comeng18
(Solved) I2c device not found (MPU6050)
Sat Jan 13, 2018 6:58 pm
Hello
I work to use MPU6050. I'm using this library https://github.com/richardghirst/PiBits ... 50-Pi-Demo but it says " Failed to open device: No such file or directory" but ı scan ı2c device ı look it in 0x68 . I worked very much for solving this problem but ı didn't it.
I updated this code. It is work
https://github.com/Comeng18/MPU6050
fivdi
Re: I2c device not found (MPU6050)
Sat Jan 13, 2018 7:38 pm
The code linked to was written quite a long time ago and looks like it was implemented for a Raspberry Pi 1. The code assumes that the I2C bus can be accessed using /dev/i2c-0. On a more recent Pi like the Zero, 2 or 3 this is not the case and /dev/i2c-1 should be used.
For example, see
https://github.com/richardghirst/PiBits ... v.cpp#L175
https://github.com/richardghirst/PiBits ... v.cpp#L347
https://github.com/richardghirst/PiBits ... v.cpp#L394
If this code is updated to use /dev/i2c-1 rather than /dev/i2c-0 it may work.
comeng18
Mon Jan 15, 2018 3:27 pm
For example, see
Thank you so much. I updated this code. It is work
Return to “C/C++”
Who is online
Users browsing this forum: No registered users and 12 guests
