arielmalka
Help required for cross-compiling C/C++ to rpi from a mac
Thu Apr 29, 2021 12:37 pm
Hi, my goal is to cross-compile from a mac (intel), ideally targeting arm64 bit architecture.
I found a tutorial, which explains how to do it (targeting arm32 bit architecture, good enough for now):
https://www.jianshu.com/p/534bee6becee
The problem is that it refers to the linaro g++ compiler, which I can't find.
When going to https://www.linaro.org/downloads, it's not clear where to download and install the actual linaro toolchain for mac.
Any help would be greatly appreciated, thanks!
swampdog
Re: Help required for cross-compiling C/C++ to rpi from a mac
Sun May 09, 2021 3:01 pm
I haven't done this in a very long time but when I did I used ct-ng..
https://crosstool-ng.github.io/
..which appears to have grabbed a linaro-gcc as part of its build.
I can't help further. :-|
arielmalka
Sun May 09, 2021 4:13 pm
Thanks.
But according to their docs: "macOS is no longer officially supported by crosstool-NG. If the instructions below work for you, congratulations. If they kill your cat, ye be warned."
So I ended-up using Docker and some ubuntu image, with this solution....
mattlewis
Sun May 09, 2021 8:24 pm
FYI, I use Docker to cross compile on my Mac: https://hub.docker.com/r/diozero/diozero-cc
A bit new to me but working well so far, extremely convenient and fast. Just reading other comments regarding cross compilation and can see that it is a huge topic! Fortunately my use cases only require very basic features.
https://www.diozero.com/
Return to “C/C++”
