J.Bryan
Does anyone have the SPI C code for ADXL345 to share?
Sun Mar 18, 2018 1:57 pm
Does anyone have the SPI C code (using pigpio library or without library) for the ADXL345 sensor to share ? Thank you for any help.
joan
Re: Does anyone have the SPI C code for ADXL345 to share?
Sun Mar 18, 2018 2:22 pm
If you search for "linux C SPI ADXL345" anything you find should work on the Pi. Have you a particular need in mind?
J.Bryan
Sun Mar 18, 2018 3:01 pm
Hi Joan,
I wrote a piece of C code by making a system call to the SPI kernel previously. However, i suspect there is mistake in my code which result in high noise. The purpose of asking for code written in pigpio library or other c code is to test the sensor if it is my code issue or sensor issue. Do you know If there is SPI C code for the ADXL345 written with your pigpio library available to test?
joan
Sun Mar 18, 2018 5:39 pm
Here is some pigpio code using the pigpio SPI driver. All it does is read the raw XYZ data. No maths.
The speed defaults to 2MBps. I think the bottom limit is 40kbps.
gcc -Wall -pthread -o adxl345_spi adxl345_spi.c -lpigpio -lrt
sudo ./adxl345_spi
#include <stdio.h>
#include <stdlib.h>
#include <pigpio.h>
#define LOOPS 500000
#define READ_BIT  0x80
#define MULTI_BIT 0x40
#define BW_RATE     0x2C
#define POWER_CTL   0x2D
#define DATA_FORMAT 0x31
#define DATAX0      0x32
int readBytes(int handle, char *data, int count)
   data[0] |= READ_BIT;
   if (count > 1) data[0] |= MULTI_BIT;
   return spiXfer(handle, data, data, count);
int writeBytes(int handle, char *data, int count)
   return spiWrite(handle, data, count);
int main(int argc, char *argv[])
   int h;
   char data[7];
   int16_t x, y, z, lx, ly, lz;
   int i;
   int bytes;
   double start, duration;
   if (gpioInitialise() < 0) return 1;
   h = spiOpen(0, 2000000, 3);
   data[0] = BW_RATE;
   data[1] = 0x0F;
   writeBytes(h, data, 2);
   data[0] = DATA_FORMAT;
   data[1] = 0x01;
   data[0] = POWER_CTL;
   data[1] = 0x08;
   lx = 0;
   ly = 0;
   lz = 0;
   start = time_time();
   for (i=0; i<LOOPS; i++)
      data[0] = DATAX0;
      bytes = readBytes(h, data, 7);
      if (bytes == 7)
         x = (data[2]<<8)|data[1];
         y = (data[4]<<8)|data[3];
         z = (data[6]<<8)|data[5];
         if ((abs(x-lx) > 30) || (abs(y-ly) > 30) || (abs(z-lz) > 30))
            printf("x=%d y=%d z=%d\n", x, y, z);
            lx = x;
            ly = y;
            lz = z;
      else printf("spiXfer error (%d)\n", bytes);
   duration = time_time() - start;
   gpioTerminate();
   printf("%d loops in %.2f seconds (%.1f sps)\n",
      LOOPS, duration, LOOPS/duration);
J.Bryan
Tue Mar 20, 2018 1:10 pm
sudo ./adxl345_spi
#include <stdio.h>
#include <stdlib.h>
#include <pigpio.h>
#define DATAX0      0x32
   int h;
   char data[7];
   int i;
   int bytes;
   data[0] = BW_RATE;
   data[1] = 0x0F;
   data[1] = 0x01;
   data[1] = 0x08;
   lx = 0;
   ly = 0;
   lz = 0;
      data[0] = DATAX0;
      if (bytes == 7)
            lx = x;
            ly = y;
            lz = z;
   gpioTerminate();
Dear Joan,
Thank you for this piece of code. I modified it based on the frequency and bits i set in my actual application. I would need your help to look at the data I logged. There is alot of fluctuation. Do you know what is wrong, is it my sensor issue? I am using Raspian with kernel version 4.9.35-v7+. I have been purged with this problem for quite some time even with my own SPI program and I think it is really affecting my robot. Thank you for any suggestion.
sudo ./adxl345_spi
#include <stdio.h>
#include <stdlib.h>
#include <pigpio.h>
#define DATAX0      0x32
   int h;
   char data[7];
   int i;
   int bytes;
   h = spiOpen(1, 5000000, 3);
   data[0] = BW_RATE;
   data[1] = 0x0F;
   data[1] = 0x0B;
   data[1] = 0x08;
   lx = 0;
   ly = 0;
   lz = 0;
      data[0] = DATAX0;
      if (bytes == 7)
            lx = x;
            ly = y;
            lz = z;
   gpioTerminate();
	return 0;
Here is the data I logged. The data is recorded on the floor and the sensor is stationary
https://drive.google.com/open?id=1bQL7s ... VqpkNFHTP5
joan
Tue Mar 20, 2018 4:06 pm
I have no idea if they are normal readings or not. All I ever do is turn the device through various orientations and check the output looks reasonable.
J.Bryan
Tue Mar 20, 2018 5:38 pm
Hi Joan,
Do you have the same sensor lying around? If you have, is it okay if you show me the output using the updated code that I posted?
I am not really sure if it is normal to read this kind of data. I always have the impression that x and y axis should be around 0 and z should be around 256 when the sensor is flat on the ground. But from my sensor's output, i am not getting it. I really appreiate if anyone else can weight in on this matter. I been trying to fix this issue for weeks but is unsure if it is normal or just something wrong with the sensor.
joan
Thu Mar 22, 2018 8:53 pm
I don't get anything at all with your modified code. When I use 5MBps and a data format of 0x01 all looks okay.
J.Bryan
Fri Mar 23, 2018 5:59 pm
Okay, but kind of weird you should be able to read something from the modified code. I did not change much of your code. The only thing i changed is the data format, SPI clock rate and i am using Chip Enable 1.
joan
Fri Mar 23, 2018 6:12 pm
That explains why I got no readings. I did not notice the chip enable change. I'll try again.
joan
Fri Mar 23, 2018 7:20 pm
The results look fine to me. I logged all readings, not just those more than 30 different to the previous reading. A plot each for X, Y, and Z.
J.Bryan
Fri Mar 23, 2018 7:32 pm
Hi Joan,
Is your readings done without this sentence of code?
I am not getting the same plot as you get. I am getting alot of noise, i will test it again and show you my result.
joan
Fri Mar 23, 2018 8:41 pm
Yes, I replaced the if statement with the unconditional printf("%d %d %d\n", x, y, z);
I then used gnuplot to plot part of the log for each axis.
plot [50000:90000][-250:250]'adxl345.log' using 1 # X
plot [50000:90000][-250:250]'adxl345.log' using 2 # Y
plot [50000:90000][0:500]'adxl345.log' using 3 # Z
J.Bryan
Sat Mar 24, 2018 7:01 pm
Hi Joan,
I would like your guidance on how to use the piscope to view the data on the SPI bus. Is it possible to do a simple view of the device ID and signal?
joan
Sat Mar 24, 2018 7:58 pm
To see the signals on piscope you would have to drop the speed to something around 70kbps or less to make sure all the edges are captured.
I haven't used it for a while but http://abyz.me.uk/rpi/pigpio/examples.h ... SPI_mon_py may be a simpler alternative.
CFLanger
Mon Apr 09, 2018 3:28 pm
when you get data coming out you have to calibrate it.
https://youtu.be/AHj_KB260eM
CFLanger
Senior Software Engineer at
www.ljtechnologies.com
Return to “C/C++”
