dsyleixa123
C++ functions to retrieve and set IPs a/o SSIDs in the local home network?
Sun May 09, 2021 11:14 am
hi,
which would be the C/C++ functions to retrieve and set IPs (IPv4) a/o SSIDs in the local home network, to be used inside of a C++ program?
e.g.,
get current router IP (e.g., 192.168.1.1)
get current router SSID (e.g., WLAN123456)
get current local Raspi IP (e.g., 192.168.1.103)
change/set local Raspi IP (to e.g., 192.168.1.100) and reconnect
retrieve all currently available router SSIDs
connect arbitrarily to a different router (by SSID+pwd)
check router connection
(I want to store all data in variables for further processing)
Re: C++ code to retrieve and set IPs a/o SSIDs in the local home network?
Sun May 09, 2021 3:41 pm
This code gets the IPv4 address
char* getIPaddr()
  struct ifaddrs* interfaceArray = NULL, *tempIfAddr = NULL;
  void* tempAddrPtr = NULL;
  int rc = 0;
  char addressOutputBuffer[INET6_ADDRSTRLEN];
  char* ifaceIP = malloc (40);
  rc = getifaddrs(&interfaceArray);	/* retrieve the current interfaces */
  if (rc == 0)
      for (tempIfAddr = interfaceArray; tempIfAddr != NULL;
	   tempIfAddr = tempIfAddr->ifa_next)
	  if (tempIfAddr->ifa_addr->sa_family == AF_INET)
	      tempAddrPtr =
		&((struct sockaddr_in*) tempIfAddr->ifa_addr)->sin_addr;
	      if (strncmp (tempIfAddr->ifa_name, "lo", 2))	/* interface ISN'T loopback */
		  inet_ntop (tempIfAddr->ifa_addr->sa_family, tempAddrPtr,
			     addressOutputBuffer,
			     sizeof (addressOutputBuffer));
		  sprintf (ifaceIP, "%s %s\0", tempIfAddr->ifa_name,
			   addressOutputBuffer);
      freeifaddrs (interfaceArray);	/* free the dynamic memory */
      interfaceArray = NULL;	/* prevent use after free  */
  else
      printf ("getifaddrs() failed with errno =  %d %s \0",
	      errno, strerror (errno));
  return ifaceIP;
To set an IP address steal the code from the ip command or test if https://stackoverflow.com/a/6940391/3491475 works.
cleverca22
Sun May 09, 2021 4:02 pm
root@pi400:~# wpa_cli -i wlan0 status | egrep ^ssid
ssid=TP-LINK_Extender_5GHz
root@pi400:~# wpa_cli -i wlan0 scan
OK
root@pi400:~# wpa_cli -i wlan0 scan_results
bssid / frequency / signal level / flags / ssid
d8:0d:17:x       5180    -40     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       TP-LINK_Extender_5GHz
d8:0d:17:x       2457    -29     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       TP-LINK_Extender_2.4GHz
4c:8b:30:x       2462    -51     [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]      FIBREOP038
28:c2:dd:x       2442    -56     [WPA2-PSK-TKIP][ESS]    Family-nas
f8:ab:05:x       2462    -73     [WPA2-PSK-CCMP][WPS][ESS]       BELL220
00:fc:8d:x       2462    -80     [WPA-PSK-CCMP][WPA2-PSK-CCMP][WPS][ESS] Simmons
5c:7d:7d:x       5220    -90     [WPA2-PSK-CCMP][ESS]
you need a bit of a delay between scan and scan_results
root@pi400:~# wpa_cli -i wlan0 list_networks
network id / ssid / bssid / flags
0       TP-LINK_Extender_5GHz   any     [CURRENT]
1       Alexander-5G    any
2       TP-LINK_Extender_2.4GHz any
root@pi400:~# wpa_cli -i wlan0 select_network 2
this lets you force a certain network, if its already been added
dsyleixa123
Sun May 09, 2021 4:35 pm
thank you!
