I'm subclassing a QTextEdit and I can't get the cursor to show.
Flow:-
From the button slot, I call a QDialog (propForm).
From the dialog, I call a subclassed QTextEdit (data/dataEdit).
No matter what I try, I can't get the cursor to show (visible).
The program compiles and runs OK, up to the point of a noshow cursor.
Could someone tell me what I haven't done.
Regards
void menu::textButton() // slot
prop = new propForm(this);
prop->setObjectName("prop" + QString::number(cm::formCount));
prop->setFocus();
#ifndef PROPFORM_H
#define PROPFORM_H
#include <QDialog>
#include <QLabel>
#include "dataEdit.h"
class propForm : public QDialog
Q_OBJECT
public:
propForm(QWidget *parent = 0);
dataEdit *data;
QLabel *fileData;
protected slots:
void focusInEvent(QFocusEvent *);
void closeEvent(QCloseEvent *);
void focusOutEvent(QFocusEvent *);
bool eventFilter(QObject *, QEvent *);
#endif // PROPFORM_H
propForm::propForm(QWidget *parent) : QDialog(parent)
this->resize(400, 300);
this->setWindowTitle(cm::subItem);
this->setStyleSheet(sty::style1);
QString filePath = (cm::mainItem + "/" + cm::subItem);
fileData = new QLabel(filePath, this);
fileData->setGeometry(0, 0, this->width(), 25);
fileData->setFrameStyle(QFrame::Panel | QFrame::Sunken);
fileData->setAlignment(Qt::AlignHCenter | Qt::AlignBottom);
data = new dataEdit(this);
data->setObjectName("data" + QString::number(cm::formCount));
data->setGeometry(0, fileData->height(), this->width(), this->height() - fileData->height());
QFile file(filePath);
if ( ! (file.open(QIODevice::ReadOnly))) {
cr::message("Can't open file\nfor read.", "Error", 2);
return;
QTextStream in(&file);
while ( ! in.atEnd()) data->append(in.readLine());
file.close();
this->show();
#ifndef DATAEDIT_H
#define DATAEDIT_H
#include <QTextEdit>
class dataEdit : public QTextEdit
Q_OBJECT
public:
dataEdit(QWidget *parent = 0);
~dataEdit();
protected slots:
void showEvent(QShowEvent *);
void resizeEvent(QResizeEvent *e);
private slots:
void onTextChanged();
private:
//QTextCursor *textCursor;
#endif // DATAEDIT_H
dataEdit::dataEdit(QWidget *parent) : QTextEdit(parent)
qDebug() << "start1";
this->activateWindow();
this->setFocus();
connect(this, SIGNAL(textChanged()), this, SLOT(onTextChanged()));
qDebug() << "start2";
this->setReadOnly(false);
this->setEnabled(true);
this->setLineWrapMode(NoWrap);
QTextCursor textCursor(this->textCursor());
textCursor.movePosition(QTextCursor::Start, QTextCursor::MoveAnchor, 1);
textCursor.movePosition(QTextCursor::EndOfLine, QTextCursor::MoveAnchor, 1); //end of first line
this->ensureCursorVisible();
qDebug() << "end";
void dataEdit::showEvent(QShowEvent *e)
qDebug() << "show1";
void dataEdit::focusInEvent(QFocusEvent *)
qDebug() << "focusInEvent - " << this->objectName();
void dataEdit::onTextChanged()
qDebug() << "text changed";
OUTPUT:
start1
start2
end
text changed [text changed
text changed (from
text changed (the data
text changed (loaded
text changed (at startup
show1
focusInEvent - "data1"
