx, fy, 10);
RGB(0,0,0,dotcolor);
setfill(dotcolor);
TextMid(x1, y1-20, "(x1, y1)", SansTypeface, 18);
TextMid(x2, y2+10, "(x2, y2)", SansTypeface, 18);
TextMid(cx, cy, "(cx, cy)", SansTypeface, 18);
TextMid(fx, fy, "(fx, fy)", SansTypeface, 18);
TextEnd(cx+(r/2)+20, cy, "r", SansTypeface, 18);
TextMid(x1+((x2-x1)/2), h/6, "Linear Gradient", SansTypeface, 36);
TextMid(cx, h/6, "Radial Gradient", SansTypeface, 36);
End();
// makepi draws the Raspberry Pi
void makepi(VGfloat x, VGfloat y, int w, int h) {
// dimensions
VGfloat socw = h / 5,
compw = h / 5,
cjw = h / 10,
cjh = h / 8,
audw = h / 5,
aujw = h / 10,
aujh = cjh / 2,
hdw = w / 6,
hdh = w / 10,
gpw = w / 3,
gph = h / 8,
pw = h / 10,
usw = w / 5,
ush = h / 5,
etw = w / 5,
eth = h / 5,
sdw = w / 6, sdh = w / 4, offset = (w / 2) / 10, w34 = (w * 3) / 4, w2 = w / 2, h2 = h / 2, h40 = (h * 2) / 5;
Fill(0, 128, 0, 1);
Rect(x, y, w, h); // board
Fill(255, 255, 0, 1);
Rect(x + w2, (y + h) - compw, compw, compw); // composite
Fill(192, 192, 192, 1);
Rect(x + w2 + (cjw / 2), y + h, cjw, cjh); // composite jack
Fill(0, 0, 0, 1);
Rect(x + w34, y + h - audw, audw, audw); // audio
Rect(x + w34 + (aujw / 2), y + h, aujw, aujh); // audio jack
Rect(x + w2, y, hdw, hdh); // HDMI
Rect((x + w) - etw, y, etw, eth); // Ethernet
Rect((x + w + offset) - usw, y + h40, usw, ush); // USB
Rect(x, y, pw, pw); // Power
Fill(0, 0, 0, 1);
Rect(x + (w * 2) / 5, y + h40, socw, socw); // SoC
Rect(x, (y + h) - gph, gpw, gph); // GPIO
Fill(0, 0, 255, 1);
Rect(x - sdw, (y + h2) - (sdh / 2), sdw, sdh); // SD card
// raspi draws the raspberry pi, scaled to the screen dimensions
void raspi(int w, int h, char *s) {
VGfloat midx = w / 2, midy = h / 2;
int rw = midx, rh = (rw * 2) / 3, fontsize = w * 0.03;
Start(w, h);
Background(255, 255, 255);
makepi(midx - (rw / 2), midy - (rh / 2), rw, rh);
Fill(128, 0, 0, 1);
TextMid(midx, midy - (rh / 2) - (fontsize * 2), s, SansTypeface, fontsize);
End();
typedef struct {
Fontinfo font;
VGfloat tw;
int fontsize;
} FW;
void textbbox(char *s, Fontinfo f, int pointsize) {
// adjust the font to fit within a width
void fitwidth(int width, int adj, char *s, FW * f) {
f->tw = TextWidth(s, f->font, f->fontsize);
while (f->tw > width) {
f->fontsize -= adj;
// testpattern shows a test pattern
void testpattern(int w, int h, char *s) {
VGfloat midx, midy1, midy2, midy3;
int fontsize = 256, h2 = h / 2;
FW tw1 = { MonoTypeface, 0, fontsize };
FW tw2 = { SansTypeface, 0, fontsize };
FW tw3 = { SerifTypeface, 0, fontsize };
Start(w, h);
// colored squares in the corners
Fill(255, 0, 0, 1);
Rect(0, 0, 100, 100);
Fill(0, 255, 0, 1);
Rect(0, h - 100, 100, 100);
Fill(0, 0, 255, 1);
Rect(w - 100, 0, 100, 100);
Fill(128, 128, 128, 1);
Rect(w - 100, h - 100, 100, 100);
// for each font, (Sans, Serif, Mono), adjust the string to the w
fitwidth(w, 20, s, &tw1);
