jviyer
cython install hangs [solved]
Sun Oct 05, 2014 10:24 pm
running install
running build
running build_py
creating build
creating build/lib.linux-armv6l-3.2
copying cython.py -> build/lib.linux-armv6l-3.2
creating build/lib.linux-armv6l-3.2/Cython
copying Cython/CodeWriter.py -> build/lib.linux-armv6l-3.2/Cython
copying Cython/StringIOTree.py -> build/lib.linux-armv6l-3.2/Cython
copying Cython/__init__.py -> build/lib.linux-armv6l-3.2/Cython
copying Cython/Debugging.py -> build/lib.linux-armv6l-3.2/Cython
copying Cython/TestUtils.py -> build/lib.linux-armv6l-3.2/Cython
copying Cython/Utils.py -> build/lib.linux-armv6l-3.2/Cython
copying Cython/Shadow.py -> build/lib.linux-armv6l-3.2/Cython
creating build/lib.linux-armv6l-3.2/Cython/Build
copying Cython/Build/Inline.py -> build/lib.linux-armv6l-3.2/Cython/Build
copying Cython/Build/BuildExecutable.py -> build/lib.linux-armv6l-3.2/Cython/Build
copying Cython/Build/__init__.py -> build/lib.linux-armv6l-3.2/Cython/Build
copying Cython/Build/Dependencies.py -> build/lib.linux-armv6l-3.2/Cython/Build
copying Cython/Build/IpythonMagic.py -> build/lib.linux-armv6l-3.2/Cython/Build
copying Cython/Build/Cythonize.py -> build/lib.linux-armv6l-3.2/Cython/Build
creating build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Future.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Nodes.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/TreeFragment.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/DebugFlags.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Optimize.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/__init__.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Naming.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Visitor.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Annotate.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Buffer.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/FusedNode.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/FlowControl.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Symtab.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/StringEncoding.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Version.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/CodeGeneration.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/MemoryView.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Lexicon.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Parsing.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/PyrexTypes.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/CmdLine.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Main.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Scanning.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Pipeline.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/AnalysedTreeTransforms.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Code.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/ParseTreeTransforms.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Options.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/TypeInference.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Interpreter.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/TypeSlots.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/TreePath.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Builtin.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/AutoDocTransforms.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/CythonScope.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Errors.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/UtilNodes.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/UtilityCode.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/ExprNodes.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/ModuleNode.py -> build/lib.linux-armv6l-3.2/Cython/Compiler
creating build/lib.linux-armv6l-3.2/Cython/Runtime
copying Cython/Runtime/__init__.py -> build/lib.linux-armv6l-3.2/Cython/Runtime
creating build/lib.linux-armv6l-3.2/Cython/Distutils
copying Cython/Distutils/build_ext.py -> build/lib.linux-armv6l-3.2/Cython/Distutils
copying Cython/Distutils/__init__.py -> build/lib.linux-armv6l-3.2/Cython/Distutils
copying Cython/Distutils/extension.py -> build/lib.linux-armv6l-3.2/Cython/Distutils
creating build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Plex/Traditional.py -> build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Plex/DFA.py -> build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Plex/__init__.py -> build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Plex/Machines.py -> build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Plex/Actions.py -> build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Plex/Timing.py -> build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Plex/Transitions.py -> build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Plex/Scanners.py -> build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Plex/Lexicons.py -> build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Plex/Regexps.py -> build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Plex/Errors.py -> build/lib.linux-armv6l-3.2/Cython/Plex
creating build/lib.linux-armv6l-3.2/Cython/Tests
copying Cython/Tests/__init__.py -> build/lib.linux-armv6l-3.2/Cython/Tests
copying Cython/Tests/TestJediTyper.py -> build/lib.linux-armv6l-3.2/Cython/Tests
copying Cython/Tests/TestCodeWriter.py -> build/lib.linux-armv6l-3.2/Cython/Tests
copying Cython/Tests/TestStringIOTree.py -> build/lib.linux-armv6l-3.2/Cython/Tests
copying Cython/Tests/xmlrunner.py -> build/lib.linux-armv6l-3.2/Cython/Tests
creating build/lib.linux-armv6l-3.2/Cython/Build/Tests
copying Cython/Build/Tests/__init__.py -> build/lib.linux-armv6l-3.2/Cython/Build/Tests
copying Cython/Build/Tests/TestStripLiterals.py -> build/lib.linux-armv6l-3.2/Cython/Build/Tests
copying Cython/Build/Tests/TestIpythonMagic.py -> build/lib.linux-armv6l-3.2/Cython/Build/Tests
copying Cython/Build/Tests/TestInline.py -> build/lib.linux-armv6l-3.2/Cython/Build/Tests
creating build/lib.linux-armv6l-3.2/Cython/Compiler/Tests
copying Cython/Compiler/Tests/TestVisitor.py -> build/lib.linux-armv6l-3.2/Cython/Compiler/Tests
copying Cython/Compiler/Tests/TestTreePath.py -> build/lib.linux-armv6l-3.2/Cython/Compiler/Tests
copying Cython/Compiler/Tests/TestBuffer.py -> build/lib.linux-armv6l-3.2/Cython/Compiler/Tests
copying Cython/Compiler/Tests/__init__.py -> build/lib.linux-armv6l-3.2/Cython/Compiler/Tests
copying Cython/Compiler/Tests/TestParseTreeTransforms.py -> build/lib.linux-armv6l-3.2/Cython/Compiler/Tests
copying Cython/Compiler/Tests/TestSignatureMatching.py -> build/lib.linux-armv6l-3.2/Cython/Compiler/Tests
copying Cython/Compiler/Tests/TestTreeFragment.py -> build/lib.linux-armv6l-3.2/Cython/Compiler/Tests
copying Cython/Compiler/Tests/TestUtilityLoad.py -> build/lib.linux-armv6l-3.2/Cython/Compiler/Tests
copying Cython/Compiler/Tests/TestMemView.py -> build/lib.linux-armv6l-3.2/Cython/Compiler/Tests
creating build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/__init__.py -> build/lib.linux-armv6l-3.2/Cython/Utility
