Ginnychabada
stringstream exits the program
Mon Jun 19, 2017 7:23 am
Hi, I have been trying to write a program to take continuous snaps on raspi camera. It worked all fine untill i included few other functions that are concerned with the unicorn hat. When i included them, it doesn't show any error during compiling or during run. It just comes out of the program without even printing the first printf statement in the program.
Here is the code before including the unicorn's related functions:
#include <ctime>
#include <fstream>
#include <sstream>				//stringstream - used for naming the files in the loop
#include <iostream>
#include <raspicam/raspicam.h>
#include <unistd.h>
#include <sys/time.h>
#include "shutter.h"
using namespace std;
int main (int argc, char **argv)
	bettercam Camera; //camera object
	//open camera
	if(!Camera.open())
		cerr<<"Error opening the Camera"<<endl;
		return -1;
	//shutter management
	int scale;
	cout<<endl<<" \t\t\t\t"<<"Enter the shutter speed in the range of 1 - 10: ";
	cin>>scale;
	cout<<endl;
	Camera.chooseShutterspeed(scale);
	for(int i=0;i<2;i++)
			//wait untill the camera stabilizes
			cout<<"Sleeping for 3 sec..."<<endl;
			sleep(3);
			struct timeval t1,t2;
			gettimeofday(&t1,NULL);				//timestamp 1
				//capture
				Camera.grab();
			gettimeofday(&t2,NULL);				//timestamp 2
			//allocate memory
			unsigned char *data=new unsigned char[  Camera.getImageTypeSize ( raspicam::RASPICAM_FORMAT_RGB )];
			//extract the image in rgb format
			Camera.retrieve ( data,raspicam::RASPICAM_FORMAT_RGB );//get camera image
	        std::stringstream ss;
			//save
			ss<<"file-"<<i;
			std::string s = ss.str();
			std::ofstream outFile ( s.c_str(),std::ios::binary );
			outFile<<"P6\n"<<Camera.getWidth() <<" "<<Camera.getHeight() <<" 255\n";
			outFile.write ( ( char* ) data, Camera.getImageTypeSize ( raspicam::RASPICAM_FORMAT_RGB ) );
			cout<<"Image saved at "<<ss.str()<<endl;
			//time diff
			cout<<"Time diff: "<<t2.tv_usec-t1.tv_usec<<"micro seconds"<<endl<<endl<<endl;
			//free resrources
			delete data;
    return 0;
Here is the code after adding the other functionalities:
#include <iostream>
#include <ctime>
#include <fstream>
#include <unistd.h>
#include <assert.h>
#include <dirent.h>
#include <errno.h>
#include <fcntl.h>
#include <math.h>
#include <signal.h>
#include <stdarg.h>
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <time.h>
#include <unistd.h>
#include <sys/mman.h>
#include <sys/stat.h>
#include <sys/types.h>
#include "ws2811.h"
#define TARGET_FREQ    WS2811_TARGET_FREQ
#define GPIO_PIN       18
#define DMA            5
#define WIDTH          8
#define HEIGHT         8
#define LED_COUNT      (WIDTH * HEIGHT)
ws2811_t ledstring
    .freq = TARGET_FREQ,
    .dmanum = DMA,
    .channel =
        [0] =
            .gpionum    = GPIO_PIN,
            .count      = LED_COUNT,
            .invert     = 0,
            .brightness = 55,
void setBrightness(ws2811_t &ledstring,int b)
    ledstring.channel[0].brightness = b;
    return;
void setPixelColorRGB(ws2811_t &ledstring, int pixel, int r, int g, int b)
    ledstring.channel[0].leds[pixel] = (r << 16) | (g << 8) | b;
    return;
void clearLEDBuffer(ws2811_t &ledstring){
    int i;
    for(i=0; i<LED_COUNT;i++){
        setPixelColorRGB(ledstring, i,0,0,0);
  Remap an x/y coordinate to a pixel index
int getPixelPosition(int x, int y){
    int map[8][8] = {
        {7 ,6 ,5 ,4 ,3 ,2 ,1 ,0 },
        {8 ,9 ,10,11,12,13,14,15},
        {23,22,21,20,19,18,17,16},
        {24,25,26,27,28,29,30,31},
        {39,38,37,36,35,34,33,32},
        {40,41,42,43,44,45,46,47},
        {55,54,53,52,51,50,49,48},
        {56,57,58,59,60,61,62,63}
    return map[x][y];
void show(ws2811_t &ledstring){