fitwidth(w, 20, s, &tw2);
fitwidth(w, 20, s, &tw3);
midx = w / 2;
// Adjust the baselines to be medial
midy1 = h2 + 20 + (tw1.fontsize) / 2;
midy2 = h2 - (tw2.fontsize) / 2;
midy3 = h2 - 20 - tw2.fontsize - (tw3.fontsize) / 2;
TextMid(midx, midy1, s, tw1.font, tw1.fontsize);
Fill(128, 0, 0, 1);
TextMid(midx, midy2, s, tw2.font, tw2.fontsize);
Fill(0, 0, 128, 1);
TextMid(midx, midy3, s, tw3.font, tw3.fontsize);
End();
// textlines writes lines of text
void textlines(VGfloat x, VGfloat y, char *s[], Fontinfo f, int fontsize, VGfloat leading) {
int i;
for (i = 0;; i++) {
if (s[i] == NULL) {
break;
TextMid(x, y, s[i], f, fontsize);
y -= leading;
// tb draws a block of text
void tb(int w, int h) {
char *para[] = {
"For lo,",
"the winter is past,",
"the rain is over and gone",
"the flowers appear on the earth;",
"the time for the singing of birds is come,",
"and the voice of the turtle is heard in our land",
NULL
VGfloat tmargin = w * 0.5, lmargin = w * 0.10, top = h * .9, mid = h * .6, bot = h * .3;
int fontsize = 24, leading = 40, lfontsize = fontsize * 2, midb = ((leading * 2) + (leading / 2)) - (lfontsize / 2);
Start(w, h);
Fill(49, 79, 79, 1);
textlines(tmargin, top, para, SerifTypeface, fontsize, leading);
textlines(tmargin, mid, para, SansTypeface, fontsize, leading);
textlines(tmargin, bot, para, MonoTypeface, fontsize, leading);
Text(lmargin, top - midb, "Serif", SansTypeface, lfontsize);
Text(lmargin, mid - midb, "Sans", SansTypeface, lfontsize);
Text(lmargin, bot - midb, "Mono", SansTypeface, lfontsize);
End();
void imagetest(int w, int h) {
int imgw = 422, imgh = 238;
VGfloat cx = (w / 2) - (imgw / 2), cy = (h / 2) - (imgh / 2);
VGfloat ulx = 0, uly = h - imgh;
VGfloat urx = w - imgw, ury = uly;
VGfloat llx = 0, lly = 0;
VGfloat lrx = urx, lry = lly;
Start(w, h);
Background(0, 0, 0);
Image(cx, cy, imgw, imgh, "desert1.jpg");
Image(ulx, uly, imgw, imgh, "desert2.jpg");
Image(urx, ury, imgw, imgh, "desert3.jpg");
Image(llx, lly, imgw, imgh, "desert4.jpg");
Image(lrx, lry, imgw, imgh, "desert5.jpg");
End();
void imagetable(int w, int h) {
char *itable[] = {
"desert0.jpg",
"desert1.jpg",
"desert2.jpg",
"desert3.jpg",
"desert4.jpg",
"desert5.jpg",
"desert6.jpg",
"desert7.jpg",
NULL
VGfloat left = 50.0;
VGfloat bot = h - imgh - 50.0;
VGfloat gutter = 50.0;
VGfloat x = left;
VGfloat y = bot;
int i;
Start(w, h);
for (i = 0; itable[i] != NULL; i++) {
Image(x, y, imgw, imgh, itable[i]);
Fill(255, 255, 255, 0.3);
Rect(x, y, imgw, 32);
Fill(0, 0, 0, 1);
TextMid(x + (imgw / 2), y + 10, itable[i], SansTypeface, 16);
x += imgw + gutter;
if (x > w) {
x = left;
y -= imgh + gutter;
y = h * 0.1;
TextMid(w / 2, 100, "Joshua Tree National Park", SansTypeface, 48);
End();
// fontrange shows a range of fonts
void fontrange(int w, int h) {
