bobdx_cool
Exiting from a for and while loop
Sun Oct 26, 2014 11:25 pm
def function1():
totalSteps = 1000
stepsDone = 0
    while (switch == 1 or stepsDone <= totalSteps):
            for x in range(0,4000):
                 GPIO.output(10,GPIO.HIGH)
                 if (switch ==0):
                    break
                 if (stepsDone==totalSteps):
                     break
                 GPIO.output(26,GPIO.HIGH)
                 time.sleep(.0008)
                 GPIO.output(26,GPIO.LOW)
                 time.sleep(.0008)
                 stepsDone=stepsDone+1
    GPIO.output(10,GPIO.LOW)
    stepsDone =0
The problem I am facing is that when the if (stepsDone==totalSteps): becomes true the program breaks out of the for loop, but not out of the while loop. What should I change for it break out of for and while loop and execute GPIO.output(10,GPIO.LOW).
DirkS
Re: Exiting from a for and while loop
Sun Oct 26, 2014 11:41 pm
because of the <= in the while statement it will not exit when the two variables are equal.
If you also want to exit if both are equal then you should use just 'less than' in the while statement:
while (switch == 1 or stepsDone < totalSteps):
Gr.
Dirk.
Sun Oct 26, 2014 11:50 pm
Python's break can only ever break out of the currently active loop (current level of indentation).
What are you trying to achieve with the stepsDone counter? If you run 4000 times round the for loop it will ALWAYS exceed total steps before the for loop is complete.
Also you may want to look at a truth table for the "switch == 1 or stepsDone <= totalSteps" conditions, consider turning that round so you check "switch == 0 AND stepsDone > totalSteps". With multiple conditions it's always a good idea to jot down a truth table to help visualise the logic you're writing (until you become an expert at think this out in your head).
try: except: & finally: exception handling allows you to "raise" an exception up to a higher level.
billio
Tue Oct 28, 2014 12:12 am
Your code is a little obtuse, is this what you meant to happen ?.
Set 10 high, then
Set 26 high and low very quickly for 1000 times or until the switch status is 0, then
Set 10 low
def function1():
    totalSteps = 1000
    stepsDone = 0
    while switch == 1 and stepsDone < totalSteps :
        time.sleep(.0008)
        time.sleep(.0008)
davef21370
Tue Oct 28, 2014 5:57 pm
running=True
while running:
    for i in range(0,4000):
        do something...
        if switch==1:
            running=False
            break
Something like that should work.
Dave.
Apple say... Monkey do !!
paddyg
Wed Oct 29, 2014 9:36 pm
and/or the classic advice is to convert it into different functions which allows you to use 'return' to break out of whatever convoluted nested block you happen to be in.
Return to “Python”