@ DougieLawson: what do you mean by "steal the code from the ip command"?
OTOH, the code at the link is no C code which I know how to use, tbh...
@ cleverca22: is that C/C++ code at all?
Sun May 09, 2021 4:49 pm
@ DougieLawson: what do you mean by steal the code from the ip command?
Take a look at the source for for the IP command and see how it sets an IP address.
https://mirrors.edge.kernel.org/pub/lin ... 9.0.tar.xz
The stack overflow posting has an example program
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <stddef.h>             /* offsetof */
#include <net/if.h>
#include <sys/ioctl.h>
#include <sys/socket.h>
#include <arpa/inet.h>
#include <linux/sockios.h>
#include <netinet/in.h>
#if __GLIBC__ >=2 && __GLIBC_MINOR >= 1
#include <netpacket/packet.h>
#include <net/ethernet.h>
#else
#include <asm/types.h>
#include <linux/if_ether.h>
#endif
#define IFNAME "eth0:2"
#define HOST "192.168.3.135"
#define ifreq_offsetof(x)  offsetof(struct ifreq, x)
int main(int argc, char **argv) {
        struct ifreq ifr;
        struct sockaddr_in sai;
        int sockfd;                     /* socket fd we use to manipulate stuff with */
        int selector;
        unsigned char mask;
        int rc;
        char *p;
        /* Create a channel to the NET kernel. */
        sockfd = socket(AF_INET, SOCK_DGRAM, 0);
        /* get interface name */
        strncpy(ifr.ifr_name, IFNAME, IFNAMSIZ);
        memset(&sai, 0, sizeof(struct sockaddr));
        sai.sin_family = AF_INET;
        sai.sin_port = 0;
        sai.sin_addr.s_addr = inet_addr(HOST);
        p = (char *) &sai;
        memcpy( (((char *)&ifr + ifreq_offsetof(ifr_addr) )),
                        p, sizeof(struct sockaddr));
        rc=ioctl(sockfd, SIOCSIFADDR, &ifr);
        printf("SIOCSIFADDR rc %d\n", rc);
        rc=ioctl(sockfd, SIOCGIFFLAGS, &ifr);
        printf("SIOCSIFFLAGS rc %d\n", rc);
        ifr.ifr_flags |= IFF_UP | IFF_RUNNING;
        // ifr.ifr_flags &= ~selector;  // unset something
        rc=ioctl(sockfd, SIOCSIFFLAGS, &ifr);
        close(sockfd);
        return 0;
that needs to run with sudo that creates an eth0:2 interface and assigns 192.168.1.204 to it.
dsyleixa123
Sun May 09, 2021 4:56 pm
thanks try it ASAP.
as to your 1st code: I can't compile it (I use g++):
#include <stdio.h>
#include <string.h>
#include <errno.h>
char* getIPaddr()
  int rc = 0;
  if (rc == 0)
	      tempAddrPtr =
  else
  return ifaceIP;
#include <stdio.h>
    char IPaddr[16]; //192.168.111.222 len=15+1
    strcpy(IPaddr, getIPaddr() );
    printf("%s", IPaddr);
    char c=getchar();
	return 0;
g++ -Wall -I/opt/vc/include -c  "IPaddr001.c" -pthread -I/opt/vc/include -lshapes -lwiringPi -lpigpio -lrt $(pkg-config eigen3 --cflags) -lreadline (im Verzeichnis: /home/pi/raspiProgs/internet)
IPaddr001.c: In function ‘char* getIPaddr()’:
IPaddr001.c:10:28: error: ‘INET6_ADDRSTRLEN’ was not declared in this scope
IPaddr001.c:11:29: error: ‘malloc’ was not declared in this scope
IPaddr001.c:13:34: error: ‘getifaddrs’ was not declared in this scope
IPaddr001.c:17:28: error: invalid use of incomplete type ‘struct getIPaddr()::ifaddrs’
IPaddr001.c:7:10: note: forward declaration of ‘struct getIPaddr()::ifaddrs’
IPaddr001.c:19:18: error: invalid use of incomplete type ‘struct getIPaddr()::ifaddrs’