int *s, sizes[] = { 6, 7, 8, 9, 10, 11, 12, 14, 16, 18, 21, 24, 36, 48, 60, 72, 96, 0 };
VGfloat x, y = h / 2, spacing = 50, s2 = spacing / 2, len, lx;
char num[4];
Start(w, h);
// compute the length so we can center
for (len = 0, s = sizes; *s; s++) {
len += *s + spacing;
len -= spacing;
lx = (w / 2) - (len / 2); // center point
// for each size, display a character and label
for (x = lx, s = sizes; *s; s++) {
Fill(128, 0, 0, 1);
TextMid(x, y, "a", SerifTypeface, *s);
snprintf(num, 3, "%d", *s);
TextMid(x, y - spacing, num, SansTypeface, 16);
x += *s + spacing;
// draw a line below the characters, a curve above
x -= spacing;
Stroke(150, 150, 150, 0.5);
StrokeWidth(2);
Line(lx, y - s2, x, y - s2);
Fill(255, 255, 255, 1);
Qbezier(lx, y + s2, x, y + s2, x, y + (spacing * 3));
End();
// refcard shows a reference card of shapes
void refcard(int width, int height) {
char *shapenames[] = {
"Circle",
"Ellipse",
"Rectangle",
"Rounded Rectangle",
"Line",
"Polyline",
"Polygon",
"Arc",
"Quadratic Bezier",
"Cubic Bezier",
"Image"
VGfloat shapecolor[4];
RGB(202, 225, 255, shapecolor);
VGfloat top = height * .95, sx = 500, sy = top, sw = width * .05, sh = height * .045, dotsize = 7, spacing = 2.0;
int i, ns = sizeof(shapenames) / sizeof(char *), fontsize = height * .033;
Start(width, height);
sx = width * 0.10;
Fill(128, 0, 0, 1);
TextEnd(width - 20, height / 2, "OpenVG on the Raspberry Pi", SansTypeface, fontsize + (fontsize / 2));
Fill(0, 0, 0, 1);
for (i = 0; i < ns; i++) {
Text(sx + sw + sw / 2, sy, shapenames[i], SansTypeface, fontsize);
sy -= sh * spacing;
sy = top;
VGfloat cx = sx + (sw / 2), ex = sx + sw;
setfill(shapecolor);
Circle(cx, sy, sw);
coordpoint(cx, sy, dotsize, shapecolor);
sy -= sh * spacing;
Ellipse(cx, sy, sw, sh);
sy -= sh * spacing;
Rect(sx, sy, sw, sh);
coordpoint(sx, sy, dotsize, shapecolor);
sy -= sh * spacing;
Roundrect(sx, sy, sw, sh, 20, 20);
sy -= sh * spacing;
StrokeWidth(1);
Stroke(204, 204, 204, 1);
Line(sx, sy, ex, sy);
coordpoint(ex, sy, dotsize, shapecolor);
sy -= sh;
VGfloat px[5] = { sx, sx + (sw / 4), sx + (sw / 2), sx + ((sw * 3) / 4), sx + sw };
VGfloat py[5] = { sy, sy - sh, sy, sy - sh, sy };
Polyline(px, py, 5);
coordpoint(px[0], py[0], dotsize, shapecolor);
coordpoint(px[1], py[1], dotsize, shapecolor);
coordpoint(px[2], py[2], dotsize, shapecolor);
coordpoint(px[3], py[3], dotsize, shapecolor);
coordpoint(px[4], py[4], dotsize, shapecolor);
sy -= sh * spacing;
py[0] = sy;
py[1] = sy - sh;
py[2] = sy - (sh / 2);
py[3] = py[1] - (sh / 4);
py[4] = sy;
Polygon(px, py, 5);
sy -= (sh * spacing) + sh;
Arc(sx + (sw / 2), sy, sw, sh, 0, 180);
coordpoint(sx + (sw / 2), sy, dotsize, shapecolor);
sy -= sh * spacing;
VGfloat cy = sy + (sh / 2), ey = sy;
Qbezier(sx, sy, cx, cy, ex, ey);
coordpoint(cx, cy, dotsize, shapecolor);
coordpoint(ex, ey, dotsize, shapecolor);
sy -= sh * spacing;
ey = sy;
