dturgut
Unable to read Pi input
Thu Sep 14, 2017 2:08 am
Hi everyone,
So I am trying to read in the state of a PWM MA3 absolute rotary encoder with the Raspberry Pi. When I run the code below, only values of zero are being printed. When I run the Python equivalent code, I get a series of ones and zeros, so I'm not sure what I am doing wrong with the C code.
#include <wiringPi.h>
#include <time.h>
#include <stdio.h>
#define Pin 1
int main(void)
       pinMode(Pin, INPUT);
       int pos[100000];
       int i = 0;
       while(i<100000)
            printf("%u", digitalRead(Pin));
            ++i;
        return 0;
To build, I simply execute:
gcc -o test test.c
./test
All help will be appreciated.
1dot0
Re: Unable to read Pi input
Thu Sep 14, 2017 7:45 am
I don't know your encoder and don't understand your code, but
- where do you setup wiringPi? By which pin numbering scheme?
6by9
Thu Sep 14, 2017 11:27 am
https://projects.drogon.net/raspberry-pi/wiringpi/pins/ for the reference on what WiringPi considers to be GPIO 1.
Please don't send PMs asking for support - use the forum.
gordon@drogon.net
Thu Sep 14, 2017 1:15 pm
Hi everyone,
#include <time.h>
#include <stdio.h>
#define Pin 1
int main(void)
       int pos[100000];
       int i = 0;
       while(i<100000)
            ++i;
        return 0;
gcc -o test test.c
./test
You're missing a call to wiringPiSetup() before the first pinMode().
incidentally, test stuff like this in a shell/terminal before you even write code with: e.g.
gpio mode 1 in
while true; do echo -n `gpio read 1`; done
-Gordon
Return to “C/C++”
Who is online
Users browsing this forum: No registered users and 2 guests
