simplesi
Easiest way to get a Python prog to receive a T'internet msg
Sun Dec 14, 2014 10:53 pm
I want to stick a Model A+ with Unicorn hat at top of tree underneath our Angel and tweet/whatsapp/sms (any muggle friendly app will do) so I can change the colour of the leds.
I'm a Python person so would like to do it in that (and then maybe extend to ScratchGPIO!)
ideas?
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
toxibunny
Re: Easiest way to get a Python prog to receive a T'internet
Sun Dec 14, 2014 11:32 pm
this is a really good question, and I'm sorry to say I don't know, apart from it probably has something to do with tcp, udp, and/or sockets, if they're not already the same thing.
I bought one of those esp8266 modules the other day, and it's really revealed a pretty big gap in my knowledge. I've been doing a little bit of reading, but haven't really grokked it yet...
note: I may or may not know what I'm talking about...
DirkS
Sun Dec 14, 2014 11:36 pm
Possible starting point: http://blog.whaleygeek.co.uk/twurtle/
Gr.
Dirk.
simplesi
Sun Dec 14, 2014 11:42 pm
@dirk - Ta - I'll read up on twitter modules
Simon
simplesi
Mon Dec 15, 2014 12:11 am
Ended up following
http://www.makeuseof.com/tag/how-to-bui ... itter-bot/ (Note instructions slightly outdated so you need to interpret and modify slightly - main one is that it wnted me to authorise my phone)
and got it reading my timeline using
#!/usr/bin/env python
import sys
from twython import Twython
CONSUMER_KEY = 'cxcvcvx2'
CONSUMER_SECRET = 'ffdfgdfgdfgdf
ACCESS_KEY = 'dfgdfgdg'
ACCESS_SECRET = dfgdgdgdfgdf'
twitter = Twython(CONSUMER_KEY,CONSUMER_SECRET,ACCESS_KEY,ACCESS_SECRET)
print twitter.get_home_timeline()
so I should be off to the races
simplesi
Mon Dec 15, 2014 8:25 am
And this shows how to receive a tweet :)
https://learn.sparkfun.com/tutorials/ra ... er-monitor
simplesi
Mon Dec 15, 2014 4:13 pm
@forToffee showed me this
http://fortoffee.org.uk/2014/12/a-cheer ... tmas-tree/
which is easier to do as no Twitter authorisation needed but then my Pi is not totally under my control :)
Simon
simplesi
Tue Dec 16, 2014 1:08 pm
So i've added in #cheerlights into ScratchGPIO but still looking for a ways of interacting normal muggles to an #Iot Pi device :)
http://simplesi.net/cheerlights-support ... -dev-only/
Tue Dec 16, 2014 1:50 pm
simplesi wrote:So i've added in #cheerlights into ScratchGPIO but still looking for a ways of interacting normal muggles to an #Iot Pi device :)
Ah, that explains some of the obscure tweets from Dr. Andy Stanford-Clark (@andysc) that I've been seeing.
I'll do your homework for you for a suitable fee.
danarashad
Mon Jan 12, 2015 4:23 am
simplesi wrote:Ended up following
import sys
I am trying to get this to work. But I keep receiving the following errors.
[email protected](none) ~/TwitterTest $ python d.py 'Hello Twitterverse'
File "d.py", line 9, in <module>
api.update_status(status=sys.argv[1])
File "/usr/local/lib/python2.7/dist-packages/twython/endpoints.py", line 107, in update_status
return self.post('statuses/update', params=params)
File "/usr/local/lib/python2.7/dist-packages/twython/api.py", line 267, in post
return self.request(endpoint, 'POST', params=params, version=version)
File "/usr/local/lib/python2.7/dist-packages/twython/api.py", line 257, in request
api_call=url)
File "/usr/local/lib/python2.7/dist-packages/twython/api.py", line 198, in _request
retry_after=response.headers.get('X-Rate-Limit-Reset'))
twython.exceptions.TwythonAuthError: Twitter API returned a 401 (Unauthorized), Could not authenticate you
What if anything am I doing wrong. I followed the directions from the link you posted. I have the correct access keys from twitter. Thanks for any help. Raspberry Pi b+, I don't know if that has anything to do with it not working.
simplesi
Mon Jan 12, 2015 7:11 am
Well my code prints tweets - you seem to be wanting to send a tweet
Can you show us your code and I'll try it with my creds
Simon
Mon Jan 12, 2015 12:40 pm
The problem is that danarashad has failed to get the OAuth2 stuff done to register his application, get the four keys (consumer_key, consumer_secret, access_token, access_token_secret) and run the OAuth callback process.
The Twython documentation is very much lacking details of how to do that. There's one more reason to use Tweepy.
DavidMS
Mon Jan 12, 2015 12:47 pm
Have a look this is would be quite easy to modify to what you are looking for, I think
http://www.raspberrypi.org/forums/viewt ... 32&t=95987
http://meanderingpi.wordpress.com/
11 Raspberry Pi's and counting....
danarashad
Mon Jan 12, 2015 7:58 pm
DougieLawson wrote:The problem is that danarashad has failed to get the OAuth2 stuff done to register his application, get the four keys (consumer_key, consumer_secret, access_token, access_token_secret) and run the OAuth callback process.
I can try to run the OAuth callback process. I have the four keys, I'll figure out how to run the OAuth callback process. Thanks for all the help. By the way is Raspberry Pi big in the UK? I am in America and it seems like a lot of the help is coming out of the UK.
Mon Jan 12, 2015 8:08 pm
danarashad wrote: I can try to run the OAuth callback process. I have the four keys, I'll figure out how to run the OAuth callback process. Thanks for all the help. By the way is Raspberry Pi big in the UK? I am in America and it seems like a lot of the help is coming out of the UK.
It's a British design for a British university, made by a British company in Wales. So it's just ever so slightly British and ever so slightly popular over here in Blighty.
danarashad
Tue Jan 13, 2015 2:52 am
Thanks, I got it working now.
I had to change
ACCESS_KEY = '***************YOUR DATA*****************'
to OAUTH_TOKEN=''
And I changed ACCESS_SECRET = '***************YOUR DATA*****************'
to OAUTH_TOKEN_SECRET=''.
Works like a charm. Again thanks for the help.
The link where I started the project.
And go Blighty I have been wanted a Pi then finally bought one.
Return to “Python”