cy = sy + sh;
Cbezier(sx, sy, cx, cy, cx, sy, ex, ey);
sy -= (sh * spacing * 1.5);
Image(sx, sy, 100, 100, "starx.jpg");
End();
// rotext draws text, rotated around the center of the screen, progressively faded
void rotext(int w, int h, int n, char *s) {
VGfloat fade = (100.0 / (VGfloat) n) / 100.0;
VGfloat deg = 360.0 / n;
VGfloat x = w / 2, y = h / 2;
VGfloat alpha = 1.0; // start solid
int i, size = w / 8;
Start(w, h);
Translate(x, y);
for (i = 0; i < n; i++) {
Fill(255, 255, 255, alpha);
Text(0, 0, s, SerifTypeface, size);
alpha -= fade; // fade
size += n; // enlarge
Rotate(deg);
End();
// rseed seeds the random number generator from the random device
void rseed(void) {
unsigned char d[sizeof(long int)];
long int s;
int fd;
// read bytes from the random device,
// pack them into a long int.
fd = open("/dev/urandom", O_RDONLY);
if (fd < 0) {
srand48(1);
return;
read(fd, (void *)d, (size_t) sizeof(long int));
s = d[3] | (d[2] << 8) | (d[1] << 16) | (d[0] << 24);
srand48(s);
close(fd);
// rshapes draws shapes with random colors, strokes, and sizes.
void rshapes(int width, int height, int n) {
int i, j, np = 10;
VGfloat sx, sy, cx, cy, px, py, ex, ey, pox, poy;
VGfloat polyx[np], polyy[np];
rseed();
Fill(randcolor(), randcolor(), randcolor(), drand48());
Ellipse(randf(width), randf(height), randf(200), randf(100));
Circle(randf(width), randf(height), randf(100));
Rect(randf(width), randf(height), randf(200), randf(100));
Arc(randf(width), randf(height), randf(200), randf(200), randf(360), randf(360));
sx = randf(width);
sy = randf(height);
Stroke(randcolor(), randcolor(), randcolor(), 1);
StrokeWidth(randf(5));
Line(sx, sy, sx + randf(200), sy + randf(100));
StrokeWidth(0);
sx = randf(width);
sy = randf(height);
ex = sx + randf(200);
ey = sy;
cx = sx + ((ex - sx) / 2.0);
cy = sy + randf(100);
sx = randf(width);
sy = randf(height);
ey = sy;
px = cx;
py = sy - randf(100);
Cbezier(sx, sy, cx, cy, px, py, ex, ey);
pox = randf(width);
poy = randf(height);
for (j = 0; j < np; j++) {
polyx[j] = pox + randf(200);
polyy[j] = poy + randf(100);
Polygon(polyx, polyy, np);
pox = randf(width);
Polyline(polyx, polyy, np);
Fill(128, 0, 0, 1);
Text(20, 20, "OpenVG on the Raspberry Pi", SansTypeface, 32);
End();
// sunearth shows the relative sizes of the sun and the earth
void sunearth(int w, int h) {
VGfloat sun, earth, x, y;
int i;
rseed();
Start(w, h);
for (i = 0; i < w / 4; i++) {
x = randf(w);
y = randf(h);
Circle(x, y, 2);
earth = (VGfloat) w *0.010;
sun = earth * 109;
Fill(0, 0, 255, 1);
Circle(w / 3, h - (h / 10), earth);
Fill(255, 255, 224, 1);
Circle(w, 0, sun);
End();
// advert is an ad for the package
void advert(int w, int h) {
VGfloat y = h/4;
int fontsize = (w * 4) / 100;
char *s = "github.com/ajstarks/openvg";
char *a = "ajstarks@gmail.com";
int imw = 110, imh = 110, rw = w/4, rh = (rw*2/3);
