lianergoist
How do I debug stdin?
Fri Aug 10, 2018 4:14 pm
I hope this kind of question is on-topic here. Else, plese let me know.
I have a problem with the LF character. I have made a little demo to show the problem:
#include <stdlib.h>
#include <stdio.h>
void search_word() {
	char *tmp_string;
	size_t len=50;
	tmp_string = (char *) malloc(len * sizeof(char)+1);
	printf("\nEnter a word: ");
	fflush(stdout);
	fflush(stdin);
	getline(&tmp_string, &len, stdin);
	printf("%s\n", tmp_string);
	free(tmp_string);
int main() {
	int selected;
	while (1) {
		printf("Search another word? (y/n) ");
		fflush(stdout);
		do {
			selected = fgetc(stdin);
		} while (selected == '\n');
		if (selected == 'y') {
			fflush(stdin);
			search_word();
		else if (selected == 'n') {
			break;
		else {
			printf("Hit 'y' or 'n'\n");
	return 0;
When I run the program, it never let me enter a word. I get the following output:
[email protected]:~/c/ooo $ gcc -o test8 -g test8.c
[email protected]:~/c/ooo $ ./test8
Search another word? (y/n) y
Enter a word:
Enter a word:
Search another word? (y/n) n
It *looks* like the LF char is not flushed from stdin and therefore is send to getline().
I have two problems:
1. I don really understand this piece of code:
do {
It is something I found in a book and it should somehow make make the loop ignore the LF, but I don't understand why/how it does it - and it looks like it's not really working...? :-/ Can someone please explain why/how it works? Or maybe just suggest alternative ways to ignore the LF?
2. I have tried to run the code in gdb, but I don't know how I can view/print stdin. How can I see if stdin really is flushed and no LF is waiting?
Thanks...
Thomas Jensen
There are two types of people.
1) Those who can extrapolate from incomplete data
jahboater
Re: How do I debug stdin?
Fri Aug 10, 2018 4:49 pm
I suspect mixing fgetc and getline is confusing things.
Does this do what you want ?
I simplified it a little (there is no need to keep mallocing/freeing the buffer every time).
#include <stdlib.h>
#include <stdio.h>
static char *tmp_string = NULL;
static size_t tmp_len = 50;
  if( getline( &tmp_string, &tmp_len, stdin ) != -1 )
int main() {
  for(;;) {
      const char selected = tmp_string[0];
      if( selected == 'y' )
        search_word();
      else if( selected == 'n' )
        break;
      else
Perhaps take a look at GNU readline().
It is very easy to use and allows command line editing amongst other things.
Fri Aug 10, 2018 6:47 pm
do {
It's a simple do-while loop. It loops until the condition in the while() is not true.
In psuedo-code:
loop_start:
    read character from stdin
if character == "\n" go to loop_start
"\n" is the escape sequence that matches the LF character (0x0a ascii)
lianergoist
Fri Aug 10, 2018 7:25 pm
Thank you for helping me. Yes, it works. It's smart only to read the first char of the string.
I will be back after some testing.... :)
Thomas Jensen
lianergoist
Fri Aug 10, 2018 8:57 pm
In psuedo-code:
loop_start:
Well, I know that much. I think I am a little confused about why it should do what my book said it was supposed to do (jump over the LF character). I have now been running the code in gdb, and I can see the loop does (of course) nothing in my code, so .... I have to studie the code in the book again.
Well, jahboater showed a way to get around the problem with getline not waiting for keyboard input. But, my guess is, it is not waiting because it receives a LF from fgets (???) and think work is done. I would very much like to understand why. How can I test if there is a LF hanging? I use fflush, but that's not working...
If someone can tell me how to view stdin in gdb, I would also very much like to know. I have tried 'print stdin, but it just return this:
(gdb) print stdin
$1 = (struct _IO_FILE *) 0x76f9d640 <_IO_2_1_stdin_>
and I don't know how to get a readable value out of that...
