HermannSW
C scripts / C++ scripts
Sun Sep 12, 2021 4:36 pm
I know there are good reasons for only one language per source file.
Nevertheless I really like multi-language scripts.
All together in a single source makes changing anything easy, as well as makes it easy to move the file anywhere.
I remembered today when answering a posting [bash + C]:
viewtopic.php?f=37&t=319444&p=1912504#p1912448
Especially the head of my github "gamepad" tool, that allows to control a 4DoF robot arm with cheap SNES gamepad (the bash script uses pigpio library pigs commands to control the 4 servos):
https://github.com/Hermann-SW/4DoF_robo ... ls/gamepad
#!/bin/bash
# contains and uses this version of Jason White's joystick.c at bottom
# https://gist.github.com/jasonwhite/c5b2048c15993d285130/eb3bcd6e1cd88002d21764b9965d075eceaf4b83
# requires SNES joystick connected to Raspberry USB, pigpio library installed
js=/tmp/joystick
if [ ! -f $js ]; then sed -n "/^\/\*\*$/,\$p" $0 | gcc -x c - -o $js; fi
g=1500
The bash script tests whether /tmp/joystick is existent, and if not extracts the C code from bottom of gamepad and compiles it to /tmp/joystick:
exit
 * Author: Jason White
In my day job I am responsible as L3 support for all "IBM DataPower Gateway" compilers.
"3lang.js" is a multi-language script that utilizes 3 languages.
I used it as example in a blog posting (unfortunately IBM deleted all developerworks blogs end of 2019, inclusive my 268 blog posts -- only few are available):
https://stamm-wilbrandt.de/en/blog/3lang.js
Three of the languages DataPower supports are XSLT 1.0 (oldest), XQuery 1.0 and GatewayScript (similar to nodejs). It is possible to call XSLT from GatewayScript [with transform.xslt()], as well as to call XQuery from XSLT [with dp:xquery-transform()]. So 3lang.js executed in a GatewayScript action allows to utilize XQuery language features (most notably XPath 2.0 support) only that way. This was just demonstrator code for what is possible in case if needed.
We have seen above how C code can be extracted from bash script part after "exit" command and compiled into /tmp executable, and executed from there. Tiny C compiler "tcc" (sudo apt install tcc) allows for even easier C script with its "-⁠run" option (compile and run directly, do not store executable), and Unix shebang. This is from tcc man page:
$ cat shtcc
#!/usr/bin/tcc -run
#include <stdio.h>
int main()
    printf("Hello World\n");
    return 0;
Directly executing this script just does what you think:
$ ./shtcc
Hello World
Now that is a C only script, without any bash script part.
"shtcc2" utilizes the idea in initial "gamepad" script, but without storing compiled executable:
Execution:
$ ./shtcc2
foo
bar
There is absolutely no need to use C scripts, but for simple tasks they can be quite useful.
P.S:
Syntax highlighted HTML page created with "TOHtml" tool (based on vim's "+TOhtml" feature, for 600 different syntaxes):
viewtopic.php?f=33&t=317616
https://stamm-wilbrandt.de/2wheel_balancing_robot
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/en/Raspberry_camera.html
HermannSW
Re: C scripts
Mon Sep 13, 2021 4:28 pm
One possible application for C script is "multi-piping".
In bash shell you have the pipe operator, but I don't know of any way to split input onto 2 or more pipes in bash.
In C execution of "popen()" does execute a binary with a pipe to it, allowing for splitting into multiple pipes.
I will use that to split 4056x3040 12MP HQ camera YUV i420 frame into six 2028x1080 subframes covering the whole frame, and then use i420tohtml tool (executed by popen) to .h264 encode each of the 6 frames. Just opening 6 pipes with popen(), code to extract 2028x1080 i420 subframe works already:
viewtopic.php?f=43&t=316426&p=1912087#p1912087
While I will likely create a pure C program doing so, the "multi-piping" idea can be used in a C script for something else, allowing the bash part of C script utilize "multi-piping".
trejan
Re: C scripts
Mon Sep 13, 2021 5:49 pm
https://tldp.org/LDP/abs/html/process-sub.html
Re: C scripts
Mon Sep 13, 2021 10:19 pm
HermannSW
Re: C scripts
Tue Sep 14, 2021 7:23 am
I don't see how sub processes should help to split "one" input pipe onto more than one output pipe.
