RaspbianUser1
[solved]Reading command inputted
Thu May 06, 2021 7:51 pm
Hi, I am having some issue programming and need some help.
My problem is, I want to read the command inputted E.G. ./a.out hello world
I would to then remove the a.out and just have it print
hello world
so far, the furthest I have got is ./a.outhelloworld
Thanks for any help
Last edited by RaspbianUser1 on Thu May 06, 2021 10:26 pm, edited 1 time in total.
Running with a Raspberry Pi 4B 4GB with Raspberry Pi OS with MATE Desktop
Why not overclock, push some more performance out of your computer!
Think before you delete something a stranger on the internet told you to.
jimbox51
Re: Reading command inputted
Thu May 06, 2021 8:25 pm
hello world
Thanks for any help
It would be helpfull to show your code.
Try this ref. and the simple program shown there...
https://www.cprogrammingbasics.com/argv-and-argc/
But any simple C tutorial would conver this topic.
RaspbianUser1
Thu May 06, 2021 8:28 pm
Well actually I did get that far, all I need is the ability to put spaces between the words from argv and ignore argc[0] and just print the rest
GlowInTheDark
Thu May 06, 2021 8:52 pm
for (int i=1; i<argc; i++)
    printf("%s%s",argv[i],i+1 == argc ? "\n" : " ");
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Loves Linux; loves to dance.
manu2007
Thu May 06, 2021 8:56 pm
This should work :
#include <stdio.h>
int main(int argc, char **argv)
    printf("Total number of command Line Agrguments = %d \n", argc);
    for (int i = 1; i < argc; ++i)
        printf("i = %d , val = %s\n", i, argv[i]);
    return 0;
RaspbianUser1
Thu May 06, 2021 8:57 pm
@glowinthedark
wow, that works super well
but I don't know how it works, could you please explain it
all I can gather is the for line starts at 1 to eliminate the first word (or is that wrong :oops: )
Thanks a lot for the code
RaspbianUser1
Thu May 06, 2021 8:59 pm
This should work :
#include <stdio.h>
    return 0;
I had found that code or similar on stack, however it didn't answer my question on how to turn it into a full sentence
GlowInTheDark
Thu May 06, 2021 9:13 pm
Yeah, argv[0] is the command name, the rest of the args start at argv[1].
And, of course, the other part of the trick is that you print out each arg followed by another string. That "another" string is a space for all but the last arg, and is a newline for the last one (where i is exactly one less than argc).
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
RaspbianUser1
Thu May 06, 2021 9:23 pm
How can I get this data into a variable?
I haven't done any c in a while an have got really sloppy
I need it in a variable so I can run something like
system(output);
GlowInTheDark
Thu May 06, 2021 10:10 pm
Well, the obvious answer is: It is already in a variable. The name of the variable is argv.
But, it sounds like what you really need is to concatenate them together into a single string.
One way would be:
char buff[1000];
*buff = 0;
    strcat(strcat(buff,argv[i])," ");
buff[strlen(buff) - 1] = '\0';
Note that this is not as efficient as it could be, but I erred on the side of keeping it as simple as possible.
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
RaspbianUser1
Thu May 06, 2021 10:21 pm
precisely what I wanted, perfect!
and also compared to that 2 liner before, this is a lot more intuitive
however what does this do
without it the code still works and makes no difference, however I should know what it does incase
RaspbianUser1
Thu May 06, 2021 10:22 pm
Nevermind, I looked at it and realised that it removed the last space
Re: [solved]Reading command inputted
Fri May 07, 2021 5:00 am
Please note that GlowInTheDark's solution is buggy.
Consider what happens when the user inputs long strings. Or a lot of arguments. That for loop will happily fill up the 1000 character buffer and continue past the end of it, writing into memory it should not be writing into.
This is known as "undefined behaviour" in C. Your program is trying to work outside the specification of the C language. These kind of bugs may not show up, you program may just work by chance. They may show up when your program gets bigger and cause you a lot of head scratching. The best outcome would be if they immediately crashed your program. They have been the cause of countless security problems over the decades.
Use of strcat and similar functions, strcpy etc, is not recommended. At least use the length limit versions strncat etc. Or at least add some code to verify that buffer overflow cannot occur.
See: https://c-for-dummies.com/blog/?p=2801
GlowInTheDark
Fri May 07, 2021 5:32 am
It's not "buggy". It is, as the comment indicates, not the most efficient (or the most "safe") way to do it, but doing it in full generality is beyond the scope of a posting to a public forum. Adding the code necessary to ensure that the we don't write past the end of the buffer is not particularly difficult, but is beyond the scope.
A "safe" way to do it would be to use C++ and the built-in "string" package.
Or to use my (or anyone else's) "safe string" package - but again, beyond the scope of this posting.
Sheesh!
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
dsyleixa123
Fri May 07, 2021 8:59 am
safe enough if one donates a ~64k buff size
char buff[65000];
that should fit for general purposes ;-)
RaspbianUser1
Fri May 07, 2021 10:33 am
Does one normally enter commands that long, I think my longest was probably 50 characters
GlowInTheDark
Fri May 07, 2021 1:27 pm
In order to see things the way, that one poster (on this very thread) chose to see things, you have to assume a truly malicious user - who knows how big you made the buffer and is willing to type in enough characters to overflow that buffer. The point is that, on this assumption, you can never make it big enough - even if you make it many gigabytes, he (the malicious user) could type in enough to break it. But note also, that in order to actually do any damage, he'd have to know exactly which bytes to type in (what bytes of machine code to put in and exactly where they will land). It's all very theoretical, but I guess it actually has happened once or twice in recorded history. (See: The Morris Worm - c. 1986).