VGfloat tw = TextWidth(s, SansTypeface, fontsize);
Start(w, h);
makepi((w/2) - (rw/2), h/2, rw, rh);
Fill(128, 0, 0, 1);
Text(w / 2 - (tw / 2), y - (fontsize / 4), s, SansTypeface, fontsize);
y -= 100;
tw = TextWidth(a, SansTypeface, fontsize / 3);
Text(w / 2 - (tw / 2), y, a, SansTypeface, fontsize / 3);
Image((w / 2) - (imw / 2), 20, imw, imh, "starx.jpg");
End();
// demo shows a timed demonstration
void demo(int w, int h, int sec) {
refcard(w, h);
sleep(sec);
rshapes(w, h, 50);
sleep(sec);
testpattern(w, h, "OpenVG on RasPi");
sleep(sec);
imagetable(w, h);
sleep(sec);
rotext(w, h, 30, "Raspi");
sleep(sec);
tb(w, h);
sleep(sec);
fontrange(w, h);
sleep(sec);
sunearth(w, h);
sleep(sec);
raspi(w, h, "The Raspberry Pi");
sleep(sec);
gradient(w,h);
sleep(sec);
advert(w, h);
// wait for a specific character
void waituntil(int endchar) {
int key;
for (;;) {
key = getchar();
if (key == endchar || key == '\n') {
break;
// main initializes the system and shows the picture.
// Exit and clean up when you hit [RETURN].
int main(int argc, char **argv) {
int w, h, n;
char *usage =
"%s [command]\n\tdemo sec\n\tastro\n\ttest ...\n\trand n\n\trotate n ...\n\timage\n\ttext\n\tfontsize\n\traspi\n\tadvert\n\tgradient\n";
char *progname = argv[0];
saveterm();
init(&w, &h);
rawterm();
switch (argc) {
case 2:
if (strncmp(argv[1], "image", 5) == 0) {
imagetable(w, h);
} else if (strncmp(argv[1], "text", 4) == 0) {
tb(w, h);
} else if (strncmp(argv[1], "astro", 5) == 0) {
sunearth(w, h);
} else if (strncmp(argv[1], "fontsize", 8) == 0) {
fontrange(w, h);
} else if (strncmp(argv[1], "advert", 6) == 0) {
advert(w,h);
} else if (strncmp(argv[1], "raspi", 5) == 0) {
} else if (strncmp(argv[1], "gradient", 8) == 0) {
gradient(w,h);
} else {
restoreterm();
fprintf(stderr, usage, progname);
return 1;
break;
case 3:
n = atoi(argv[2]);
if (strncmp(argv[1], "demo", 4) == 0) {
if (n < 1 || n > 30) {
n = 5;
demo(w, h, n);
} else if (strncmp(argv[1], "rand", 4) == 0) {
if (n < 1 || n > 1000) {
n = 100;
rshapes(w, h, n);
} else if (strncmp(argv[1], "test", 4) == 0) {
testpattern(w, h, argv[2]);
} else {
restoreterm();
return 1;
break;
case 4:
if (strncmp(argv[1], "rotate", 6) == 0) {
rotext(w, h, atoi(argv[2]), argv[3]);
} else {
restoreterm();
return 1;
break;
default:
refcard(w, h);
waituntil(0x1b);
restoreterm();
finish();
return 0;
I'll have a look when I get home. Strange the fontinfo files aren't there, it should have all the original files... maybe I made a mistake setting git up (I've only ever used it to download, this is the first time uploading to it).
another mistake is with this different former program:
it gives a compile error unless I #include shapes_plus,
and after I did, it stops and waits for a key press after the final test (graph) before showing the benchmark results... strangely ...