IPaddr001.c:19:43: error: ‘AF_INET’ was not declared in this scope
IPaddr001.c:22:37: error: invalid use of incomplete type ‘struct getIPaddr()::ifaddrs’
IPaddr001.c:24:31: error: invalid use of incomplete type ‘struct getIPaddr()::ifaddrs’
IPaddr001.c:26:26: error: invalid use of incomplete type ‘struct getIPaddr()::ifaddrs’
IPaddr001.c:27:9: error: ‘addressOutputBuffer’ was not declared in this scope
IPaddr001.c:28:37: error: ‘inet_ntop’ was not declared in this scope
IPaddr001.c:29:44: error: invalid use of incomplete type ‘struct getIPaddr()::ifaddrs’
IPaddr001.c:35:34: error: ‘freeifaddrs’ was not declared in this scope
IPaddr001.c:41:31: warning: embedded ‘\0’ in format [-Wformat-contains-nul]
IPaddr001.c: In function ‘int main(int, char**)’:
IPaddr001.c:57:10: warning: unused variable ‘c’ [-Wunused-variable]
     char c=getchar();
Kompilierung fehlgeschlagen.
Sun May 09, 2021 4:59 pm
I've updated it to suppress the warnings.
It's C so compile with gcc -o ipaddup ipaddup.c
Run it with sudo ./ipaddup
dsyleixa123
Sun May 09, 2021 5:02 pm
I always need g++ because I always include C++ libs additionally (and it also will have to run as a function in qt creator).
will try the updated code now...
(edit: just now noticed that you didn't change your 1st code yet which I am currently using...)
dsyleixa123
Sun May 09, 2021 5:04 pm
#include <stdio.h>
#include <string.h>
#include <errno.h>
char* getIPaddr()
  int rc = 0;
  if (rc == 0)
	      tempAddrPtr =
  else
  return ifaceIP;
int main()
    char IPaddr[16]; //192.168.xxx.yyy len=15+1
    strncpy(IPaddr, getIPaddr(), 15);
    char c=getchar();
    return 0;
g++ -Wall -I/opt/vc/include -o  "IPaddr_read001" "IPaddr_read001.c" -pthread -I/opt/vc/include -lshapes -lwiringPi -lpigpio -lrt $(pkg-config eigen3 --cflags) -lreadline  (im Verzeichnis: /home/pi/raspiProgs/internet)
IPaddr_read001.c: In function ‘char* getIPaddr()’:
IPaddr_read001.c:10:28: error: ‘INET6_ADDRSTRLEN’ was not declared in this scope
IPaddr_read001.c:11:29: error: ‘malloc’ was not declared in this scope
IPaddr_read001.c:13:34: error: ‘getifaddrs’ was not declared in this scope
IPaddr_read001.c:17:28: error: invalid use of incomplete type ‘struct getIPaddr()::ifaddrs’
IPaddr_read001.c:7:10: note: forward declaration of ‘struct getIPaddr()::ifaddrs’
IPaddr_read001.c:19:18: error: invalid use of incomplete type ‘struct getIPaddr()::ifaddrs’
IPaddr_read001.c:19:43: error: ‘AF_INET’ was not declared in this scope
IPaddr_read001.c:22:37: error: invalid use of incomplete type ‘struct getIPaddr()::ifaddrs’
IPaddr_read001.c:24:31: error: invalid use of incomplete type ‘struct getIPaddr()::ifaddrs’
IPaddr_read001.c:26:26: error: invalid use of incomplete type ‘struct getIPaddr()::ifaddrs’
IPaddr_read001.c:27:9: error: ‘addressOutputBuffer’ was not declared in this scope
IPaddr_read001.c:28:37: error: ‘inet_ntop’ was not declared in this scope
IPaddr_read001.c:29:44: error: invalid use of incomplete type ‘struct getIPaddr()::ifaddrs’
IPaddr_read001.c:35:34: error: ‘freeifaddrs’ was not declared in this scope
IPaddr_read001.c:41:31: warning: embedded ‘\0’ in format [-Wformat-contains-nul]
IPaddr_read001.c: In function ‘int main(int, char**)’:
