Theirchuck
Code error in C
Sun Apr 18, 2021 1:24 pm
Hello guys, trying to run HC SR04 sensor in C language I used http://www.piprojects.xyz/ultrasonic-distance-sensor/ codes on this site but
ultrasonic.c: 50: 2: error: expected identifier or ‘('before‘ return'
return 0;
ultrasonic.c: 51: 1: error: expected identifier or ‘('before‘)' token
I am getting error like this. Can you help me for solution?
and i'm using raspberry pi 3 B +
dsyleixa123
Re: Code error in C
Mon Apr 19, 2021 11:37 am
perhaps the "}" in main() between delay(1000) and return 0 is redundant and has to be deleted...?
        delay(1000);
	return 0;
Re: Code error in C
Mon Apr 19, 2021 12:21 pm
More likely the "}" on the line between the printf and the delay should be removed. It makes little sense otherwise. Like so:
int main(void) {
	setup();
	while (1)
		int dist=getCM();
		printf("Distance: %dcm\n", dist);
		delay(1000);
	return 0;
Re: Code error in C
Mon Apr 19, 2021 12:30 pm
This version works. Note: that I've changed from WiringPi pin numbers to BCM/Broadcom pin numbers (by using wiringPiSetupGpio).
#include <stdio.h>
#include <stdlib.h>
#include <wiringPi.h>
#define TRIG 22
#define ECHO 25
void setup() {
        wiringPiSetupGpio();
        pinMode(TRIG, OUTPUT);
        pinMode(ECHO, INPUT);
        //TRIG pin must start LOW
        digitalWrite(TRIG, LOW);
        delay(30);
int getCM() {
        //Send trig pulse
        digitalWrite(TRIG, HIGH);
        delayMicroseconds(20);
        //Wait for echo start
        while(digitalRead(ECHO) == LOW);
        //Wait for echo end
        long startTime = micros();
        while(digitalRead(ECHO) == HIGH);
        long travelTime = micros() - startTime;
        //Get distance in cm
        int distance = travelTime / 58;
        return distance;
int main(void) {
        setup();
        printf("Distance: %dcm\n", getCM());
        return 0;
I wired the HC-SR04 with Vcc on 5V, GND on GND, trig on pin#22 and echo (with a three 1K resistor voltage divider (cos I couldn't find a 1K & 2.2K resistor)) on pin#25.
https://pinout.xyz/pinout/pin15_gpio22
https://pinout.xyz/pinout/pin22_gpio25
dsyleixa123
Re: Code error in C
Mon Apr 19, 2021 12:39 pm
I agree with Heater, it makes more sense to wait 1s after each reading than just once at the end of the program 8-)
Theirchuck
Re: Code error in C
Wed Apr 21, 2021 10:14 pm
Hello, I tried the code hc sr04 Thanks. I have 2 questions. When I compiled it, I get these errors. Is there a solution to this?
/ usr / bin / ld: /tmp/ccMiXxtK.o: in the `setup 'function:
ultrasonic.c :(. text + 0x8): undefined reference to wiringPiSetupGpio
/ usr / bin / ld: ultrasonic.c :(. text + 0x14): `undefined reference to pinMode
/ usr / bin / ld: ultrasonic.c :(. text + 0x20): `undefined reference to pinMode
/ usr / bin / ld: ultrasonic.c :(. text + 0x2c): undefined reference for `` digitalWrite ''
/ usr / bin / ld: ultrasonic.c :(. text + 0x34): undefined reference to `` delay ''
/ usr / bin / ld: /tmp/ccMiXxtK.o: In function `getCM ':
ultrasonic.c :(. text + 0x54): undefined reference for `` digitalWrite ''
/ usr / bin / ld: ultrasonic.c :(. text + 0x5c): undefined reference for 'delayMicroseconds'
/ usr / bin / ld: ultrasonic.c :(. text + 0x68): undefined reference for `` digitalWrite ''
/ usr / bin / ld: ultrasonic.c :(. text + 0x74): undefined reference for `` digitalRead ''
/ usr / bin / ld: ultrasonic.c :(. text + 0x84): undefined reference to "micros"
/ usr / bin / ld: ultrasonic.c :(. text + 0x98): undefined reference for `` digitalRead ''
/ usr / bin / ld: ultrasonic.c :(. text + 0xa8): undefined reference for `` micros ''
Collect2: error: ld 1 returned exit status
and I need a schematic to build the circuit
Re: Code error in C
Thu Apr 22, 2021 12:52 am
Compile it with
gcc -o ultra -lwiringPi ultrasonic.c
Theirchuck
Re: Code error in C
Thu Apr 22, 2021 6:09 pm
hello thanks for your help, i am using the code compile command worked but when i compiled geany from brick i get the errors i wrote above i guess i need to fix them how can i fix them thanks.
