RogerW
qtcreator on jessie
Sat Oct 03, 2015 11:09 am
I am trying to install qtcreator on jessie. I get this when I try to run it from a command window.
libEGL warning: DRI2: failed to authenticate
No tool chain set from kit "Desktop".
Unable to find an X11 visual which matches EGL config 125
Could not initialize OpenGL
Aborted
I imagine I need to install more packages - but what?
Re: qtcreator on jessie
Sat Oct 03, 2015 11:24 am
RogerW wrote:I am trying to install qtcreator on jessie. I get this when I try to run it from a command window.
Aborted
How or what did you install :?:
The RPi supports OpenGL ES, but you have an OpenGL error :?:
Did you install from repository :?:
sudo apt-get update
sudo apt-get install qtcreator
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
RogerW
Sat Oct 03, 2015 12:42 pm
Yes I installed from the repository. As far as I can remember
sudo apt-get install qt5-default
This was probably a mistake as I thought it would give a basic installation.
Then
Sat Oct 03, 2015 1:07 pm
RogerW wrote:Yes I installed from the repository. As far as I can remember
Then
https://packages.debian.org/jessie/qtcreator
RogerW
Sat Oct 03, 2015 1:15 pm
That seems to list 30 dependent packages - do I have to install them all one by one?
Sat Oct 03, 2015 1:20 pm
No, it will auto install dependencies when run
sudo apt-get update
RogerW
Sat Oct 03, 2015 1:40 pm
Thanks for your help
fruitoftheloom wrote: No, it will auto install dependencies when run
sudo apt-get update
Done that - nothing installed.
However I used synaptic to chack the packes installed against that list and three appear to be missing:
qtbase-abi-5-3-2
qtdeclarative-abi-5-3-2
qtquick1-abi-5-2-1
These do not seem to be in the repository
[Edit]
Thinking about it I suspect that the prblem is not those "missing" packages but something to go with OpenGL.I have no idea where to look.
RogerW
Sat Oct 03, 2015 3:56 pm
For anyone else trying to use QtCreator this got me going
viewtopic.php?t=99129&p=688095
Add "-noload Welcome" to the command line. I would still like to hear of a proper fix though.
Sat Oct 03, 2015 5:52 pm
RogerW wrote:For anyone else trying to use QtCreator this got me going
TY :D
RogerW
Sat Oct 03, 2015 6:17 pm
fruitoftheloom wrote: TY :D
Sat Oct 03, 2015 6:21 pm
Just saying thankyou TY for finding solution, if I need to use the software will know what to expect...
Sat Oct 03, 2015 6:33 pm
It's an internet abbreviation for "thank you" because Fruity is missing the vowel keys on his keyboard.
This is a doctor free zone.
RogerW
Sat Oct 03, 2015 6:37 pm
Just put it down to old age.
tksaha
Mon Oct 05, 2015 2:14 pm
Ok, qtcreator starts, but no kit, no qmake. Has any body installed and used it? Then please let us know how to compile.
RogerW
Mon Oct 05, 2015 2:44 pm
Tools/Options/Build&Run/Kits
Then click on Desktop(default)
find Compiler and click Manage button
Clock Add and select GCC
Having done all this I can compile. However this is not saved when you close QtCteator.
Does anyone know how to get it to save?
topguy
Mon Oct 05, 2015 2:47 pm
sudo apt-get install qt5-default qt5-qmake, qtbase5-dev-tools
This should be the basic, but there are a lot of "-dev" packages for the different Qt-modules.
Maybe "qt5-doc" also should be considered, I dont know if QtCeator are able to make use of them.
Edit:
If you want to make Qt apps of course, you can set it up to use fo any C/C++ code as Roger explained.
Fastcash
Wed Nov 18, 2015 9:17 am
Hi everyone,
In complement of the RogerW 's solution, you can deactivate the Welcome plugin once you started Qt Creator the first time.
Go to Help -> About Plugins...
Uncheck Qt Creator --> Welcome
Restart Qt Creator
This is just a temporary solution that give you the possibity to launch Qt Creator without typing "-noload Welcome" to the command line for your following session.
Best regards,
Starmage
Thu Aug 17, 2017 11:16 am
Has anyone actually had success running qtcreator on Jessie on a Pi 3?
I need something that's simple to install (using gtk+/Glade at moment without any issue)..
But am considering if qtCreator is a better option.
procount
Thu Aug 17, 2017 11:58 am
A long time ago, I installed QT4 on Jessie (RPi 2&3) to edit/compile NOOBS. It still works fine.
According to aptitude, I installed the following qt4 packages:
  • qt4-dev-tools
  • qt4-linguistic-tools
  • qtcreator
It lists the following packages as having being automatically installed:
  • qt4-designer
  • qt4-qmake
  • qtbase5-dev-tools
  • qtcreator-data
  • qtdeclarative5-dev-tools
  • qttools5-dev-tools
  • qtxmlpatterns5-dev-tools
Maybe there were others I installed too, but it was too long ago to remember.
I also needed to add the "-noload Welcome" to get qtcreator to run.
I have no experience with QT5.
PINN - NOOBS with the extras... https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=142574
Return to “C/C++”
