J.Bryan
Hardware PWM Pin 32 and Pin 33 Question
Fri Jan 12, 2018 1:40 pm
Dear All,
I am trying to use the pigpio library to generate PWM signal on the Hardware PWM Pin 32 and 33 of the Raspberry Pi GPIO header.
I was referring to this thread:
viewtopic.php?f=33&t=179438
I saw that it can be done using:
gpioHardwarePWM(12, 5000, 500000);
gpioHardwarePWM(13, 10000, 100000);
I would like to check do I need to set the pin to use "Alternate function" or is it already done by the function "gpioHardwarePWM"?
I referred to the documentation but is not really understanding how "gpioHardwarePWM" function work.
The function header is listed as:
int gpioHardwarePWM(unsigned gpio, unsigned PWMfreq, unsigned PWMduty)
Does "PWMfreq" refers to the maximum frequency of the connected device? I am looking at the L298N motor board and would like to control the Speed of the connected DC Motor. For the "PWMduty", is the range always at 0 to 1000000 regardless of the "PWMfreq"?
Am I correct to assume that 1000000 refers to 100% duty cycle. So if I want a 70% duty cycle I can set e.g pin 32 to 700000 example:
gpioHardwarePWM(12, 10000, 700000);
gpioHardwarePWM(13, 10000, 700000);
If I am wrong, may I get some reference to a working example piece of c code that controls Motor Speed with the Hardware PWM pin?
Thanks for your help.
joan
Re: Hardware PWM Pin 32 and Pin 33 Question
Fri Jan 12, 2018 1:48 pm
Your assumptions are correct. The function will set the GPIO to the correct mode. The duty cycle is out of one million, so 500 thousand will be 50%. The frequency is the PWM frequency you want. Mostly frequency is not critical for DC motor control. Anything around 1000 should be fine.
mattmiller
Fri Jan 12, 2018 1:54 pm
My personal experience with using motors on robots is that you seem to loose a lot of torque at high frequencies
My default value is 50Hz
I go as low as 10Hz when trying to move robot motors very slowly in order to get them to turn at all
J.Bryan
Fri Jan 12, 2018 2:05 pm
Hi Joan,
Thanks for your reply! I'm not really getting on how to select the value for the frequency. From the datasheet, I saw that the maximum frequency of the l298n is 40KHz. Does it mean that it is okay to set the frequency to be any frequency below 40KHz? I understand theoretically there is difference in the time between setting 1KHz or 25KHz but not really sure how the selected frequency value will affect my application?
For most Arduino delicated motor shield board, there is a way to set the speed of the motor e.g -400 to 400. Am I achieving similar effect by varying the duty cycle?
I am sorry for the novice question.
Thanks for your help!
1dot0
Fri Jan 12, 2018 2:19 pm
I am using DC motors by pwm frequencies from about 1kHz up to 25 kHz - all are fine.
Admittedly, for lower frequencies there might be increasingly audible beeps occuring.
On the Pi I used soft pwm generated by wiringPi, additionally I am using add-on shields which have built-in AVR or ARM cpus, no issues about either one.
joan
Fri Jan 12, 2018 2:37 pm
@J.Bryan Use the duty cycle to vary the speed. Think of the duty cycle as setting the voltage between 0 and maximum. The Arduino interface seems to be setting the direction as well as speed.
joan
Fri Jan 12, 2018 2:44 pm
I only have limited experience of PWM with a few motor driver boards / motors. I think Arduino defaults to something like 500Hz which is partly why pigpio defaults to 800Hz.
1dot0
Fri Jan 12, 2018 3:39 pm
Most Arduino pwm outputs are set to about 490Hz or 980Hz by default. The frequencies are generated as a result of the clock frequency being divided by a pre-scaler. One may also set the pre-scaler arbitrarily. Note that "Arduino" may relate to AVR cpus at 8-16MHz and ARM cpus from 48-84 MHz (and perhaps even Intel cpus).
joan
Fri Jan 12, 2018 3:51 pm
Most Arduino pwm outputs are set to about 490Hz or 980Hz by default. The frequencies are generated as a result of the clock frequency being divided by a pre-scaler. One may also set the pre-scaler arbitrarily. Note that "Arduino" may relate to AVR cpus at 8-16MHz and ARM cpus from 48-84 MHz.
