Hi all,
basically this is the idea:
I have a Machine COntroller (PLC) which outputs string message on the ethernet port (via socket communication). In the raspberry pi i want to add those strings into a RSS server.... Connected in the same network is an device with an RSS feed reader reading those messages..
What i have to make is the communication between the PLC and the Raspberry (1) and i need to make a program in the raspberry which add's the incoming strings onto the RSS server.
Does anyone can help me with this application, or give me a good example about making the communication between the controller and the rasberry pi?
Thanks a lot
Best regards,
Denistuff
