simplesi
basic image processing module
Tue Dec 09, 2014 6:57 pm
Is there a basic image reader module in default Pi Python 2 setup?
I'm just looking to reading in a image - reduce it in size to 8x8 and display it on a Unicorn Hat
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
DirkS
Re: basic image processing module
Tue Dec 09, 2014 7:04 pm
Pillow (formerl PIL): http://pillow.readthedocs.org/
or ImageMagick
Gr.
Dirk.
simplesi
Tue Dec 09, 2014 7:11 pm
I was wondering if there was anything basic that is installed by default?
Simon
DirkS
Tue Dec 09, 2014 7:29 pm
simplesi wrote:I was wondering if there was anything basic that is installed by default?
Not that I'm aware of...
Gr.
Dirk.
gordon77
Tue Dec 09, 2014 7:51 pm
What kind of image are you reducing to 8x8 ?
Expecting something viewable ?
paddyg
Tue Dec 09, 2014 8:30 pm
You could probably use numpy which has been bundled with the standard raspbian. BUT if you haven't used it much already you probably won't find it 'basic' (though I would recommend getting to grips with it). See some discussion here http://www.raspberrypi.org/forums/viewt ... ge#p532741
Pillow is your best bet.
simplesi
Tue Dec 09, 2014 10:36 pm
I don't think (or at least can't find) numpy reads image files
Simon
gordon77
Tue Dec 09, 2014 11:14 pm
How about just using pygame to load the image, then pygame.transform to resize it, possible taking the average of the 64 areas and rebuilding the 8x8 image.
How do you display it on the hat ?
simplesi
Tue Dec 09, 2014 11:35 pm
I need (want) a module that doesn't need installing by the user for ScratchGPO to read in an image and then display it on a led matrix
Its just occured to me that maybe I bodge things by calling bash image commands
Simon
simplesi
Wed Dec 10, 2014 2:06 pm
Well - i've resorted to just reading bytes from an 8x8 bmp file to start with so I'm relying on external progs to resize/convert for me buts its a start :)
https://vine.co/u/968241109107089408
gordon77
Wed Dec 10, 2014 6:33 pm
simplesi wrote:I need (want) a module that doesn't need installing by the user for ScratchGPO to read in an image and then display it on a led matrix
Simon
Pygame doesn't need installing with python 2.7, is that what you mean or do you mean installing even a python program?
simplesi
Wed Dec 10, 2014 11:47 pm
No - if pygame is installed by default - I'll give it a go :)
Ta
Simon
knute
Thu Dec 11, 2014 4:00 am
You are going to run into some interesting artifacts by scaling an image to 8x8. I'm not a Python programmer so I can't help you with that but it is a simple task in Java to scale an image. What do you need in the end, the RGB values of the 64 pixels?
simplesi
Thu Dec 11, 2014 11:31 am
Got this working
if self.bFindValue('image'):
                                subprocess.Popen(['convert', '-resize', '8x8!', '+matte', '/home/pi/sghdev/scratch_gpio/' +self.value , '/home/pi/sghdev/scratch_gpio/sghimage.bmp'])
                                # When reading a binary file, always add a 'b' to the file open mode
                                with open('sghimage.bmp', 'rb') as f:
                                #with open(self.value + '.bmp', 'rb') as f:
                                    # BMP files store their width and height statring at byte 18 (12h), so seek
                                    # to that position
                                    f.seek(10)
                                    # The width and height are 4 bytes each, so read 8 bytes to get both of them
                                    bytes = f.read(4)
                                    # Here, we decode the byte array from the last step. The width and height
                                    # are each unsigned, little endian, 4 byte integers, so they have the format
                                    # code '<II'. See http://docs.python.org/3/library/struct.html for more info
                                    bmpdata = int(struct.unpack('<I', bytes)[0])
                                    print bmpdata
                                    # Print the width and height of the image
                                    print('Data starts at:  ' + str(bmpdata))
                                    #print('Image height: ' + str(size[1]))
                                    f.seek(bmpdata)
                                    for i in range(0,64):
                                        bytes = f.read(3)
                                        pixel = struct.unpack('BBB',  bytes)#[0]
                                        #pixel = struct.unpack('<I', bytes)[0]
                                        print i,pixel
                                        self.matrixBlue,self.matrixGreen,self.matrixRed = pixel
                                        ym = int(int(i) / 8)
                                        xm  = i % 8
                                        #print "xm,ym" ,xm,ym
                                        #print self.matrixRed,self.matrixGreen,self.matrixBlue
                                        #print self.matrixMult,self.matrixLimit,self.matrixRangemax,led, ym, ym
                                        UH.set_pixel(xm,7 - ym,self.matrixRed,self.matrixGreen,self.matrixBlue)
                                    UH.show()
Just need to make sure it works on a virgin Raspbian install
Simon
paddyg
Thu Dec 11, 2014 2:32 pm
could you do something like this which might be tidier:
bytes = f.read(192)
pixel = struct.unpack('192B',  bytes)
pixel = numpy.array(pixel).reshape(8, 8, 3)
for i, p in enumerate(pixel):
  for j, pp in enumerate(p[::-1]):
    UH.set_pixel(i, j, pp[0], pp[1], pp[2])
simplesi
Thu Dec 11, 2014 3:23 pm
Ta - I've ended up with this (saves using numpy)
                                    bytes = f.read(192)
                                    print "pixel",pixel
                                        UH.set_pixel( i % 8, 7 - (i // 8), pixel[(i * 3) +2], pixel[(i * 3) +1], pixel[(i * 3) +0])
Return to “Python”
