leejohnson
help on a couple of pythons question please :)
Wed Dec 03, 2014 2:21 pm
Hey only me again i have two questions for my gui im working on.
1. i have created a settings page and want to have a slidder bar on the page to control the dimmer on the screen (like a phone or sat nav does) at to save the light setting for all screens.
2. im in need of a countdown when a button is pressed (take photo) i want print on screen a 5 second countdown (using my font) and then Smile!!! then the pi camera take the photo.
i have gone through varies website but havent found something quite right , is this possible, as always thank you in advance
scotty101
Re: help on a couple of pythons question please :)
Wed Dec 03, 2014 5:11 pm
What are you using to create your GUI?
Tkinter?
Pygame?
wxWidgets?
Kivy?
Laurens-wuyts
Wed Dec 03, 2014 5:37 pm
Maybe something to look at?
http://www.raspberrypi.org/forums/viewt ... 38&t=75899
Laurens
gordon77
Thu Dec 04, 2014 10:04 am
I've wondered how to get pygame to read the mouse buttons as you move the mouse, so I did some investigation. Here's one solution to your slider question: The slider (red bar) will move with the mouse when you press the left mouse button. The value of the position will be x in the program.
Gordon77
#!/usr/bin/python
import os
import pygame, sys
from pygame.locals import *
# set window size
width = 640
height = 100
# initilaise pygame
pygame.init()
windowSurfaceObj = pygame.display.set_mode((width,height),1,16)
redColor = pygame.Color(255,0,0)
blackColor = pygame.Color(0,0,0)
#starting position
x = 100
pygame.draw.rect(windowSurfaceObj,redColor,Rect(x,5,10,90))
pygame.display.update(pygame.Rect(0,0,width,height))
s = 0
while s == 0:
    button = pygame.mouse.get_pressed()
    if button[0] != 0:
       pos = pygame.mouse.get_pos()
       x = pos[0]
       y = pos[1]
       a = x - 5
       if a < 0:
          a = 0
       pygame.draw.rect(windowSurfaceObj,blackColor,Rect(0,0,width,height))
       #pygame.display.update(pygame.Rect(0,0,width,height))
       pygame.draw.rect(windowSurfaceObj,redColor,Rect(a,5,10,90))
   # check for ESC key pressed, or pygame window closed, to quit
    for event in pygame.event.get():
       if event.type == QUIT:
          pygame.quit()
          sys.exit()
       elif event.type == KEYDOWN:
          if event.key == K_ESCAPE:
             pygame.quit()
             sys.exit()
leejohnson
Thu Dec 04, 2014 11:11 am
scotty sorry i thought i had put it in.
it is in pygame
gordon77
Thu Dec 04, 2014 11:38 am
Heres a version using images, save the attached inamges in home/pi
Gordon77
#!/usr/bin/python
import os
import pygame, sys
# set window size
width = 256
height = 28
# initilaise pygame
pygame.init()
screen = pygame.display.set_mode((width,height),1,16)
slider= pygame.image.load('slider.jpg')
background= pygame.image.load('slider_back.jpg')
#starting position
x = 100
screen.blit(background,(0,0))
screen.blit(slider,(x,5))
s = 0
while s == 0:
    if button[0] != 0:
       x = pos[0]
       y = pos[1]
       if x < 5:
          x = 5
       if x > 240:
          x = 240
          pygame.quit()
          sys.exit()
             pygame.quit()
             sys.exit()
scotty101
Thu Dec 04, 2014 12:27 pm
I've found PGU very useful for creating GUIs https://code.google.com/p/pgu/
I worked with a small team to develop an air traffic control game that used pygame and pgu. It had some sliders and buttons. Link is https://code.google.com/p/python-air-traffic-control/
leejohnson
Thu Dec 04, 2014 2:32 pm
wow i like that, thank you very much guys on your help with the slidder.
btw is there an easy way of making a button function. for example
screenmode 1 has 2 buttons say ( yes) (no)
if (yes) pressed go to screenmode 2
if (no) pressed go to screenmode 3
thats what i want to achieve but havent dived into code yet to work it out.
gordon77
Fri Dec 05, 2014 8:41 am
Lee,
You asked about controlling the brightness with the slider, here's a version that does that by varying the colours.
Gordon77
#!/usr/bin/python
import os
import pygame, sys
# set window size
width = 255
height = 100
# initilaise pygame
pygame.init()
#starting position
x = 128
redColor = pygame.Color(x,0,0)
whiteColor = pygame.Color(x,x,x)
pygame.draw.rect(windowSurfaceObj,whiteColor,Rect(0,0,width,height))
s = 0
while s == 0:
    if button[0] != 0:
       x = pos[0]
       y = pos[1]
       a = x - 5
       if a < 0:
          a = 0
       if event.type == QUIT or (event.type == KEYDOWN and event.key == K_ESCAPE):
          pygame.quit()
          sys.exit()
Return to “Python”
