hesam_m
Raspberry Pi Pico using C/C++ SDK
Sat Jun 19, 2021 6:05 am
I'm using C/C++ SDK for the Pico board and I have compiled and run the C code successfully. I have two questions:
1) is there any way to see the consumed memory and usage statistic (Flash, SRAM)?
2) How can I optimize the code (probably through CMake) for size or speed?
pic0
Re: Raspberry Pi Pico using C/C++ SDK
Sat Jun 19, 2021 10:46 am
See here.
kilograham
Sat Jun 19, 2021 1:11 pm
also looking at the generated map file gives you aa trove of information
defaault build is optimized; pass -DCMAKE_BUILD_TYPE=MinSizeRel to cmake for a min size release build, though generally you're better off with the default.
hesam_m
Sat Jun 19, 2021 1:13 pm
See here.
Thank you, however where the Size command belongs to?
hesam_m
Sat Jun 19, 2021 1:16 pm
Thank you. How can I optimize it for speed?
triss64738
Sat Jun 19, 2021 1:49 pm
-DCMAKE_BUILD_TYPE=Release optimizes for speed, which I think is already the default.
hesam_m
Sat Jun 19, 2021 2:24 pm
I'm using VSCode. I changed the Cmake to "Release" and compiled the code. The generated UF2 file is 20K or so heavier and it has not optimized for Speed. is there anything I missed?
triss64738
Sat Jun 19, 2021 4:06 pm
If you're on Windows, you can find the "size" binary somewhere around where your cross-compiler is installed. (I don't know where that is, I don't run Windows.)
hesam_m wrote:and it has not optimized for Speed
How so? It should (compared to -DCMAKE_BUILD_TYPE=Debug).
hesam_m
Sat Jun 19, 2021 5:04 pm
Yes, the file on windows is arm-none-eabi-size.exe and this is the output, Now I'm not sure which one is FLASH and which one is SRAM
Because I'm actually testing the execution speed of a known code block, that I have tested the speed difference on the STM32 compiler by using optimized for speed (-Ofast). The speed of the know code block I see on Pico is the default speed, the same as STM32 with no applied optimization. So selecting Release did not help.
I'm using VSCode and I change Debug and Release there
kilograham
Sat Jun 19, 2021 5:51 pm
The default release cmake build is optimized...
you may be having issues with VS Code... try doing a clean build, also the output from the cmake generation or the build is most useful if you are making screenshot.
Fair enough, but are you running the instructions more than once? the first execution is likely to be slower as it will read from flash.
triss64738
Sat Jun 19, 2021 6:17 pm
Yes, that's the default output of size. If you add the --format=SysV or -A flag, it gives a more detailed output. -x turns the output into hexadecimal:
$ arm-none-eabi-size -Ax test.elf
test.elf  :
section                  size         addr
.text                  0xb914   0x20000000
.rodata                 0xa28   0x2000b918
.binary_info             0x38   0x2000c340
.data                   0x124   0x2000c380
.uninitialized_data       0x0   0x2000c4a4
.scratch_x                0x0   0x20040000
.scratch_y                0x0   0x20041000
.bss                   0x175c   0x2000c4a8
.heap                   0x800   0x2000dc04
.stack_dummy            0x800   0x20041000
.ARM.attributes          0x2d          0x0
.comment                 0x11          0x0
.debug_line             0x228          0x0
.debug_info             0x9a4          0x0
.debug_abbrev           0x1fc          0x0
.debug_aranges           0x40          0x0
.debug_str              0x5d9          0x0
.debug_loc               0x90          0x0
.debug_ranges            0x10          0x0
.debug_frame             0x28          0x0
Total                 0x100db
All the .debug etc. stuff can be ignored, but the rest gives you an idea about how everything is laid out. The addresses tell you whether things are in SRAM, or in flash. Addresses starting with 0x2 are in SRAM, those with 0x1 are in flash. In the above example, everything is in SRAM, because I compiled it with the -DPICO_NO_FLASH=On CMake option. If I wouldn't have specified it, .text and .rodata would most likely have addresses starting with 0x1, and thus be in flash. If you want a nicer output, I guess you could write a script that parses this output.
hesam_m
Sat Jun 19, 2021 7:58 pm
Thank you for your helpful comments and replies. The problem of both cases are now solved.
Return to “SDK”