IPaddr_read001.c:56:10: warning: unused variable ‘c’ [-Wunused-variable]
     char c=getchar();
cleverca22
Sun May 09, 2021 5:17 pm
the example i gave was just raw shell commands, but you can access wpa_cli over a unix socket too
#include <QString>
#include <sys/types.h>
#include <QDebug>
#include <sys/un.h>
#include <QTimer>
#include <QTime>
#include "wpa_client.h"
int connect_proxy(int fd,sockaddr *addr,int size) {
	return connect(fd,addr,size);
wpa_client::wpa_client(QString interface) {
	this->interface = interface;
	pinger = new QTimer(this);
	connect(pinger,SIGNAL(timeout()),this,SLOT(ping_it()));
	pinger->start(5000);
	connected = false;
void wpa_client::ping_it() {
	if ((!connected) && (fd > 0)) {
		if (try_connect()) return;
	} else send_msg("PING");
void wpa_client::connect_wpa() {
	fd = socket(PF_FILE,SOCK_DGRAM,0);
	if (!fd) return;
	struct sockaddr_un self;
	self.sun_family = AF_FILE;
	strncpy(self.sun_path,"/tmp/wpa_client",100);
	unlink("/tmp/wpa_client");
	if (bind(fd,(sockaddr*)&self,sizeof(self))) {
		qDebug("err1");
		return;
	start();
bool wpa_client::try_connect() {
	struct sockaddr_un target;
	target.sun_family = AF_FILE;
	strncpy(target.sun_path,qPrintable(QString("/var/run/wpa_supplicant/wlan0")),100);
	if (connect_proxy(fd,(sockaddr*)&target,sizeof(target))) {
		qDebug() << QString("err2 %1").arg(fd);
		return true;
	qDebug() << "connected?";
	if (send_msg("ATTACH")) {
		return true;
	qDebug() << "attached";
	connected = true;
	return false;
bool wpa_client::send_msg(QString msg) {
	if (fd < 0) return true;
	const char *buffer;
	buffer = qPrintable(msg);
	int length = strlen(buffer);
	int ret = send(fd,buffer,length,0);
	if (ret == -1) {
		qDebug("connection lost, reconn");
		connected = false;
		return true;
	if (ret != (int)length) {
		qDebug() << QString("send of %1 was partial %2 %3").arg(msg).arg(ret).arg(length);
		return true;
	return false;
void wpa_client::run() {
	char buffer[1024];
	int size;
	while (1) {
		size = recv(fd,buffer,1024,0);
		buffer[size] = 0;
		pinger->start(10000);
		QString line = buffer;
		if (line == "PONG\n") {
		} else {
			qDebug() << QTime::currentTime() << QString(buffer);
something i wrote to handle it ~10 years ago
an example session:
> status
> scan
OK
<3>CTRL-EVENT-SCAN-STARTED
<3>CTRL-EVENT-SCAN-RESULTS
there is a delay between started and results, which tells you when you can then issue scan_results
the syscalls behind it:
root@pi400:~# strace wpa_cli -i wlan0
socket(AF_UNIX, SOCK_DGRAM, 0)          = 3
bind(3, {sa_family=AF_UNIX, sun_path="/tmp/wpa_ctrl_14804-1"}, 110) = 0
connect(3, {sa_family=AF_UNIX, sun_path="/var/run/wpa_supplicant/wlan0"}, 110) = 0
socket(AF_UNIX, SOCK_DGRAM, 0)          = 4
bind(4, {sa_family=AF_UNIX, sun_path="/tmp/wpa_ctrl_14804-2"}, 110) = 0
connect(4, {sa_family=AF_UNIX, sun_path="/var/run/wpa_supplicant/wlan0"}, 110) = 0
send(4, "ATTACH", 6, 0)                 = 6
recv(4, "OK\n", 10, 0)                  = 3
send(3, "STATUS", 6, 0)                 = 6
recv(3, "bssid=d8:0d:xx\nfreq=518"..., 4095, 0) = 299
wpa_cli is almost exactly the same protocol send over the unix socket
dsyleixa123
Sun May 09, 2021 5:24 pm
thanks cleverca22, I don't understand how to use the functions (and I'm afraid destroying aything on my Pi accidentally by faulty usage).