    ws2811_render(&ledstring);
void unicorn_exit(int status){
    int i;
    ws2811_t ledstring;
    ledstring.freq = TARGET_FREQ;
    ledstring.dmanum = DMA;
    ledstring.channel[0].gpionum    = GPIO_PIN;
    ledstring.channel[0].count      = LED_COUNT;
    ledstring.channel[0].invert     = 0;
    ledstring.channel[0].brightness = 55;
    for (i = 0; i < 64; i++){
    ws2811_fini(&ledstring);
    exit(status);
void control_led(ws2811_t &ledstring){
	int bri,p;
	cout<<"Enter the overall brightness of the LEDs\nNote: Brightness should be an integer ";
	cin>>bri;
	clearLEDBuffer(ledstring);
	show(ledstring);
	setBrightness(ledstring, bri);
	int n=-1;
    while(n<0){
        cout<<"\nEnter the number of LEDs to be turned ON at a time ";
        cin>>n;
	int t=-1;
    while(t<0){
        cout<<"\nEnter the duration of ON in seconds ";
        cin>>t;
	int x,y,r,g,b,i;
	for(i=0;i<n;i++){
		x=-1;y=-1;r=-1;g=-1;b=-1;
		while(x<0 || x>7){
			cout<<"Enter the x co-ordinate of led "<<i+1;
			cin>>x;
		while(y<0 || y>7){
			cout<<"Enter the y co-ordinate of led "<<i+1;
			cin>>y;
		cout<<"\n";
		while(r<0 || r>255){
			cout<<"Enter the value for R ";
			cin>>r;
		while(g<0 || g>255){
			cout<<"Enter the value for G ";
			cin>>g;
		while(b<0 || b>255){
			cout<<"Enter the value for B ";
			cin>>b;
		cout<<"\n";
		p=getPixelPosition(x, y);
		setPixelColorRGB(ledstring, p, g, r, b);
	show(ledstring);
	sleep(t);
int main()
	int i;
	ws2811_t ledstring;
    for (i = 0; i < 64; i++) {
        struct sigaction sa;
        memset(&sa, 0, sizeof(sa));
        sa.sa_handler = unicorn_exit;
        sigaction(i, &sa, NULL);
    setvbuf(stdout, NULL, _IONBF, 0);
    if(ws2811_init(&ledstring))
        return -1;
    /////////////////////////////////////////////////// Camera Monitoring //////////////////////////////////////////////////
    //camera object
    bettercam Camera;
	//open camera
	if(!Camera.open())
		return -1;
	int scale;
	cin>>scale;
	cout<<endl;
	control_led(ledstring);
			sleep(3);
				//capture
				Camera.grab();
			//allocate memory
			//save
			ss<<"file-"<<i;
			time diff
			free resrources
			delete data;
	//unicorn_exit(0);
	show(ledstring);
I guess the problem is with std::stringstream ss . I am not sure. Can someone tell me what's going wrong .
LdB
Re: stringstream exits the program
Mon Jun 19, 2017 7:52 am
At a guess .. your if test is wrong
        return -1;
Show us what ws2811_init does .. We don't have the code but that would do exactly as you say it does if wrong.
Paeryn
Mon Jun 19, 2017 11:20 am
I'm confused about the title, you say stringstream exits the program yet your old program uses stringstream and you say that works fine, none of the new code uses it so why do you suspect stringstream?
ws2811_init() returns 0 for success and -1 for failure so that part is ok. I'd stick a print there to see if that call is the one failing.
There is an issue with the exit handling function you set up (apart from that you try setting all signals from 0 to 63 to it).
    int i;
    ws2811_t ledstring;
    exit(status);
Here in your exit handler you for some reason create a new struct ws2811_t and try using it (and then finishing it) without ever initialising it. That isn't going to work (the struct holds information that it needs to talk to the hardware, this new one won't have that), you should be using & finishing the one that you originally created. And this handler could theoretically be called before the original struct has been initialised so you need to check for that.
She who travels light — forgot something.
tommylee2k
Wed Jun 21, 2017 2:40 pm
compile it with debugging info ( -g ), and see what happens in GDB
Return to “C/C++”
Who is online
