from sklearn.decomposition import RandomizedPCA
import numpy as np
import glob
import cv2
import math
import os.path
import string
#function to get ID from filename
def ID_from_filename(filename):
part = string.split(filename, '/')
return part[1].replace("s", "")
#function to convert image to right format
def prepare_image(filename):
img_color = cv2.imread(filename)
img_gray = cv2.cvtColor(img_color, cv2.cv.CV_RGB2GRAY)
img_gray = cv2.equalizeHist(img_gray)
return img_gray.flat
IMG_RES = 92 * 112 # img resolution
NUM_EIGENFACES = 10 # images per train person
NUM_TRAINIMAGES = 110 # total images in training set
#loading training set from folder train_faces
folders = glob.glob('train_faces/*')
# Create an array with flattened images X
# and an array with ID of the people on each image y
X = np.zeros([NUM_TRAINIMAGES, IMG_RES], dtype='int8')
y = []
# Populate training array with flattened imags from subfolders of train_faces and names
c = 0
for x, folder in enumerate(folders):
train_faces = glob.glob(folder + '/*')
for i, face in enumerate(train_faces):
X[c,:] = prepare_image(face)
y.append(ID_from_filename(face))
c = c + 1
# perform principal component analysis on the images
pca = RandomizedPCA(n_components=NUM_EIGENFACES, whiten=True).fit(X)
X_pca = pca.transform(X)