And my skills are very poor, I do not even know what wpa or socket are, I just know an IP address, and a SSID, and a password ;)
do you have compileable and executable code with a main() and demonstating either usage?
cleverca22
Sun May 09, 2021 5:26 pm
you cant really destroy things when using wpa and sockets
also, the code i quoted, was originally written for an x86 laptop, so you dont even need to involve the pi when testing it, if you have a normal linux machine
dsyleixa123
Sun May 09, 2021 5:27 pm
no, I just have a Pi 2 and no other Linux machine, and need it just for my Pi
(cross-over post:)
do you have compileable and executable code with a main() and demonstrating either usage? (I compile by Geany for the first steps, no GUI, no qt libs, just C and std:: libs and LXterminal)
cleverca22
Sun May 09, 2021 5:55 pm
stripped out all of the QT code, and now i just have:
#include <sys/un.h>
#include <unistd.h>
#include <stdio.h>
static inline ssize_t out(int fd, const char *msg) {
  return send(fd, msg, strlen(msg), 0);
  int fd = socket(AF_UNIX, SOCK_DGRAM, 0);
  bind(fd, (sockaddr*)&self,sizeof(self));
  strncpy(target.sun_path, "/var/run/wpa_supplicant/wlan0", 100);
  connect(fd, (sockaddr*)&target,sizeof(target));
  out(fd, "ATTACH");
  char buffer[1024];
  int size;
  bool exit_soon = false;
  while (true) {
    size = recv(fd, buffer, 1024, 0);
    buffer[size] = 0;
    printf("received: %s\n", buffer);
    if (exit_soon) {
      out(fd, "DETACH");
      break;
    if (strcmp(buffer,"OK\n") == 0) {
      out(fd, "STATUS");
      out(fd, "SCAN");
    } else if (strcmp(buffer, "<3>CTRL-EVENT-SCAN-RESULTS ") == 0) {
      out(fd, "SCAN_RESULTS");
     exit_soon = true;
and it does this when ran:
pi@pi400:~ $ g++ wifi-test.cpp -o wifi-test && ./wifi-test
received: OK
received: bssid=d8:0d:17:xxx
freq=5180
id=0
mode=station
pairwise_cipher=CCMP
group_cipher=TKIP
key_mgmt=WPA2-PSK
wpa_state=COMPLETED
ip_address=192.168.2.56
p2p_device_address=42:8e:25:xxx
address=dc:a6:32:xxx
ieee80211ac=1
received: OK
received: <3>CTRL-EVENT-SCAN-STARTED
freq=5180
id=0
mode=station
group_cipher=TKIP
key_mgmt=WPA2-PSK
wpa_state=COMPLETED
ieee80211ac=1
received: FAIL-BUSY
received: <3>CTRL-EVENT-BSS-ADDED 49 f8:ab:05:xxx
received: <3>CTRL-EVENT-SCAN-RESULTS
received: bssid / frequency / signal level / flags / ssid
d8:0d:17:xxx       5180    -41     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       TP-LINK_Extender_5GHz
d8:0d:17:xxx       2457    -76     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       TP-LINK_Extender_2.4GHz
pi@pi400:~ $
after the initial connection, it sends ATTACH, and the server responds with OK
it then sends STATUS and SCAN
the server responds immediately with the current status, and then a short while later with SCAN-RESULTS
so it fires off a scan_results command to query it all, and then exits
all thats missing, is code to parse the reply out of a char* and give you want you need
dsyleixa123
Sun May 09, 2021 6:24 pm
thank you, it compiles and runs, printing lots of things, not sure how to get the abitrary infos I want to store though, tbh...
dsyleixa123
Mon May 10, 2021 12:02 pm
hmmm, I don't get it, it prints things out, but where are they stored?