creating build/lib.linux-armv6l-3.2/Cython/Tempita
copying Cython/Tempita/__init__.py -> build/lib.linux-armv6l-3.2/Cython/Tempita
copying Cython/Tempita/compat3.py -> build/lib.linux-armv6l-3.2/Cython/Tempita
copying Cython/Tempita/_tempita.py -> build/lib.linux-armv6l-3.2/Cython/Tempita
copying Cython/Tempita/_looper.py -> build/lib.linux-armv6l-3.2/Cython/Tempita
creating build/lib.linux-armv6l-3.2/pyximport
copying pyximport/pyxbuild.py -> build/lib.linux-armv6l-3.2/pyximport
copying pyximport/__init__.py -> build/lib.linux-armv6l-3.2/pyximport
copying pyximport/pyximport.py -> build/lib.linux-armv6l-3.2/pyximport
creating build/lib.linux-armv6l-3.2/Cython/Debugger
copying Cython/Debugger/DebugWriter.py -> build/lib.linux-armv6l-3.2/Cython/Debugger
copying Cython/Debugger/__init__.py -> build/lib.linux-armv6l-3.2/Cython/Debugger
copying Cython/Debugger/libcython.py -> build/lib.linux-armv6l-3.2/Cython/Debugger
copying Cython/Debugger/libpython.py -> build/lib.linux-armv6l-3.2/Cython/Debugger
copying Cython/Debugger/Cygdb.py -> build/lib.linux-armv6l-3.2/Cython/Debugger
creating build/lib.linux-armv6l-3.2/Cython/Debugger/Tests
copying Cython/Debugger/Tests/test_libcython_in_gdb.py -> build/lib.linux-armv6l-3.2/Cython/Debugger/Tests
copying Cython/Debugger/Tests/__init__.py -> build/lib.linux-armv6l-3.2/Cython/Debugger/Tests
copying Cython/Debugger/Tests/TestLibCython.py -> build/lib.linux-armv6l-3.2/Cython/Debugger/Tests
copying Cython/Debugger/Tests/test_libpython_in_gdb.py -> build/lib.linux-armv6l-3.2/Cython/Debugger/Tests
creating build/lib.linux-armv6l-3.2/Cython/Includes
copying Cython/Includes/openmp.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes
creating build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_bool.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_number.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_exc.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_string.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_tuple.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_method.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_list.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_bytes.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_getargs.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_long.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_mem.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_iterator.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_type.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_weakref.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_complex.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_instance.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_ref.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_mapping.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_buffer.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_set.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_unicode.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_pycapsule.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_cobject.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_function.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_float.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_dict.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/stdlib.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_module.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_sequence.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python2.5.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_version.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/stdio.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_int.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_oldbuffer.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/stl.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
copying Cython/Includes/Deprecated/python_object.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/Deprecated
creating build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/__init__.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/stdint.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/float.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/locale.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/limits.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/stddef.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/errno.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/setjmp.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/string.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/signal.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/stdlib.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/stdio.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
copying Cython/Includes/libc/math.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libc
creating build/lib.linux-armv6l-3.2/Cython/Includes/posix
copying Cython/Includes/posix/__init__.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/posix
copying Cython/Includes/posix/fcntl.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/posix
copying Cython/Includes/posix/types.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/posix
copying Cython/Includes/posix/stat.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/posix
copying Cython/Includes/posix/time.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/posix
copying Cython/Includes/posix/ioctl.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/posix
copying Cython/Includes/posix/signal.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/posix
copying Cython/Includes/posix/stdlib.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/posix
copying Cython/Includes/posix/unistd.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/posix
copying Cython/Includes/posix/resource.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/posix
creating build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/__init__.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/sequence.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/set.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/ref.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/mem.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/weakref.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/array.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/long.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/object.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/type.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/float.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/buffer.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/mapping.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/datetime.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/number.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/getargs.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/cobject.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/bytes.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/tuple.