Thomas Jensen
jahboater
Fri Aug 10, 2018 11:38 pm
(gdb) print stdin
stdin is a pointer to a structure.
So try 'print *stdin' and see what that gets you.
The structure is actually defined in /usr/include/libio.h (not /usr/include/stdio.h like it used to be).
look for the line starting with "struct _IO_FILE".
jahboater
Fri Aug 10, 2018 11:39 pm
(gdb) print stdin
Look for the line starting with "struct _IO_FILE". There you will see the details of the structure with comments.
lianergoist
Sat Aug 11, 2018 6:06 am
Well, I *did* know that, so this is a little embarrassing... :roll:
Well, I leaned something today. fflush has no effect on stdin...
(gdb) next
Search another word? (y/n) 36				selected = fgetc(stdin);
(gdb) next
y
37			} while (selected == '\n');
(gdb) p *stdin
$4 = {_flags = -72539512, _IO_read_ptr = 0x22411 "\n",
  _IO_read_end = 0x22412 "", _IO_read_base = 0x22410 "y\n",
  _IO_write_base = 0x22410 "y\n", _IO_write_ptr = 0x22410 "y\n",
  _IO_write_end = 0x22410 "y\n", _IO_buf_base = 0x22410 "y\n",
  _IO_buf_end = 0x22810 "", _IO_save_base = 0x0, _IO_backup_base = 0x0,
  _IO_save_end = 0x0, _markers = 0x0, _chain = 0x0, _fileno = 0, _flags2 = 0,
  _old_offset = -1, _cur_column = 0, _vtable_offset = 0 '\000',
  _shortbuf = "", _lock = 0x76f9e6c4 <_IO_stdfile_0_lock>, _offset = -1,
  __pad1 = 0x0, __pad2 = 0x76f9d6e0 <_IO_wide_data_0>, __pad3 = 0x0,
  __pad4 = 0x0, __pad5 = 0, _mode = -1, _unused2 = '\000' <repeats 39 times>}
(gdb) next
41				fflush(stdin);
(gdb) next
42				search_word();
(gdb) p *stdin
$5 = {_flags = -72539512, _IO_read_ptr = 0x22411 "\n",
(gdb)
Thomas Jensen
jahboater
Sat Aug 11, 2018 6:18 am
Perhaps there is simply no stuff in the buffer waiting to be read.
In which case fflush() would do nothing.
lianergoist
Sat Aug 11, 2018 6:44 am
Perhaps? But isn't it clear there *is* something in the buffer "('y\n"), both before and after fflush? I would expect both _IO_read_end and (for sure) _IO_read_ptr to point to same address as _IO_read_base after fflush.
Thomas Jensen
jahboater
Sat Aug 11, 2018 7:06 am
Good point.
I don't know. Perhaps now is the time to download the source of glibc and look at the code for fflush?
http://ftp.gnu.org/gnu/glibc/
Look for "glibc-2.28.tar.xz" (or .gz)
I tend to just assume this stuff works, its been around for 50 years or so and is in constant use by millions of programs.
lianergoist
Sat Aug 11, 2018 9:21 am
No need for that. A quick google search show tthe behavior of flushing stdin is undefined. See https://www.geeksforgeeks.org/clearing- ... fer-in-cc/
*LOL* Oh yes. Well, I didn't thought I had found a bug in libc... :D
Thomas Jensen
jahboater
Sat Aug 11, 2018 1:17 pm
Quite right - I should have looked at the standard first too :(
C17 says:
Description
2 If stream points to an output stream or an update stream in which the most recent
operation was not input, the fflush function causes any unwritten data for that stream
to be delivered to the host environment to be written to the file; otherwise, the behavior is
undefined.
3 If stream is a null pointer, the fflush function performs this flushing action on all
streams for which the behavior is defined above.
I didn't know you could do "fflush(NULL)" ......
Return to “C/C++”
