Problem controlling a GPIO with Python
Posted: Mon Dec 22, 2014 8:34 pm
by eltuxumuxu
I have the Raspberry Pi B with Raspbian installed.
Im trying to control the GPIO27 (number 13) with a script
The script on.py says:
import RPi.GPIO as GPIO
GPIO.setup(13, GPIO.OUT)
GPIO.output(13, True)
and off.py says:
GPIO.output(13, False)
The problem is that the LED connected to the GPIO doesn't turn on.
However, if i follow the following commands, it turns on
root@raspberrypi:~# echo 27 > /sys/class/gpio/export
root@raspberrypi:~# echo out > /sys/class/gpio/gpio27/direction
root@raspberrypi:~# echo 1 > /sys/class/gpio/gpio27/value
I have no problem with python using others GPIOs, but i cant using this. What am i doing wrong?
Re: Problem controlling a GPIO with Python
Posted: Tue Dec 23, 2014 4:45 am
by vachhaninimiT
You code should be
GPIO.setmode(GPIO.BOARD) #or you can use GPIO.setmode(GPIO.BCM)
#In board mode it will setup up pin 13 and in BCM mode it will setup GPIO13
Posted: Tue Dec 23, 2014 11:42 am
by DirkS
Above is correct, but to make it absolutely clear: RPi.GPIO defaults to mode GPIO.BCM.
So if you don't set it explicitly to GPIO.BOARD you should use the same number as you did in the echo commands (27).
Gr
Dirk.
Posted: Tue Dec 23, 2014 11:52 am
by eltuxumuxu
Thank you, there was two problems: first was that, i had to set the setmode, and the second one, i had installed RPi.GPIO 0.1.0, when i uninstalled it, it worked like a charm. Thank you again!!