I don't see why or if I messed anything up accidentally...?
// HaWe Brickbench
// benchmark test for NXT/EV3 and similar Micro Controllers
// PL: GCC, Raspi, Raspbian Linux
// Autor: (C) Helmut Wunder 2013,2014
// ported to Raspi by "HaWe"
// freie Verwendung für private Zwecke
// für kommerzielle Zwecke nur nach schriftlicher Genehmigung durch den Autor.
// protected under the friendly Creative Commons Attribution-NonCommercial-ShareAlike 3.0 Unported License
// http://creativecommons.org/licenses/by-nc-sa/3.0/
// version 1.09.005 25.10.2015
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <math.h>
#include <fcntl.h>
#include <string.h>
#include <sys/ioctl.h>
#include <stdint.h>
#include <time.h>
#include <sys/time.h>
#include "VG/vgu.h"
#include "shapes.h"
unsigned long runtime[8];
int a[500], b[500], c[500], t[500];
uint32_t timer()
struct timeval now;
uint32_t ticks;
gettimeofday(&now, NULL);
ticks=now.tv_sec*1000+now.tv_usec/1000;
return(ticks);
// Mersenne Twister
unsigned long randM(void) {
const int M = 7;
const unsigned long A[2] = { 0, 0x8ebfd028 };
static unsigned long y[25];
static int index = 25+1;
if (index >= 25) {
int k;
if (index > 25) {
unsigned long r = 9, s = 3402;
for (k=0 ; k<25 ; ++k) {
r = 509845221 * r + 3;
s *= s + 1;
y[k] = s + (r >> 10);
for (k=0 ; k<25-M ; ++k)
y[k] = y[k+M] ^ (y[k] >> 1) ^ A[y[k] & 1];
for (; k<25 ; ++k)
y[k] = y[k+(M-25)] ^ (y[k] >> 1) ^ A[y[k] & 1];
index = 0;
unsigned long e = y[index++];
e ^= (e << 7) & 0x2b5b2500;
e ^= (e << 15) & 0xdb8b0000;
e ^= (e >> 16);
return e;
// Matrix Algebra
// matrix * matrix multiplication (matrix product)
void MatrixMatrixMult(int N, int M, int K, double *A, double *B, double *C) {
int i, j, s;
for (i = 0; i < N; ++i) {
for (j = 0; j < K; ++j) {
C[i*K+j] = 0;
for (s = 0; s < M; ++s) {
C[i*K+j] = C[i*K+j] + A[i*N+s] * B[s*M+j];
// matrix determinant
double MatrixDet(int N, double A[]) {
int i, j, i_count, j_count, count = 0;
double Asub[N - 1][N - 1], det = 0;
if (N == 1)
return *A;
if (N == 2)
return ((*A) * (*(A+1+1*N)) - (*(A+1*N)) * (*(A+1)));
for (count = 0; count < N; count++) {
i_count = 0;
for (i = 1; i < N; i++) {
j_count = 0;
for (j = 0; j < N; j++) {
if (j == count)
continue;
Asub[i_count][j_count] = *(A+i+j*N);
j_count++;
i_count++;
det += pow(-1, count) * A[0+count*N] * MatrixDet(N - 1, &Asub[0][0]);
return det;
// shell sort
void shellsort(int size, int* A)
int i, j, increment;
int temp;
increment = size / 2;
while (increment > 0) {
for (i = increment; i < size; i++) {
j = i;
temp = A[i];
while ((j >= increment) && (A[j-increment] > temp)) {
A[j] = A[j - increment];
j = j - increment;
A[j] = temp;
if (increment == 2)
increment = 1;
else
increment = (unsigned int) (increment / 2.2);
// gnu quick sort
// (0ptional)
int compare_int (const int *a, const int *b)
