Concie
smtplib.SMPT fails (gmail)
Fri Sep 12, 2014 8:07 am
I try to run a simple script to send me an e-mail, but it fails
Here is the code:
import smtplib
username = '***@gmail.com'
password = '***'
destination = '***@gmail.com'
msg = 'test connection mail'
server = smtplib.SMTP('smtp.gmail.com:587')
server.starttls()
server.login(username,password)
server.sendmail(username, destination, msg)
server.quit()
When I add some test prints, I notice the script hangs at
Already tried changing this to
server = smtplib.SMTP('smtp.gmail.com', 587)
When I press ctrl+C, this is what I get:
  File "testsendmail.py", line 9, in <module>
  File "/usr/lib/python2.7/smtplib.py", line 249, in __init__
    (code, msg) = self.connect(host, port)
  File "/usr/lib/python2.7/smtplib.py", line 310, in connect
    (code, msg) = self.getreply()
  File "/usr/lib/python2.7/smtplib.py", line 354, in getreply
    line = self.file.readline()
  File "/usr/lib/python2.7/socket.py", line 447, in readline
    data = self._sock.recv(self._rbufsize)
When I run this code on my windows machine, there is no problem
Is there someone who can help me with this problem?
theoscy
Re: smtplib.SMPT fails (gmail)
Fri Sep 12, 2014 11:01 pm
Change
to
You could say my love for Linux is terminal ;)
Sat Sep 13, 2014 12:53 am
This code works with python3
import time
from datetime import datetime
import smtplib
from email.mime.text import MIMEText
from email.mime.multipart import MIMEMultipart
f_time = datetime.now().strftime('%a %d %b @ %H:%M')
toaddr = '[email protected]'    # redacted
me = '[email protected]' # redacted
password = 'xxxxxxxx' # redacted
subject = 'Test message ' + f_time
msg = MIMEMultipart()
msg['Subject'] = subject
msg['From'] = me
msg['To'] = toaddr
msg.preamble = "Test message @ " + f_time
message = "Main body text here"
html = "<html><head></head><body><h1>Title</h1><p>Main body text here</body></html>"
plainText = MIMEText(message, 'plain')
htmlText = MIMEText(html,'html')
msg.attach(plainText)
msg.attach(htmlText)
try:
   s = smtplib.SMTP('smtp.gmail.com',587)
   s.starttls()
   s.login(me,password)
   s.send_message(msg)
   s.quit()
except:
   print ("Error: unable to send email")
This is a doctor free zone.
jojopi
Sat Sep 13, 2014 1:28 am
The code is fine. From the backtrace it has connected to gmail but is still waiting to read the connection greeting message. That should not take long.
Do you get the greeting if you telnet to gmail manually?
[email protected] ~ $ telnet smtp.gmail.com 587
Trying 64.233.167.109...
Connected to gmail-smtp-msa.l.google.com.
Escape character is '^]'.
220 mx.google.com ESMTP gj3sm3395027wib.15 - gsmtp
If not, it is an external or network problem, rather than Python.
Concie
Sun Sep 14, 2014 9:59 am
I've decided to completely reinstall my Pi with the latest version of Raspbian.
This seemd to fix the problem for me
Thank you all for your replies
guyc
Wed Mar 18, 2015 9:32 pm
I am having the exact same problem. My code hangs at;
server=smtplib.SMTP('smtp.gmail.com',587)
It will not return unless a do a manual ctrl-c.
I am running Python 3.2.3 on Raspbian GNU/Linux 3.12.28+ OS
I tried to telnet ([email protected] ~ $ telnet smtp.gmail.com 587) and I get the following response;
Trying 74.125.133.109...
It appears the connection has been made but I get no other output.
I have a couple questions;
1) Why does smtplib.SMTP('smtp.gmail.com',587) hang and not timeout regardless if the problem is externally related?
2) How can I avoid a hang condition like this?
3) Has anybody run into this issue and understand the root cause of the hang?
4) Any other suggestions?
Return to “Python”
