R-A
how to post data to URL?
Sun Oct 01, 2017 6:34 pm
I wonder if someone can help me?
I found some code on the internet (github) to read values from my solar inverter, but it's written in C. And I don't know C, but rather some PHP and Python.
So I want to modify the script to upload the values to http://www.emoncms.com either a GET or POST request. Their API supports the following format:
GET: https://emoncms.org/input/post?node=emo ... xxxxxxxxxx
POST: curl --data "node=1&data={power1:100,power2:200,power3:300}&apikey=xxxxxxxxxxxxxxxx" "https://emoncms.org/input/post"
API samples: https://emoncms.org/site/api#input
I can do this in Python, as follows:
     r = requests.get("https://emoncms.org/input/post.json?node=1&json={Bedroom1Roof:" + str(myTempBed1Roof) + "}&apikey=" + APIKEY)
#      print(r.url)
#      r.status_code == requests.codes.ok
#      print(r.status_code)
"str(myTempBed1Roof)" is a variable string which I get from a DS18B20 temp sensor.
But, as I said, the current script is written in C, and I don't know how to accomplish this. Nor do I know how to re-write this code in Python.
Any help would be highly appreciated. I have searched the forums but the code I found is all for Python.
I'm using a Raspberry Pi 3 Model B with 7" LCD Touch screen and Mini USB Wireless Keyboard
R-A
Re: how to post data to URL?
Wed Oct 04, 2017 8:45 pm
Any help with this would be highly appreciated
ghans
Wed Oct 04, 2017 10:08 pm
Use subprocess.Popen() to execute the C program and read its output.
ghans
6by9
Thu Oct 05, 2017 8:39 am
Post a link to the C code and someone may be helpful enough to do at least a cursory conversion to Python, or at least give some guidance as to what the C is doing and how you might replicate it in Python.
Please don't send PMs asking for support - use the forum.
R-A
Fri Oct 06, 2017 7:26 pm
I didn't write the code, so I didn't think I could post the URL, but it's on github.com/manio/skymax-demo
The important piece of code is on https://github.com/manio/skymax-demo/bl ... r/main.cpp
c++ is a bit difficult for me to understand, though I understand and can code some (limited) Python.
ghans
Sat Oct 07, 2017 12:49 pm
Why don't install that piece of software and play around a bit. This is what the Pi is about , after all.
sudo apt-get update
sudo apt-get install cmake
git clone git://github.com/manio/skymax-demo.git
cd skymax-demo
mkdir out
cd out
cmake ..
make
(instructions copied nearly verbatim from the github page)
ghans
R-A
Wed Oct 25, 2017 6:59 am
sudo apt-get update
cd skymax-demo
mkdir out
cd out
cmake ..
make
ghans
Why don't you re-read my question? I HAVE installed that script, but I want to MODIFY it to post data to Emoncms. And I don't know how to code C++
topguy
Wed Oct 25, 2017 1:36 pm
In theory you only need to learn two C functions.
* snprintf() - function that lets you format the contents of a string. ( understanding this is the hard part )
* system() - function that calls a command similar to running in on the command line.
So in the main function of the demo program:
- Allocate a buffer for the string.
- create the "curl" command needed to post the data.
- run the "curl" command.
// Allocate buffer for the string.
char postcmd[1024];   // alternative: char * postcmd = calloc(1024);
// Format the curl command to post data.
snprintf( postcmd, 1024,  "/usr/bin/curl --data \"node=1&data={power1:%d,power2:%d,power3:%d}&apikey=xxxxxxxxxxxxxxxx\" \"https://emoncms.org/input/post\"", load_percent, heatsink_temp, voltage_batt );
//print command for debug
printf( "debug: %s\n", postcmd);
//run the command
system(postcmd);
R-A
Wed Oct 25, 2017 8:32 pm
//run the command
system(postcmd);
Thank you!
That help a lot, although I'm getting really strange values from the snprintf formatted string:
Here's the (modified to work) code:
  //parse and display values
        sscanf(reply->c_str(), "%f %f %f %f %d %d %d %d %f %d %d %d %d %f %f %d", &voltage_grid, &freq_grid, &voltage_out, &freq_out, &load_va, &load_watt, &load_percent, &voltage_bus, &voltage_batt, &batt_charge_current, &batt_capacity, &temp_heatsink, &pv1, &pv2, &scc, &batt_discharge_current);
        printf("\tAC Grid voltage: %.1f\n", voltage_grid);
        printf("\tAC Grid frequency: %.1f\n", freq_grid);
        printf("\tAC out voltage: %.1f\n", voltage_out);
        printf("\tAC out frequency: %.1f\n", freq_out);
        printf("\tLoad [%]: %d\n", load_percent);
        printf("\tLoad [W]: %d\n", load_watt);
        printf("\tLoad [VA]: %d\n", load_va);
        printf("\tBus voltage: %d\n", voltage_bus);
        printf("\tHeatsink temperature: %d\n", temp_heatsink);
        printf("\tBattery capacity [%]: %d\n", batt_capacity);
        printf("\tBattery voltage: %.2f\n", voltage_batt);
        printf("\tBattery charge current [A]: %d\n", batt_charge_current);
        printf("\tBattery discharge current [A]: %d\n", batt_discharge_current);
        snprintf( postcmd, 1024,  "/usr/bin/curl --data \"node=0&data={loadwatts:%d,gridvoltage:%d,inverter_voltage:%d}&apikey=xxxxxxxxxxxx\" \"https://emoncms.org/input/post\"", load_watt, voltage_grid, voltage_bus );
And as you can see from the output, it gives different values from the original code:
Wed Oct 25 22:31:36 2017 MAIN LOOP
Skymax: QPIGS: 110 bytes read: (218.6 50.1 218.6 50.1 0262 0224 005 436 54.00 000 100 0060 0000 000.0 00.00 00000 00010101 00 00 00000 110
Skymax: QMOD: 5 bytes read: (L
AC Grid voltage: 218.6
AC Grid frequency: 50.1
AC out voltage: 218.6
AC out frequency: 50.1
Load [%]: 5
Load [W]: 224
Load [VA]: 262
Bus voltage: 436
Heatsink temperature: 60
Battery capacity [%]: 100
Battery voltage: 54.00
Battery charge current [A]: 0
Battery discharge current [A]: 0
debug: /usr/bin/curl --data "node=0&data={loadwatts:224,gridvoltage:1073741824,inverter_voltage:1080775475}&apikey=xxxxxxxxxxxx" "https://emoncms.org/input/post"
ok
I am reading up on snprintf to see how I can fix it although I haven't found anything that helps, yet. This is still a bit unclear to me.