I did not think of "tee" command for this scenario.
I can only get it working with result in wrong order (output first 3 lines of input using first pipe, then last two lines of input using second pipe):
pi@raspberrypi400:~ $ echo -e "1\n2\n3\n4\n5\n6\n7" | tee >(head -3) | tail -5
6
7
1
2
3
Any idea for solving this test problem with "tee", or with sub processes?
I went ahead and created C script solution "headtail.c" for this.
I like to have ".c" suffix although it is a script for indication that C part is contained.
First time that a "*.c" file needs to be executable for me ;-)
Here you can see that it does its job, demonstrating splitting input pipe onto more than one output pipe:
pi@raspberrypi400:~ $ echo -e "1\n2\n3\n4\n5\n6\n7" | ./headtail.c
1
2
3
6
7
Here is headtail.c:
("$0 -nt $exc" is better than "! -f $exc" used before, since it triggers recompilation in case script has been modified)
https://gist.github.com/Hermann-SW2/209 ... 12e438dc37
HermannSW
Re: C scripts
Tue Sep 14, 2021 10:26 am
I would not have thought that generalized output to n pipes would be so easy to have.
Of course I did it with C script.
Demo with 3 pipes:
$ echo -e "1\n2\n3\n4\n5\n6\n7\n8\n9\n10" | ./pipn.c "head -3" "wc" "tail -2"
1
2
3
     10      10      21
9
10
Now demo with "pipe in pipe":
$ echo -e "1\n2\n3\n4\n5\n6\n7\n8\n9\n10" | ./pipn.c "head -3 | wc" "tail -2"
      3       3       6
9
10
"pipn.c" processes each passed argument command line with bash -c "...", which is generated in "cmd()". In previous posting "fgets()" was for text files only. Now with "fread()" and "fwrite()" arbitrary (binary) data can be pipe processed as well:
https://gist.github.com/Hermann-SW2/c69 ... e33673c162
P.S:
New bash "operator" |n pipes into more than 1 pipe:
viewtopic.php?f=66&t=319603
Simple demo for piping into 3 pipes, with 2nd "pipe of pipes":
$ cat /etc/X11/rgb.txt |n 'head -3' "head -55 | tail -17 | wc" "tail -2"
! $Xorg: rgb.txt,v 1.3 2000/08/17 19:54:00 cpqbld Exp $
255 250 250		snow
248 248 255		ghost white
     17      79     407
144 238 144		light green
144 238 144		LightGreen
trejan
Re: C scripts
Tue Sep 14, 2021 3:00 pm
$ cat /etc/X11/rgb.txt | tee >(head -3) >(head -55 | tail -17 | wc) >(tail -2) > /dev/null
255 250 250             snow
     17      79     407
trejan
Re: C scripts
Tue Sep 14, 2021 3:17 pm
You should change your pipn program to call setvbuf(pip[stupidforumwontletmeuseihere], NULL, _IONBF, 0) on each process stream to turn off buffering.
Paeryn
Re: C scripts
Tue Sep 14, 2021 4:01 pm
You might want to change the call to sprintf() into a call to snprintf() to prevent a possible buffer overflow
  // limit the number of chars written to the size of the buffer
  snprintf( cmds, siz, "bash -c \"%s\"", s );
Though you'll also want to either make sure the whole string was written in case it was cropped or dynamically allocate the buffer so it's always big enough to hold the complete string.
She who travels light — forgot something.
Please note that my name doesn't start with the @ character so can people please stop writing it as if it does!
Re: C scripts
Tue Sep 14, 2021 4:12 pm
I'm pretty sure the C code your presented is not guaranteed to produce the output in the order you expect either. You have a race condition.
You have spun up two processes, one for 'head' and one for 'tail'. They then run independently and write their output to stdout.
There is no guarantee that the Linux kernel will schedule them in any order you expect.
HermannSW
Re: C scripts
Tue Sep 14, 2021 8:03 pm
With the help of @Trejan in the other thread
viewtopic.php?f=66&t=319603&p=1913408#p1913414
tee command can definitely do what I tried to do with "pipn.c" .
