Lestat85
Re: Nokia Pi LCD
Wed Feb 12, 2014 4:32 pm
I've made a little daemon to show some system (system load and network ip) and router info (adsl speed and public ip, vodafone hg556a only).
The code is at gihub: https://github.com/vrdominguez/lcd-daemon
I've made it because I want to learn python, so any comment or advise is welcome
zelib0ba
Re: Nokia Pi LCD
Tue Mar 17, 2015 12:19 pm
Help plz.
I can't connect this display Imageto Rpi B+
c code work(https://www.dropbox.com/s/2f9s74ai0bxj7kp/cpu.zip?dl=0 ,but the python code from this topic does not work
magnus2005
Re: Nokia Pi LCD
Sat Mar 05, 2016 10:41 pm
hello,
I have a problem with displays center text. when I am running example of xavier berger lib clock.py almost everything is displaing ok except 3th line where hour I dont know why is at 2th line. but when I change value string from date and time to own text and add another line there is a problem. text disnt display at center but like lcd. text.
changed clock.py file to my code:
import pcd8544.lcd as lcd
import time, os, sys
if not os.geteuid() == 0:
    sys.exit('Script must be run as root')
ON, OFF = [1, 0]
try:
  lcd.init()
  lcd.cls()
  lcd.backlight(ON)
  lcd.centre_text(0,"PROBLEM")
  lcd.centre_text(1,"PROBLEM")
 lcd.centre_text(2, "TXT"
 lcd.centre_text(3,"HI")
 lcd.centre_text(4,"PROBLEM")
 time.sleep(0.25)
except KeyboardInterrupt:
  pass
finally:
  lcd.cls()
  lcd.backlight(OFF)
http://imgur.com/pCXQvkL anyone helps?
and one more question, why at lcd. py in gotoxy there is x+128, y+64?
fabertel
Re: Nokia Pi LCD
Mon Sep 26, 2016 9:40 pm
hi ! not sure if this thread is already active . i was finally able to make the display work using this
https://github.com/XavierBerger/pcd8544
But I have 2 issues :
1) i cannot user the gotoxy command . it never goes beyond the 4*4 position .
2) the lcd.centre_text behaviour is random . writing below concatenates the string in same record ..
lcd.centre_text(5,time.strftime("%d %b %Y", time.localtime()))
lcd.centre_text(6,time.strftime("%H:%M:%S", time.localtime()))
Return to “Python”