Theirchuck
Re: Code error in C
Thu Apr 22, 2021 6:21 pm
Hello. The codes worked. Thank you. But I have a question. What do I have to do to measure the sensor continuously? I am writing sudo ./ultrasonic for every measurement and it measures. What do I have to do to measure it continuously?
B.Goode
Re: Code error in C
Thu Apr 22, 2021 6:28 pm
I am no C expert, but it seems to me that you need to reinstate the while () { .. } loop that you removed?
Theirchuck
Re: Code error in C
Thu Apr 22, 2021 6:38 pm
Hello, I deleted the first codes I threw. I am using the codes that Dougie Lawson threw now and I cannot measure constantly. I am not good in C language but I have homework I want help for this and by the way thanks for your opinion
B.Goode
Re: Code error in C
Thu Apr 22, 2021 6:50 pm
Just to highlight that -
" I am not good in C language but I have homework "
Most teachers are not monsters. Homework is assigned to help you learn and improve. Or to check how much you might have learnt or improved.
Getting volunteer helpers here to do your homework is not beneficial to you.
Re: Code error in C
I don't like doing your homework for you. My rate is USD$750/day.
Stick
while (1) {
after
setup();
and
delay (10);
before
return 0;
You may need to tweak the time delay, so you get a reading when expected and don't burn the CPU @ 100% busy.
http://wiringpi.com/reference/timing/
Theirchuck
Re: Code error in C
Thu Apr 22, 2021 7:02 pm
Thanks for your help I apologize if I kept you busy
swampdog
Re: Code error in C
Thu Apr 22, 2021 7:54 pm
Here's the three "infinite" loops you can read up on..
#include <stdio.h>
#include <stdlib.h>
int
main()
 do {
	printf("%s\n","dw");
 }while(0);
 while(0)	{
	printf("%s\n","wl");
 for (;;)	{
	printf("%s\n","fl");
	if ('q' == fgetc(stdin))
		break
 return EXIT_SUCCESS;
Re: Code error in C
Fri Apr 23, 2021 2:27 am
#include <stdio.h>
#include <stdlib.h>
int
main()
 do {
 }while(0);
 while(0)	{
 for (;;)	{
		break
That is sneaky of you. "infinite" in quotes because only the last example executes the printf repeatedly forever.
swampdog
Re: Code error in C
Sat Apr 24, 2021 2:53 am
#include <stdio.h>
#include <stdlib.h>
int
main()
 do {
 }while(0);
 while(0)	{
 for (;;)	{
		break
I'd like to take full credit but if I'm honest I was thinking about how to demonstrate three infinite loops concisely without slapping a break in everywhere. I am pleased with the result though! :-)
Re: Code error in C
Sat Apr 24, 2021 8:46 am
I don't understand. Adding "break" to the two non-infinite loops you presented would not make them run forever.
You might also like to write "if" as:
    for ( ; a == b; ) {
        printf("True\n");
        break;
swampdog
Re: Code error in C
Sat Apr 24, 2021 6:52 pm
I know. It wouldn't have helped the OP, probably caused more confusion.
    for ( ; a == b; ) {
        printf("True\n");
        break;
I like that as well. :-)
Re: Code error in C
Sat Apr 24, 2021 8:27 pm
Sounds like you are ready for The International Obfuscated C Code Contest: https://www.ioccc.org/
swampdog
Re: Code error in C
Sat Apr 24, 2021 10:44 pm
That's what I like about our obfuscated code: it isn't. It's easy to read and logical.
Mind you, I was able to write..
"abc"[1]='D'
..in K&R and have that become "aDc". No memory protection!
Return to “C/C++”
