I have a project im building and have 2 RPis the 1st RPiI(server) is acting as a AP using Tp-linkwn725n adapter and my 2nd RPi(client) is connected to it using a different adapter.
I plan to run a simple 60 second countdown timer at the 1st RPi and use a push button switch to trigger it to send the countdown timer data to the 2nd RPi hopefully with little delay...
I did some searching and i plan on using this
http://www.codeproject.com/Articles/810 ... t-Protocol
as my concept in making it. would it be possible? or are there better/easier alternatives in sending the data
Thank you to them pro's. really have difficulty in programming >.<
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Re: Send Data from RPi to RPi via WiFi
Look at RabbitMQ or MQTT.
You might make some progress by reading this :
https://docs.python.org/3/howto/sockets.html
which is a basic introduction to network programming in Python.
sorry for the very late reply just had my midterms so uhm... i made progress using RabbitMQ and i successfully installed it.
i'm at loss at coding tho' because i made a simple program that looks like this:
what happens is that i can print the value of 'i' but the pika code im working with i think can only send characters? not the changing value of the 'i' so on my receiving raspberry pi it just receives the character 'i'.. any help? thank you.
import RPi.GPIO as GPIO
import time
import math
import sys
import pika
GPIO.setmode(GPIO.BOARD)
RG = 8
GR = 10
GPIO.setwarnings(False)
GPIO.setup(RG, GPIO.OUT) #L1
GPIO.setup(GR, GPIO.OUT) #L2
i=1;
while i > 0:
RG = GPIO.output(8,1)
GR = GPIO.output(10,0)
print '\nLane 1:[Red] | Lane 2:{Green}'
for i in xrange(20,0,-1):
time.sleep(1)
sys.stdout.write(str(i)+' \n')
connection = pika.BlockingConnection(pika.ConnectionParameters(
host='192.168.42.9'))
channel = connection.channel()
channel.queue_declare(queue='hello')
channel.basic_publish(exchange='',
routing_key='hello',
body='i')
print " [x] Sent"
sys.stdout.flush()
RG = GPIO.output(8,0)
GR = GPIO.output(10,1)
print '\nLane 1 Green Lane 2 Red'
time.sleep(1)
sys.stdout.flush()
i = i+1
It's not clear what you are trying to do.
Is this a classroom exercise? If it's not it might be useful to clarify why you are doing what you are doing.
its like a simple traffic light system...
i have 2 rgb led's connected in parallel the red-green colors
so the program sets the red-green high and the other green-red low and
then it prints the sleep count from 20..
then switches the red-green low and the gree-red led high
then counts down from 20 again...
what im trying to achieve is to send the countdown from 20 to another Rpi connected. i'm able to send through it but not the countdown values. is there a way to go about in sending it? or should i reprogram the countdown?
I'm still not sure about the scope you have for any solution.
However this code allows you to control a slave Pi from a master Pi and write to their gpios.
In this case the same gpio numbers are being used on both Pis. The slave Pi is networked with the name "tom."
The code just alternates gpios on/off for a minute.
#!/usr/bin/env python
# master-client.py
# 2014-10-05
# Public Domain
import time
import pigpio
RED_LED=14
GREEN_LED=15
master = pigpio.pi() # Connect to local Pi (master)
slave = pigpio.pi("tom") # Connect to remote Pi (slave)
start = time.time()
master.set_mode(RED_LED, pigpio.OUTPUT)
master.set_mode(GREEN_LED, pigpio.OUTPUT)
slave.set_mode(RED_LED, pigpio.OUTPUT)
slave.set_mode(GREEN_LED, pigpio.OUTPUT)
off_state = True
while (time.time()-start) < 60:
master.write(RED_LED, off_state)
master.write(GREEN_LED, not off_state)
slave.write(RED_LED, not off_state)
slave.write(GREEN_LED, off_state)
off_state = not off_state
time.sleep(1)
slave.stop() # Disconnect from slave
master.stop() # Disconnect from master
Using Mosquitto and DougieLawson's code, I've just knocked up these pair:
Publisher
Subscriber
Running the sub code in one window and the pub in another results in this:
Sub
Pub
Publisher
$ cat mqtt_pub.py
import mosquitto
import os
import time
import sys
from subprocess import call
from time import sleep
broker = "192.168.0.25"
port = 1883
mypid = os.getpid()
sub_uniq = "subclient_"+str(mypid)
mqtts = mosquitto.Mosquitto(sub_uniq)
mqtts.connect(broker, port, 60)
count = 20
while count > 0:
msg = str(count)
print("Publishing " + msg)
mqtts.publish("test/countdown",msg)
sleep(1)
count = count -1
$ cat mqtt_sub.py
import mosquitto
import os
import time
import sys
def on_message(obj, msg):
print ("Message received on topic: "+msg.topic+" with QoS: "+str(msg.qos)+" and payload: "+msg.payload)
port = 1883
mypid = os.getpid()
mqtts.on_message = on_message
mqtts.subscribe("test/countdown", 0)
rc = 0
while rc == 0:
rc = mqtts.loop()
Sub
Message received on topic: test/countdown with QoS: 0 and payload: 20
Message received on topic: test/countdown with QoS: 0 and payload: 19
Message received on topic: test/countdown with QoS: 0 and payload: 18
Message received on topic: test/countdown with QoS: 0 and payload: 17
Message received on topic: test/countdown with QoS: 0 and payload: 16
Message received on topic: test/countdown with QoS: 0 and payload: 15
Message received on topic: test/countdown with QoS: 0 and payload: 14
Message received on topic: test/countdown with QoS: 0 and payload: 13
Message received on topic: test/countdown with QoS: 0 and payload: 12
Message received on topic: test/countdown with QoS: 0 and payload: 11
Message received on topic: test/countdown with QoS: 0 and payload: 10
Message received on topic: test/countdown with QoS: 0 and payload: 9
Message received on topic: test/countdown with QoS: 0 and payload: 8
Message received on topic: test/countdown with QoS: 0 and payload: 7
Message received on topic: test/countdown with QoS: 0 and payload: 6
Message received on topic: test/countdown with QoS: 0 and payload: 5
Message received on topic: test/countdown with QoS: 0 and payload: 4
Message received on topic: test/countdown with QoS: 0 and payload: 3
Publishing 20
Publishing 19
Publishing 18
Publishing 17
Publishing 16
Publishing 15
Publishing 14
Publishing 13
Publishing 12
Publishing 11
Publishing 10
Publishing 9
Publishing 8
Publishing 7
Publishing 6
Publishing 5
Publishing 4
Publishing 3
Publishing 2
Publishing 1
thanks for the alternative solutions, will try using the mosquitto, it looks good >.<
can i follow this guide in installing mosquitto for your code? http://jpmens.net/2013/09/01/installing ... pberry-pi/
or i should install any specifics?
For the broker, client CLI utils and python support:
Only install the broker on one pi (unless you want to bridge them).
sudo apt-get install mosquitto mosquitto-clients python-mosquitto