Anyway, here's another way to do it (this time I am giving the full, tested, compilable program; I'm sure this may cause some readers to get a little, shall we say, heated...):
#include <stdio.h>
#include <assert.h>
    assert(argc > 1);
    for (int i=2; i < argc; i++)
	* (argv[i] - 1) = ' ';
    puts(argv[1]);
Also, I forget now what the overall goal of the project was. ISTR that it may have been just to execute the passed args as a sub-process - sort of like the "time" utility does - you pass it a command line and it executes that command line. In that case, you don't really need to concatenate them together at all. You can just pass them as is to one of the exec() functions, like this (after forking if needed):
argv++;
execvp(*argv,argv);
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
jahboater
Fri May 07, 2021 2:00 pm
I agree with Heater, get in the habit of coding defensively - the arithmetic is simple enough here.
Also having the lengths available avoids the grossly inefficient repeated strcat and final strlen.
This version is both safe and fast:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
enum { BUFSIZE=1000 };
int
main( int argc, const char *argv[] )
  char buf[BUFSIZE];
  size_t total_len = 0;
  for( int i = 1; i < argc; ++i )
    const size_t len = strlen(argv[i]);
    if( BUFSIZE - total_len < len + 1 )
      fprintf(stderr, "argument list too long\n");
      exit(EXIT_FAILURE);
    memcpy(buf + total_len, argv[i], len);
    total_len += len;
    buf[total_len++] = ' ';
  buf[total_len] = '\0';
    // use it
  puts(buf);
Fri May 07, 2021 3:24 pm
It's not "buggy".
OK. We can be generous. It's not buggy it's "feature full":
Feature 1) It likely crashes when the input is too big.
Feature 2) If it does not crash it likely causes incorrect results in some other part of the program or crates later when doing something else.
Feature 3) The user has no idea when the first 2 features will be triggered.
Feature 4) For the apparently maximum size input you have in mind, 50 characters, it uses 20 times more memory than needed.
GlowInTheDark wrote: doing it in full generality is beyond the scope of a posting to a public forum. Adding the code necessary to ensure that the we don't write past the end of the buffer is not particularly difficult, but is beyond the scope.
I have no idea where that 50 characters came from. That was not part of the requirement. Anyway it's often easily exceeded. Consider for example using something like this:
./somePprog `ls`
I will agree that one cannot go into too much detail in a mere forum post. However when advising what seems to be a beginner it seems appropriate to indicate the pitfalls of the approach.
GlowInTheDark wrote: Sheesh!
Oh alright. I take it back. That code is buggy.
GlowInTheDark wrote: In order to see things the way, that one poster (on this very thread) chose to see things, you have to assume a truly malicious user - who knows how big you made the buffer and is willing to type in enough characters to overflow that buffer.
It's OK. You can use my name when talking about me.
Anyway that talk of "truly malicious user" is clearly not true. Any user could find it does not work when trying to us it in what they think is a normal way. Failing at random for unknown reasons is generally called a "bug".
GlowInTheDark wrote: The point is that, on this assumption, you can never make it big enough
True. But one can check ones input before processing it. Which is suggested as good practice by most experienced software engineers. One can give useful error messages rather than just crashing.
GlowInTheDark wrote: But note also, that in order to actually do any damage, he'd have to know exactly which bytes to type in (what bytes of machine code to put in and exactly where they will land). It's all very theoretical, but I guess it actually has happened once or twice in recorded history.
This not true on any count.
The bug shows up as a crash, at least, without knowing anything about bytes of machine code or whatever.
Far from theoretical. Such sloppy, unchecked, use of memory, as shown in the example, has been the cause of countless bugs in all kind of software for decades. It has been the root cause of countless security vulnerabilities in all kind of systems. Microsoft has estimated it at 70% of the vulnerabilities in their products: https://msrc-blog.microsoft.com/2019/07 ... cure-code/ Others report similarly.
RaspbianUser1
Fri May 07, 2021 3:32 pm
While I understand the issue, if someone wants to break their machine, they can do it by opening a terminal and running rm / (not actual command obviously)
This code isn’t being used for anything other than removing the first word then running the rest
Its primary purpose is it to remove the $ at the beginning of guide commands
RaspbianUser1
Fri May 07, 2021 3:42 pm
I ended up setting the variable as
char command[4096];
Would you recommend higher?
Fri May 07, 2021 4:59 pm
Very true. Feel free to ignore all advice.
RaspbianUser1 wrote: Would you recommend higher?
Impossible to say. Make it as big as your application requires. Only you know that.
I would recommend checking ones inputs, using "strn..." functions instead of the older "str..." versions. And failing gracefully with a meaningful error message. Nothing more that what is commonly recognised as good practice in the C programming and other programming worlds.
It's up to you.
RaspbianUser1
Fri May 07, 2021 5:10 pm
Well the function of the code is above the quoted reply
What would you set it as, considering it will be running user commands for terminal
dsyleixa123
Fri May 07, 2021 5:14 pm
char command[4096];
if you can hold out accidental (more or less quite unlikely) crashes, take an appropriate value (1000, 4000, 65000, whatever).
My advice: if you want to make more flexible and more failsafe, use std::string (as already had been stated above).
Fri May 07, 2021 5:18 pm
Impossible to say.
What does "running user commands for terminal" mean? That may well include simple things like:
$ ./mu_prog `ls`
Where that `ls` could produce a very long list of very long arguments.
Return to “C/C++”