Thanks. The Arduino experience suggests that those values are reasonable for a lot of uses.
J.Bryan
Thu Jan 18, 2018 10:23 am
Hi Joan,
I followed the suggestion for the frequency value, (mainly 10hz, 50hz,1000hz, 25000 hz) and all of it work fine with my dc motors.
I set it to 10Hz in the end for both the hardware PWM Pin.
I am trying to count the pulse of the encoder and I followed the other thread which you had answered.
viewtopic.php?f=33&t=71295
I was looking at the gpioSetAlertFunc from the documentation:
int gpioSetAlertFunc(unsigned user_gpio, gpioAlertFunc_t f)
In your documentation, you mentioned that
The alert may be cancelled by passing NULL as the function.
The GPIO are sampled at a rate set when the library is started.
If a value isn't specifically set the default of 5 us is used.
The number of samples per second is given in the following table.
I would like to ask, will the "gpioSetAlertFunc " function affect or change the 10Hz frequency which I had set for the hardware PWM pin?
Thank You!
joan
Thu Jan 18, 2018 11:23 am
No, PWM is completely separate from sampling.
For usage of gpioSetAlertFunc perhaps look at the following example.
http://abyz.me.uk/rpi/pigpio/ex_rotary_encoder.html
J.Bryan
Thu Jan 18, 2018 2:30 pm
Hi Joan,
I am not really understanding if i need to setup the pull up resistor.
One of the motor I intend to use is https://www.pololu.com/product/1446.
I would like to get some advice whether I need to setup the pull up resistor.
I am mainly interested in the following 2 output.
Yellow	encoder A output
White	encoder B outpu
joan
Thu Jan 18, 2018 2:50 pm
I can't be sure.
All the encoder A/B lines I've used float to the external voltage except when pulled to ground during the rotation. So yes, normally you need to enable the GPIO pull-ups to pull the A/B lines high.
J.Bryan
Thu Jan 18, 2018 3:26 pm
I can't be sure.
Noted with thanks. I would also like to check with you, will I get the correct voltage reading when I read a PWM signal using a DMM? Or is it better to use a oscilloscope.
joan
Thu Jan 18, 2018 4:40 pm
If you turn the encoder slowly you should be able to see the lines going high and low with a meter.
J.Bryan
Sat Jan 20, 2018 6:20 pm
Hi Joan for the rotary encoder example.
Is it okay if i do not include the debounce code, I am not really sure what it does? I want very accurate count for every pulse so I would like to remove the debounce code. Is the default value for "level" equal to 1? I have 4 pins, and I would like to set up 4 gpioSetAlertFunc.
Example:
   gpioSetAlertFunc(L_ENCODER_A, L_encoderPulse);
   gpioSetAlertFunc(L_ENCODER_B, L_encoderPulse);
   gpioSetAlertFunc(R_ENCODER_A, R_encoderPulse);
   gpioSetAlertFunc(R_ENCODER_B, R_encoderPulse);
void  L_encoderPulse(int gpio, int level, uint32_t tick)
   static int levA=0, levB=0;
   if (gpio == L_ENCODER_A) levA = level; else levB = level;
      if ((gpio ==  L_ENCODER_A) && (level == 0))
         if (!levB) ++L_encoderPos;
      else if ((gpio ==  L_ENCODER_B) && (level == 1))
         if (levA) --L_encoderPos;
void  R_encoderPulse(int gpio, int level, uint32_t tick)
   if (gpio == R_ENCODER_A) levA = level; else levB = level;
      if ((gpio ==  R_ENCODER_A) && (level == 0))
         if (!levB) ++R_encoderPos;
      else if ((gpio ==  R_ENCODER_B) && (level == 1))
         if (levA) --R_encoderPos;
Thanks. :)
Return to “C/C++”
Who is online
Users browsing this forum: No registered users and 12 guests
