DEUKO
How to make a command?
Fri Jul 12, 2019 5:40 am
Hi? My professors?
I'm just a student who started raspberry pie? I'm currently working on a project through RaspberryPie, and I want to set up a command to run and exit the program.
For example, if you enter a number of 1, the program will run and if you enter a number of 0, you want to turn it off.
But I do not know what to do. And I do not know how to search the material.
If there is any way, please leave a reply.
Thank you.
joan
Re: How to make a command?
Fri Jul 12, 2019 9:14 am
Start here https://projects.raspberrypi.org/en/pro ... y-pi-using and make sure you understand before continuing.
Then perhaps look at https://projects.raspberrypi.org/en/pro ... thon-sushi
Return to “C/C++”