And which are the single lines to retrieve and store values from that, e.g.
string wifi_localIP: detect e.g. "192.168.2.108"
string wifi_SSID: detect e.g. "WLAN-1234567890"
string wifi_gatewayIP: detect e.g. "192.168.2.1"
int wifi_RSSI: detect e.g. 70 //(0...100)
and how to get the list of all available WiFi networks to choose one from for a re-connection?
how would one program that list by an array of strings, probably dynamically?
(as stated, I want these data for further processing in my program, not just a print-out)
dsyleixa123
Tue May 11, 2021 5:47 pm
any hints by anyone? I don't see how to retrieve and store the required WiFi values in (local arbitrary) program variables
cleverca22
Tue May 11, 2021 6:07 pm
that gets into the subject of parsing a string into multiple pieces, which ive not done very much of
youll need to look into things like scanf or flex/bison i'm guessing
dsyleixa123
Tue May 11, 2021 7:06 pm
yes, ok, but where is the entire string of all and everything to parse? I don't see a
string wifi_allandeverything; :?
cleverca22
Tue May 11, 2021 7:12 pm
freq=5180
id=0
mode=station
group_cipher=TKIP
key_mgmt=WPA2-PSK
wpa_state=COMPLETED
ieee80211ac=1
in one of the passes of the loop, the buffer string contains all of this
dsyleixa123
Tue May 11, 2021 7:15 pm
mhmmm, and what is the function out() for? I assumed this was it which does the print out (admittedly I don't understand anything of all that nested and obfuscated code... ;-) )
PS,
and there are just 2 things I can identify:
where is the IP of the router,
where is/are the RSSI,
and where are all the rest of all optional available networks (routers? gateways? access points?)
ssidNum= n(?)
ssid[1]= ? RSSI[1]=?
ssid[2]= ? RSSI[2]=?
ssid[3]= ? RSSI[3]=?
ssid[4]= ? RSSI[4]=?
ssid[n]= ? RSSI[n]=?
(so that I can sort the ssids by their RRSis)
Tue May 11, 2021 7:37 pm
that gets into the subject of parsing a string into multiple pieces, which I've not done very much of ...
For most bang for your buck have a look at Perl compatible regular expressions (PCRE). If you can get the regex right the parsing becomes trivial.
I've had loads of fun playing with those pieces.
This is a rather crude example
#include <pcre.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
int main (int arcg, char* argv[])
        pcre *regComp;
        pcre_extra *pcreExtra;
        int pcreExecRet;
        int subStrVec[30];
        const char* pcreErrorStr;
        int pcreErrorOffset;
        char* aStrRegex;
        char** aLineToMatch;
        const char* psubStrMatchStr;
        int j;
        char* testString[] = {
                "HTTP/1.1 401 Unauthorized (ASN:s6.myenergi.net) (SN:10008888)\r\n",
                "server: cloudflare\r\n",
                "X_MYENERGI-asn: s6.myenergi.net\r\n",
                NULL};
        aStrRegex = "x_myenergi-asn: (.*.myenergi.net)";
        regComp = pcre_compile(aStrRegex, PCRE_CASELESS, &pcreErrorStr, &pcreErrorOffset, NULL);
        if (regComp == NULL)
                printf("Error: %s %s\n", aStrRegex, pcreErrorStr);
                exit(1);
        pcreExtra = pcre_study(regComp, 0, &pcreErrorStr);
        if (pcreErrorStr != NULL)
                printf("Study: %s %s\n", aStrRegex, pcreErrorStr);
                exit(1);
        for (aLineToMatch=testString; *aLineToMatch != NULL; aLineToMatch++)
                printf("String: %s\n", *aLineToMatch);
                printf("        ----+----1----+----2----+----3----+----4----+----5\n");
                pcreExecRet = pcre_exec(regComp, pcreExtra, *aLineToMatch,
