Blackbuster
Starting .exe after boot
Mon Jun 19, 2017 5:05 pm
Hello everyone!
Im trying to launch an application after my Raspberry PI 3B boots.
So I searched around the internet and found multiple options but i cant get one of them to work.
Okay so this is the case;
Ive got this executable file located at /home/pi/software/ddvsoft.exe and when i test it from terminal using:
sudo mono /home/pi/software/ddvsoft.exe
it works perfect!
Now i want to start it right after the raspberry pi boots.
I tryed:
adding
@mono /home/pi/software/ddvsoft.exe
and
@sudo mono /home/pi/software/ddvsoft.exe
to /etc/xdg/lxsessions/LXDE-pi/autostart
and..
adding
and
to /etc/xdg/lxsessions/LXDE/autostart
and..
adding
and
to /etc/init.d/rc.local
and..
adding
and
to /etc/rc.local
and last i tryed with crontab:
@reboot sudo mono /home/pi/software/ddvsoft.exe
but all these solutions do not start the app after boot.
I hope someone can help me out!
Greetings,
Kevin
topguy
Re: Starting .exe after boot
Mon Jun 19, 2017 10:22 pm
details that might be important..
- rc.local and cron is not run by the user Pi.
- if your program does not return or is spawned off in the background it might be killed by systemd.
- what if "mono" is not in the known PATH of the root user while booting. (use "which mono" to figure out where its hiding)
Since you say it runs well if you start it with sudo I would try (in rc.local)
/usr/bin/mono /home/pi/software/ddvsoft.exe  > /home/pi/mylog.txt &
If this doesnt work, you might see an error in mylog.txt that tells you why it doesnt work, and if it does work you can remove the logging to file.
PS! if you .exe file is a GUI program then I guess you need to wait for the desktop to load.
klricks
Mon Jun 19, 2017 11:24 pm
Blackbuster wrote:...
and..
adding
and
To start after desktop (GUI) loads, use this path: (Raspbian Jessie Pixel)
sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart
Go here for my RPi writeup. Basic config, Serial Port add-on etc:
http://blackeagle12.net/Comp/RPi/Rpi.html Click contact icon then world icon --->
Blackbuster
Tue Jun 20, 2017 11:16 am
mylog.txt stays empty and yes its a GUI program!
Im using Jessie but the .config folder does not exist.
Thanks guys!
anoyone else?
#edit
Problem solved!
Its: sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart to start it!
Return to “C/C++”
Who is online
Users browsing this forum: No registered users and 12 guests
