william_b
[Solved] Run python script in another python script
Sat Nov 29, 2014 6:08 pm
Hello everyone,
I am new on the forum.
Two weeks ago I bought my rapsberry pi. So i'm still a beginner.
I have two python scripts:
  • sendmail.py
    7segment+buttons.py
Running the following code, results in sending an email to myself.
python sendmail.py 'subject of the mail' 'body of the mail
I do want to run sendmail.py from within 7segment+buttons.py and pass some arguments. This is were I get stuck.
I have implemented it as follows:
import os
try:
   while True:
   # button pressed
      index+=1
      os.system('python sendmail.py "update" index'
      #increase number on 7-segment display)
The problem:
  • Index is recognised as a string (not as a variable)
    Increase number on 7-segment display is delayed (it waits until the mail is send)
After some googling, I did find that I could also use subprocess.Popen. I tried it, but didn't get it to work.
Can someone help me, or give me a tip how to solve this problem.
paddyg
Re: Run python script in another python script
Sun Nov 30, 2014 12:09 am
Yes you should use subprocess.Popen with a list of each word in the command you want to execute ie ['python', 'sendmail.py', 'subject of email' etc..]
if you want to include a variable in a string you need to use format() ie
'python sendmail.py "update" {}'.format(index)
william_b
Sun Nov 30, 2014 8:00 am
Thank you, this worked perfectly.
elParaguayo
Re: [Solved] Run python script in another python script
Sun Nov 30, 2014 12:42 pm
For what it's worth, it's actually possible to do without string formatting too e.g.:
subject="This is the subject of my email"
body="This is the body of my email"
subprocess.Popen(["python", "sendmail.py", subject, body])
This should work as python will treat each item in the list as a separate parameter.
Depending on how sendmail is structured you could also import it into your own script and then call the functions directly rather than having to trigger a separate python process.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
ranjithkalluri
Thu Nov 16, 2017 10:36 pm
I have same issue, I tried using os.system('python abc.py'), it appears that the program is running until I interrupt with keyboard.
But abc.py program should read from sensor and create a csv file. It runs perfectly when run separately but doesn't work while called from another script.
I have tried using shebang line interpreter ( #!) inside abc.py file, but still doesn't work
elParaguayo
Fri Nov 17, 2017 7:35 am
Can you post your scripts?
Return to “Python”