                        strlen(*aLineToMatch), 0, 0, subStrVec, 30);
                if (pcreExecRet > 0)
                        printf("Matched\n");
                        for (j=0; j<pcreExecRet; j++)
                                pcre_get_substring(*aLineToMatch, subStrVec, pcreExecRet, j, &(psubStrMatchStr));
                                printf("Match (%2d/%2d): (%2d, %2d): %s\n", j, pcreExecRet-1, subStrVec[j*2],
                                               subStrVec[j*2+1], psubStrMatchStr);
                else if (pcreExecRet < 0)
                        switch(pcreExecRet)
                                case PCRE_ERROR_NOMATCH : printf("No match\n"); break;
                                case PCRE_ERROR_NULL : printf("Null\n"); break;
                                case PCRE_ERROR_BADOPTION : printf("Bad opt\n"); break;
                                case PCRE_ERROR_BADMAGIC : printf("Voodoo\n"); break;
                                case PCRE_ERROR_UNKNOWN_NODE : printf("Something kooky\n"); break;
                                case PCRE_ERROR_NOMEMORY : printf("Oom\n"); break;
                                default : printf("Very bad\n"); break;
                else
                        printf("No error, but no match");
                printf("\n");
        pcre_free(regComp);
        if (pcreExtra != NULL)
#ifdef PCRE_CONFIG_JIT
                pcre_free_study(pcreExtra);
#else
                pcre_free(pcreExtra);
#endif
        return 0;
I'm looking for a string in the headers returned from a website (for my car charger).
Here's a redacted sample of the full set if headers that come back.
Date: Sun, 09 May 2021 19:07:59 GMT
Transfer-Encoding: chunked
Connection: keep-alive
Set-Cookie: __cfduid=<redacted>; expires=Tue, 08-Jun-21 19:07:58 GMT; path=/; domain=.myenergi.net; HttpOnly; SameSite=Lax
WWW-Authenticate: Digest realm="MyEnergi Telemetry",qop="auth",nonce="<redacted>",opaque="000000100000000100000000f72ea42300007b69b27acf1fc135f0f4cf9bdf3f93460e8f72bd797786e87676196d728f",Stale="false",algorithm="MD5"
CF-Cache-Status: DYNAMIC
cf-request-id: 09f4208a2c0000dc37aa8c9000000001
Report-To: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report?s=<redacted>"}],"group":"cf-nel","max_age":604800}
NEL: {"report_to":"cf-nel","max_age":604800}
Server: cloudflare
CF-RAY: 64cd36bd1e42dc37-LHR
alt-svc: h3-27=":443"; ma=86400, h3-28=":443"; ma=86400, h3-29=":443"; ma=86400
HTTP/1.1 401 Unauthorized (ASN:s6.myenergi.net) (SN:redacted)
Set-Cookie: __cfduid=<redacted>; expires=Tue, 08-Jun-21 19:07:59 GMT; path=/; domain=.myenergi.net; HttpOnly; SameSite=Lax
WWW-Authenticate: Digest realm="MyEnergi Telemetry",qop="auth",nonce="<redcated>",opaque="000000100000000100000000f72ea42300007b69b27acf1fc135f0f4cf9bdf3f93460e8f72bd797786e87676196d728f",Stale="false",algorithm="MD5"
cf-request-id: 09f4208ac10000dc37008f2000000001
Server: cloudflare
CF-RAY: 64cd36be0fbddc37-LHR
cleverca22
Tue May 11, 2021 7:38 pm
mhmmm, and what is the function out() for? I assumed this was it which does the print out (admittedly I don't understand anything of all that nested and obfuscated code... )
the send() function needs the length of a the thing to send
writing send(fd,"foo",strlen("foo")); makes the code messy, and opens you to mistakes
so i made a function to handle that for me
PS,
thats the ssid i'm currently connected to, and the ip of my pi400
thats further down in the example i pasted:
dsyleixa123
Tue May 11, 2021 7:55 pm
aha, I slowly see... but then I still have no idea how to extract all the details and store them to my arbitrary program variables, tbh.