Paeryn
Wed Oct 25, 2017 9:58 pm
From your initial reading voltage_grid is a float (or a double)
But when you print it with snprintf() you have told it to expect an integer %d
The problem is that the compiler will pass the values directly according to the type they have but snprintf will interpret the values according to what you gave in the string. The error with the value of voltage_bus is twofold, (a) because you are passing a float/double not an int, and (b) because C always promotes a float to a double when passing to vararg functions so a 64-bit floating point number was passed but snprintf was told to expect a 32-bit int so half of the data representing the number will be used as if it were an int (which is why the value is nothing like the original). Since snprintf only consumed 32-bits of this 64-bit value every subsequent argument will be wrong because it will no longer be reading the correct memory addresses.
If you want snprintf to print a float you need to use %f for that argument, not %d.
        snprintf( postcmd, 1024,  "/usr/bin/curl --data \"node=0&data={loadwatts:%d,gridvoltage:%f,inverter_voltage:%d}&apikey=xxxxxxxxxxxx\" \"https://emoncms.org/input/post\"", load_watt, voltage_grid, voltage_bus );
She who travels light — forgot something.
R-A
Thu Oct 26, 2017 9:24 am
It was late last night when I posted my reply, so this morning I played with the code again and just copied what the previous writer did and it now gives me the output I expect. Almost, the last value is still wrong.
okSkymax: QPIGS: 110 bytes read: (217.6 49.9 230.0 49.9 0276 0147 005 431 53.80 001 100 0058 0004 102.0 53.94 00000 00110110 00 00 00226 110
Skymax: QMOD: 5 bytes read: (B
AC Grid voltage: 217.6
AC Grid frequency: 49.9
AC out voltage: 230.0
AC out frequency: 49.9
Load [%]: 5
Load [W]: 147
Load [VA]: 276
Bus voltage: 431
Heatsink temperature: 58
Battery voltage: 53.80
Battery charge current [A]: 1
debug: /usr/bin/curl --data "node=0&data={loadwatts:147,gridvoltage:217.6,inverter_voltage:230.0,grid_frequency:49.9,inverter_frequency:49.9,load_va:276,loadpercentage:5,voltage_bus:431,batteryvolts:53.80,Battery_ChargeCurrent:1,Battery_Capacity:100,Inverter_Temp:58,PV_Amp:102.0,PV_Volt:53.9,SCC:0,Battery_DischargeCurrent:1992596456}&apikey=4298750438d23d97bfdc1611c52cd609" "https://emoncms.org/input/post"
As you can see, Battery_DischargeCurrent:1992596456 where it should be Battery_DischargeCurrent:0 instead.
The code I have is this:
snprintf( postcmd, 1024,  "/usr/bin/curl --data \"node=0&data={loadwatts:%d,gridvoltage:%.1f,inverter_voltage:%.1f,grid_frequency:%.1f,inverter_frequency:%.1f,load_va:%d,loadpercentage:%d,voltage_bus:%d,batteryvolts:%.2f,Battery_ChargeCurrent:%d,Battery_Capacity:%d,Inverter_Temp:%d,PV_Amp:%.1f,PV_Volt:%.1f,SCC:%d,Battery_DischargeCurrent:%d}&apikey=4298750438d23d97bfdc1611c52cd609\" \"https://emoncms.org/input/post\"", load_watt, voltage_grid, voltage_out, freq_grid, freq_out,load_va, load_percent, voltage_bus, voltage_batt, batt_charge_current, batt_capacity, temp_heatsink,pvvolt, pvamp, scc, batt_discharge_current);
I did use %d on Battery_DischargeCurrent so I'm not sure why it's doing that.
Last question:
How I multiply 2 values, before I submit it to the URL?
i.e. I want to multiply pv_volt & pv_amp and post the value.
Paeryn
Thu Oct 26, 2017 9:58 am
You read scc as a float but try printing as an int, that is hitting the providing a 64 bit value but consuming a 32 bit error making the final value for Battery_DischargeCurrent to be read from the wrong place. You were (un)lucky in that scc had a value of zero so you didn't see that value printed wrong.
Last question:
You can pass the multiplied value to the snprintf
snprintf(postcmd, 1024, "pv_volt=%f, pv_amp=%f, pv_volt*pv_amp=%f", pv_volt, pv_amp, pv_volt * pv_amp);
or store the multiplied value in another variable and pass that.
Return to “C/C++”
Who is online
Users browsing this forum: No registered users and 7 guests
