upgrade9909
็Help me! Thai font in esc/pos
Mon Nov 03, 2014 11:21 am
Now I use Tsp650 and using esc/pos version 1.0.9
https://pypi.python.org/pypi/python-escpos/1.0.9
this is my code
#!/usr/bin/env python
# -*- coding: utf-8 -*-
from escpos import *
import qrcode
Epson = printer.Usb(0x0519,0x0001)
Epson.set(font='a', codepage='cp874', size='2x', align='center')
s = u'ลองตัวอักษรไทย'
Epson.text("Hello World\n")
Epson.text(s)
Epson.cut()
but when it print out thai font are error like this http://s23.postimg.org/ac75oieff/DSC_1344.jpg
how can I solve this problem??
scruss
Re: ็Help me! Thai font in esc/pos
Mon Nov 03, 2014 1:02 pm
Most ESC-POS printers only know 8-bit charater sets. As you're using Unicode, the codes are well outside that range. So you're going to have to use graphics mode.
Now you're using a faster printer than the Sparkfun/Adafruit one, you could take a look at:
  1. Using a TrueType font and rendering it to a bitmap using the Pillow ImageFont module.
  2. Print the bitmap using something like this: esc-pos-image.py.
Reed Zhao is the expert on thermal printing here, but he's very busy right now.
cheers,
Stewart
Pronouns: he/him
upgrade9909
Mon Nov 03, 2014 9:10 pm
Thank , scruss
And do you know how to change a font size and image size in python-esc/pos ?
scruss
Wed Nov 05, 2014 4:42 am
Will this work for you?
Here's what I did:
#!/usr/bin/python
# thaitest.py - thai thermal printing test - scruss, 2014-11-04
from PIL import Image, ImageFont, ImageOps, ImageDraw
text = u'ลองตัวอักษรไทย'             # Thai for ‘Thai Alphabet’, maybe?
Epson = printer.Serial(devfile='/dev/ttyUSB2')  # <<< change this !!!
# Used Thai font 'Loma', installed by
#   sudo apt-get install fonts-tlwg-loma
# then
#   cp /usr/share/fonts/truetype/tlwg/Loma.ttf .
# Used 36 pt Loma font
font = ImageFont.truetype('Loma.ttf', 36)
box = font.getsize(text)         # work out size of text
# make an image same width as text, but twice the height
image = Image.new('RGB', (box[0], 2 * box[1]))
draw = ImageDraw.Draw(image)
# draw the text at the left edge of the box
draw.text((0, 0), text, font=font)
image = ImageOps.invert(image)   # invert image to black on white
Epson._convert_image(image)      # output image to printer
Let me know if you have any questions.
Pronouns: he/him
boyzfunhouse
Wed Jun 29, 2016 7:36 pm
This work for me. Thanks a lot, Scruss. :)
Return to “Python”