I'm afraid I have to give up, too much awkward code and stuff... (In Arduino API I have WiFi (Wifi101, esp WiFi) classes for all that)
swampdog
Wed May 12, 2021 10:29 am
I think you may have reached the stage where lack of generic tools is holding you back.
This little snippet I plugged into my basic app structure..
static sdRet
avBar(sdArg1 ds,sdArg2 so)
{const sdSiz    dsn     (sdArgs::ArgIdx(ds,so));
 if (!sdSizeOk(ds,dsn))
        throw sde_App("[wlan0]")
 sdConStr       csi,
                cso;
 csi.push_back("sudo iwlist "+ds[dsn]+" scan");
// sdScript(csi,&cso,true);
sdFileLoad(&cso,"/wrk/zz");
 sdStanza       stz     (cso,"[[:space:]]Cell[[:space:]]");
 sdSiz          b,e;
 while (stz.Next(&b,&e))        {
        sdConStr        cs;
        sdVar           v;
        csi.clear();
        std::copy(
                cso.begin()+b,cso.begin()+e,
                std::back_inserter(csi)
        sdStrTok(&cs,csi[0],sdSpc());
        v["Cell"] = cs[1];
        v["Mac"] = cs[4];
        cs.clear();
        sdStrTok(&cs,csi[5],":");
        v["ESSID"] = cs[1];
v.Dump();sdLog()<<'\n';
 return sdMaxSiz();
..which is, if you've got well tested stuff to call upon, demonstrating it is possible to slap code together and concentrate on the problem in hand. The output from the above..
foo@pi20:~/usr/src/junk $ ./go run --bar wlan0
[0]Cell=01
[1]ESSID="ook!"
[2]Mac=E8:DE:27:E9:83:EA
[0]Cell=02
[1]ESSID="eek"
[2]Mac=C8:3A:35:F4:97:40
[0]Cell=03
[1]ESSID="HP-Print-89-LaserJet 200 color"
[2]Mac=48:5A:B6:6A:DD:89
[0]Cell=04
[1]ESSID="VM7506420"
[2]Mac=E4:57:40:44:88:5C
[0]Cell=05
[1]ESSID="sdtab"
[2]Mac=B8:27:EB:2E:17:90
[0]Cell=06
[2]Mac=E4:57:40:44:88:5D
Note I soon got bored of running sdScript() so dumped it's output (sudo iwlist wlan0 scan >/wrk/zz) and worked with /wrk/zz from there. Also stops the output changing and we can go back later to cater for "iwlist" not always returning what we want.
  • sdScript(csi,&cso,true) creates an on-the-fly script and in this case redirects stdout/stderr to a tempfile which it then loads into 'cso'. sdConStr is a container of strings (eg: deque<string>).
    sdStanza uses a regex to split the output into chunks, in this case the line with "Cell" in it. We can come back to that regex later and write it properly.
    the while loop gets indices of where each stanza starts/ends, basically each one starts with "Cell" and contains all the junk up to the next "Cell" or "eof". We reuse 'csi' because we don't need its contents any more.
    sdStrTok(&out,inp,tok) splits string 'inp' into an array 'out' using 'tok' as the delimiter. We need to come back to this because we're using fixed indices and it will crash at some point. Should have used sdRegex but the meaning this way is clearer.
    sdVar is map<string,string> which is likely obvious to others because the output isn't in the same order in which I set the variables. v.Dump() is a -DDEBUG only method but suffices here.
    the function declaration itself can be ignored. It's a callback function for sdArgs (argc/argv processor).
You don't have to write it all yourself like I did but it is educational. :-)
Return to “C/C++”
