Do the Dom suggested removal of ttyAMA0 from cmdline.txt and add the 'bcm2708.uart_clock=3000000'
However, do nothing to the config.txt (remove references if you already have the uart stuff in).
The #includes are for this code, other #includes may be required....
#include <termios.h>
#include <sys/mman.h>
#include <errno.h>
#define UART_BASE 0x20201000 // PL011 USART -->B+
int fd = 0;
int mem_fd = 0;
int errsv = 0;
volatile unsigned* uart = NULL;
void* uart_map = NULL;
void* IBRD = NULL;
void* FBRD = NULL;
void* LCRH = NULL;
void* UARTCR = NULL;
void* UARTFR = NULL;
uint32_t brd = 0;
struct termios termios_p;
fd = open( "/dev/ttyAMA0", O_RDWR | O_NOCTTY | O_NONBLOCK );
if( fd > 0 ) // set the baud rate and other configurations
tcgetattr( fd, &termios_p );
termios_p.c_lflag &= ~ISIG; // no signals
termios_p.c_lflag &= ~ICANON; // no canonical mode
termios_p.c_lflag &= ~ECHO; // no echo input
termios_p.c_lflag &= ~NOFLSH; // no flushing on SIGINT
termios_p.c_lflag &= ~IEXTEN; // no input processing
termios_p.c_cc[VMIN] = 0;
termios_p.c_cc[VTIME] = 0;
tcsetattr( fd, TCSANOW, &termios_p );
// Now set the uart baud rate divisors
if( ( mem_fd = open( "/dev/mem", O_RDWR | O_SYNC ) ) < 0 )
fprintf( stdout, "can't open /dev/mem for mmap(). Did you use 'sudo' ?\n" );
return;
uart_map = mmap( NULL, BLOCK_SIZE, PROT_READ | PROT_WRITE, MAP_SHARED, mem_fd, UART_BASE );
close( mem_fd );
if( uart_map == MAP_FAILED )
errsv = errno;
fprintf( stdout,"uart mmap failed\n" );
fprintf( stdout, "error %d %s\n", errsv, strerror( errsv ) );
else
uart = (volatile unsigned*)uart_map;
UARTFR = (void*)( (uint32_t)uart + 0x18 );
IBRD = (void*)( (uint32_t)uart + 0x24 );
FBRD = (void*)( (uint32_t)uart + 0x28 );
LCRH = (void*)( (uint32_t)uart + 0x2C );
UARTCR = (void*)( (uint32_t)uart + 0x30 );
// first, disable the uart and flush the fifos
brd = 0x0B00;
memcpy( UARTCR, &brd, 4 );
// check for completion of any tx/rx
memcpy( &brd, UARTFR, 4 );
while( brd & 0x08 )
usleep( 1 ); // wait a bit
brd = 6; // 3000000 / ( 16 * 31250 ) = 6.0
memcpy( IBRD, &brd, 4 );
brd = 0;
memcpy( FBRD, &brd, 4 );
brd = 0x70; // 8 bit data, FIFO enabled
memcpy( LCRH, &brd, 4 );
// enable uart, tex, rex etc.
brd = 0x0B01;
// close mmap once done here
munmap( uart_map, BLOCK_SIZE );
else
errsv = errno;
fprintf( stdout,"/dev/ttyAMA0 access failed\n" );
fd = 0;
Setting the uart_clock to 2441406 sets to an actual of 2441000. This introduces an error rate
that in turn causes, well, errors every n bits. In my case it was every 6th bit.
That in turn led to a RTFM moment
Stu.