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/complex.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/instance.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/unicode.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/exc.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/int.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/method.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/function.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/string.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/version.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/list.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/dict.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/module.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/pycapsule.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/pythread.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/oldbuffer.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/iterator.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/pystate.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
copying Cython/Includes/cpython/bool.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/cpython
creating build/lib.linux-armv6l-3.2/Cython/Includes/numpy
copying Cython/Includes/numpy/__init__.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/numpy
copying Cython/Includes/numpy/math.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/numpy
creating build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/__init__.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/map.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/set.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/utility.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/cast.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/deque.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/algorithm.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/complex.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/queue.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/string.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/pair.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/list.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/vector.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/stack.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/unordered_map.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Includes/libcpp/unordered_set.pxd -> build/lib.linux-armv6l-3.2/Cython/Includes/libcpp
copying Cython/Compiler/Code.pxd -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Scanning.pxd -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Parsing.pxd -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/ParseTreeTransforms.pxd -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/Visitor.pxd -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Compiler/FlowControl.pxd -> build/lib.linux-armv6l-3.2/Cython/Compiler
copying Cython/Runtime/refnanny.pyx -> build/lib.linux-armv6l-3.2/Cython/Runtime
copying Cython/Plex/Scanners.pxd -> build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Plex/Actions.pxd -> build/lib.linux-armv6l-3.2/Cython/Plex
copying Cython/Utility/CppConvert.pyx -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/TestCythonScope.pyx -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/TestCyUtilityLoader.pyx -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/MemoryView.pyx -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/MemoryView_C.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/ImportExport.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/Capsule.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/Exceptions.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/Printing.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/ModuleSetupCode.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/CommonTypes.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/CythonFunction.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/Builtins.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/TestUtilityLoader.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/Buffer.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/FunctionArguments.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/Profile.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/ExtensionTypes.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/Embed.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/Generator.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/Optimize.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/Overflow.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/ObjectHandling.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/TypeConversion.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/StringTools.c -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/arrayarray.h -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Utility/CppSupport.cpp -> build/lib.linux-armv6l-3.2/Cython/Utility
copying Cython/Debugger/Tests/codefile -> build/lib.linux-armv6l-3.2/Cython/Debugger/Tests
copying Cython/Debugger/Tests/cfuncs.c -> build/lib.linux-armv6l-3.2/Cython/Debugger/Tests
Skipping implicit fixer: buffer
Skipping implicit fixer: idioms
Skipping implicit fixer: set_literal
Skipping implicit fixer: ws_comma
and then it hangs !!
Note:I have done "sudo install python3.2-dev" and then did tried the cython setup and it always hangs after it reaches this point. my command is: "sudo python3 setup.py install"
Just fyi: I am using python3 : when I invoke python3 on terminal this is what I see as the interpreter:
(version Python 3.2.3 (default, Mar 1 2013, 11:53:50)
[GCC 4.6.3] on linux2
any help appreciated.
paddyg
Re: cython install hangs
Tue Oct 07, 2014 6:15 pm
not sure I can help much but a) I have installed cython with python2 on a rpi previously and it works and can give serious speed boosts b) I have just installed it with py3.4.1 on newish raspbian (with update/upgrade couple of days ago) but not tested it yet. I used pip to install, something like:
$ sudo apt-get install python3-pip
$ sudo apt-get install python3.2-dev
$ sudo pip-3.2 install cython
c) I did various false attempts such as python3-dev and pip3. d) when it eventually did run ok nothing appeared on the screen for about 40mins after pressing Enter! Sometimes it may be worth reducing graphics memory prior to doing any compiling, and updating etc (though with some SD cards I have used in the past this seemed to render them unbootable!)
aplocher
Sun Jul 30, 2017 10:52 pm
I realize this is an old post but I just wanted to say thanks to @paddyg. I spent days trying to get Cython working on my RPi Zero only to have it lock up (kinda'ish) in weird ways after running for a long time. Never seen a Linux system act this way. Once I read your mention of "adjusting the video memory" I had that "ah ha!" moment and remembered that this particular Zero I had 192mb allocated to video. Lowering it 32mb allowed me to FINALLY install Cython.
Return to “Python”