int temp = *a - *b;
if (temp > 0) return 1;
else if (temp < 0) return -1;
else return 0;
// gnu qsort:
// void qsort (void *a , size_a count, size_a size, compare_function)
// gnu qsort call for a[500] array of int:
// qsort (a , 500, sizeof(a), compare_int)
// benchmark test procedures
int test_Int_Add() {
int i=1, j=11, k=112, l=1111, m=11111, n=-1, o=-11, p=-111, q=-1112, r=-11111;
int x;
volatile long s=0;
for(x=0;x<10000;++x) {
s+=i; s+=j; s+=k; s+=l; s+=m; s+=n; s+=o; s+=p; s+=q; s+=r;
return s;
long test_Int_Mult() {
int x,y;
volatile long s;
for(y=0;y<2000;++y) {
s=1;
for(x=1;x<=13;++x) { s*=x;}
for(x=13;x>0;--x) { s/=x;}
return s;
#define PI M_PI
double test_float_math() {
volatile double s=PI;
int y;
for(y=0;y<1000;++y) {
s*=sqrt(s);
s=sin(s);
s=exp(s);
s*=s;
return s;
long test_rand_MT(){
volatile unsigned long s;
int y;
for(y=0;y<5000;++y) {
s=randM()%10001;
return s;
double test_matrix_math() {
int x;
double A[2][2], B[2][2], C[2][2];
double S[3][3], T[3][3];
unsigned long s;
for(x=0;x<250;++x) {
A[0][0]=1; A[0][1]=3;
A[1][0]=2; A[1][1]=4;
B[0][0]=10; B[0][1]=30;
B[1][0]=20; B[1][1]=40;
MatrixMatrixMult(2, 2, 2, A[0], B[0], C[0]); // <<<<<<<<<<<<<<<<<<<
MatrixDet(2, A[0]); // <<<<<<<<<<<<<<<<<<<
S[0][0]=1; S[0][1]=4; S[0][2]=7;
S[1][0]=2; S[1][1]=5; S[1][2]=8;
S[2][0]=3; S[2][1]=6; S[2][2]=9;
MatrixDet(3, S[0]); // <<<<<<<<<<<<<<<<<<<
s=(S[0][0]*S[1][1]*S[2][2]);
return s;
// for array copy using void *memcpy(void *dest, const void *src, size_t n);
long test_Sort(){
unsigned long s;
int y;
int t[500];
for(y=0;y<30;++y) {
memcpy(t, a, sizeof(a));
shellsort(500, t);
memcpy(t, a, sizeof(b));
shellsort(500, t);
memcpy(t, a, sizeof(c));
shellsort(500, t);
return y;
long test_TextOut(){
int y=77;
char buf[120];
for(y=0;y<20;++y) {
Background(0, 0, 0); // Black background
//Text(x, y, buf, SerifTypeface, 20);
Fill(255, 255, 255, 1); // White text
sprintf (buf, "%3d %4d int_Add", 0, 1000); Text( 20, 200- 20, buf, SerifTypeface, 20); End();
sprintf (buf, "%3d %4d int_Mult", 1, 1010); Text( 20, 200- 40, buf, SerifTypeface, 20); End();
sprintf (buf, "%3d %4d float_op", 2, 1020); Text( 20, 200- 60, buf, SerifTypeface, 20); End();
sprintf (buf, "%3d %4d randomize", 3, 1030); Text( 20, 200- 80, buf, SerifTypeface, 20); End();
sprintf (buf, "%3d %4d matrx_algb", 4, 1040); Text( 20, 200-100, buf, SerifTypeface, 20); End();
sprintf (buf, "%3d %4d arr_sort", 5, 1050); Text( 20, 200-120, buf, SerifTypeface, 20); End();
sprintf (buf, "%3d %4d displ_txt", 6, 1060); Text( 20, 200-140, buf, SerifTypeface, 20); End();
sprintf (buf, "%3d %4d testing...", 7, 1070); Text( 20, 200-160, buf, SerifTypeface, 20); End();
return y;
long test_graphics(){
int y=0;
for(y=0;y<100;++y) {
ClearWindow(); // Colour and size are remembered from the
// ClearWindowRGBA() call at the start of the program
Stroke(255, 255, 255, 1); // Set these at the start, no need to
Fill(255,255,255, 1); // keep calling them if colour hasn't changed
End();
CircleOutline(50, 40, 10); // circles
End();
Circle(30, 24, 10);
End();
Line(10, 10, 60, 60); // just 2 intersecting lines
End();
Line(50, 20, 90, 70);
End();
RectOutline(20, 20, 40, 40); // rectangles
End();
Rect(65, 25, 20, 30);
End();
EllipseOutline(70, 30, 15, 20); // ellipse
End();
return y;
inline void displayValues() {
char buf[120];
sprintf (buf, "%3d %7ld int_Add", 0, runtime[0]); printf(buf); printf("\n");
sprintf (buf, "%3d %7ld int_Mult", 1, runtime[1]); printf(buf); printf("\n");
sprintf (buf, "%3d %7ld float_op", 2, runtime[2]); printf(buf); printf("\n");
sprintf (buf, "%3d %7ld randomize", 3, runtime[3]); printf(buf); printf("\n");
sprintf (buf, "%3d %7ld matrx_algb", 4, runtime[4]); printf(buf); printf("\n");
sprintf (buf, "%3d %7ld arr_sort", 5, runtime[5]); printf(buf); printf("\n");
sprintf (buf, "%3d %7ld displ_txt", 6, runtime[6]); printf(buf); printf("\n");
sprintf (buf, "%3d %7ld graphics", 7, runtime[7]); printf(buf); printf("\n");
int main(){
unsigned long time0, x, y;
float s;
char buf[120];
int width, height;
char str[3];
init(&width, &height); // Graphics initialization
Start(width, height); // Start the picture
ClearWindowRGB(width, height, 0, 0, 0);
HideWindow(); // Hide the picture
printf("hw brickbench"); printf("\n");
printf("initializing..."); printf("\n");
for(y=0;y<500;++y) {
a[y]=randM()%30000; b[y]=randM()%30000; c[y]=randM()%30000;
time0= timer();
s=test_Int_Add();
runtime[0]=timer()-time0;
time0=timer();
s=test_Int_Mult();
runtime[1]=timer()-time0;
sprintf (buf, "%3d %7ld int_Mult", 0, runtime[1]); printf(buf); printf("\n");
time0=timer();
s=test_float_math();
runtime[2]=timer()-time0;
sprintf (buf, "%3d %7ld float_op", 0, runtime[2]); printf(buf); printf("\n");
time0=timer();
s=test_rand_MT();
runtime[3]=timer()-time0;
sprintf (buf, "%3d %7ld randomize", 0, runtime[3]); printf(buf); printf("\n");
time0=timer();
s=test_matrix_math();
runtime[4]=timer()-time0;
sprintf (buf, "%3d %7ld matrx_algb", 0, runtime[4]); printf(buf); printf("\n");
time0=timer();
s=test_Sort();
runtime[5]=timer()-time0;
sprintf (buf, "%3d %7ld arr_sort", 0, runtime[5]); printf(buf); printf("\n");
time0=timer();
s=test_TextOut();
runtime[6]=timer()-time0;
time0=timer();
time0=timer();
s=test_graphics();
runtime[7]=timer()-time0;
//HideWindow(); // Hide the picture
y=0;
for(x=0;x<8;++x) {y+= runtime[x];}
printf("\n");
printf("\n");
displayValues();
sprintf (buf, "gesamt ms: %ld ", y); printf(buf); printf("\n");
sprintf (buf, "benchmark: %ld ", 50000000/y ); printf(buf); printf("\n");
fgets(str, 2, stdin); // look at the pic, end with [RETURN]
finish(); // Graphics cleanup
exit(0);
