karltheneale
working through Python programming
Wed Dec 10, 2014 9:03 am
Hi, I've been working through some tasks and keep getting an error can anyone help please?
from tkinter import *
class App:
    def _init_(self, master):
        frame = Frame(master)
        frame.pack()
        Label (frame, text='deg C').grid(row=0, column=0)
        button = Button(frame, text='Convert', command=self.convert)
        button.grid(row=1)
    def convert(self):
        print('Not Implemented')
root = Tk()
root.wm_title('Temp Converter')
app = App(root)
root.mainloop()
error
File "C:/Users/Steve/Desktop/Python/Hello.py", line 17, in <module>
app = App(root)
TypeError: object() takes no parameters
ame
Re: working through Python programming
Wed Dec 10, 2014 9:14 am
Please use tags around your code, otherwise it's impossible to read.
B.Goode
Wed Dec 10, 2014 9:26 am
ame wrote:Please use tags around your code, otherwise it's impossible to read.
+1
But from what we can see -
app = App(root)
app is going to be an instance of the class App. And you have defined App to have no parameters. So the error message is telling you that you have provided a parameter ( root ) that it can't use.
Whether you fix this in the class definition or at the place where it is called depends on what you want to achieve.
karltheneale
Wed Dec 10, 2014 9:43 am
This works fine
class MyApp:                         ### (1)
	def __init__(self, myParent):      ### (1a)
		self.myContainer1 = Frame(myParent)
		self.myContainer1.pack()
		self.button1 = Button(self.myContainer1)
		self.button1["text"]= "Hello, World!"
		self.button1["background"] = "green"
		self.button1.pack()
root = Tk()
myapp = MyApp(root)  ### (2)
root.mainloop()      ### (3)
i don't understand why this would work and the other doesn't
ame
Wed Dec 10, 2014 9:49 am
Your "init" has a single underscore. The working example has two.
karltheneale
Wed Dec 10, 2014 9:55 am
ame wrote:Your "init" has a single underscore. The working example has two.
brilliant reply thank you
Return to “Python”