So no need for "pipn.c" anymore (besides demo for "C script").
It is most times the best to use existing Linux command line tools.
The best general form of piping into N pipes is this:
viewtopic.php?f=66&t=319603&p=1913408#p1913540
... | (tee >(cmd1) >(cmd2) ... >(cmdN) > /dev/null) ...
You are right, this happened in posting pointed to last, same command, different order of outputs (see posting on final "| cat"):
$ cat /etc/X11/rgb.txt | (tee >(head -3) >(head -55 | tail -17 | wc) >(tail -2) > /dev/null) | cat
255 250 250		snow
     17      79     407
255 250 250		snow
     17      79     407
P.S:
So Linux tee command allows to pipe into two pipes.
That would allow for "divide" step of divide and conquer merge sort.
Just solved the "conquer" step, merging of two sorted seuqences into one sorted sequence.
I think I never used Linux comm command before.
Use of sed is needed in order to output data identical in both inputs (column 3) two times.
It is currently not clear how to combine for complete recursive divide and conquer pipe mergesort.
Definitely not needed since we have Linux sort command.
But doing pipe mergesort of 2^n rows file with 2^n parallel pipes in between (before conquer steps) sounds like fun ...
HermannSW
Re: C scripts
Wed Sep 15, 2021 7:36 pm
I did split off this new thread as followup on "comm" usage mentioned in previous posting:
"Parallel recursive bash mergesort / fun / challenge"
viewtopic.php?f=31&t=319687
HermannSW
Re: C scripts
Thu Sep 16, 2021 1:46 pm
I answered on stackoverflow question "How to compile and execute from memory directly?"
https://stackoverflow.com/a/69204024/5674289
I mention tcc's "-run" option and showed tcc base C script from previous posting in this thread. Then I realized that the way I did the C script, the script's stdin is not available to C code executed by "tcc -run". Reason was piping C code extracted from C script via pipe.
"run_from_memory_stdin.c" demonstrates accessing C script stdin by C code, as well as working argv:
https://gist.github.com/Hermann-SW/7bc1 ... 5b15139c5f
$ route -n | ./run_from_memory_stdin.c
foo
bar 42
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         172.29.58.98    0.0.0.0         UG    306    0        0 wlan1
10.0.0.0        0.0.0.0         255.255.255.0   U     0      0        0 wlan0
169.254.0.0     0.0.0.0         255.255.0.0     U     303    0        0 wlan0
172.29.58.96    0.0.0.0         255.255.255.252 U     306    0        0 wlan1
The trick was to pass extracted C code this way:
echo "foo"
tcc -run <(sed -n "/^\/\*\*$/,\$p" $0) 42
HermannSW
Re: C scripts / C++ scripts
Sun Sep 19, 2021 7:28 am
I created C memrun repo, that allows to execute ELF binary in memory (verified for x86_64 as well as armv7l):
https://github.com/Hermann-SW/memrun/tr ... r/C#memrun
With that "run from memory" tool gcc as well can be used for "C script" without auxiliary filesystem files created. Since tcc is a C compiler only, "tcc -run" cannot help for "C++ script", while memrun can!
https://github.com/Hermann-SW/memrun/tr ... c-script-1
pi@raspberrypi400:~/memrun/C $ echo "2^64" | bc -q | ./run_from_memory_cin.cpp
foo
bar 42
18446744073709551616
This is (executable) run_from_memory_cin.cpp producing above mixed bash and C++ output:
HermannSW
Sun Sep 19, 2021 11:12 am
The C/C++ scripts seen sofar only showed how bash and C/C++ in single file can work. New section "C/C++ interaction with bash in script" describes a two year old C script, converted to "run from memory" (gamepad.c):
https://github.com/Hermann-SW/memrun/tr ... -in-script
This is how bash and C code parts work together (C code stdout output is input for bash part), in "done" line with 3 nested process substitutions:
while IFS= read -r line; do
    case $line in
    esac
    echo $g $u $l $p $d $calib
    pigs s 8 $g; pigs s 9 $u; pigs s 10 $l; pigs s 11 $p
done < <(./memrun <(gcc -o /dev/fd/1 -x c <(sed -n "/^\/\*\*$/,\$p" $0)))
exit
Return to “C/C++”
