fs007
Bug in RPIO.PWM ?
Wed Sep 10, 2014 7:48 pm
the following code does not work as exspected:
#!/usr/bin/python
import subprocess
import time
import RPIO
from RPIO import PWM
PWM.setup()
# .. doing some PWM commands ....
PWM.cleanup()
subprocess.call("ls")
time.sleep(3)
print("abcd")
The script crashes (returns to the shell) without any error message after "ls" is executed (NOT showing "abcd").
If i comment out the lines with PWM... , the script works as expected, showing "abcd" (=running to the end).
I need both PWM and script shall continue to run after subprocess call . How can i make this work ?
texy
Re: Bug in RPIO.PWM ?
Thu Sep 11, 2014 6:21 am
Why is
PWM.cleanup()
where you have put it?
Should it not be at the end of the script?
Texy
fs007
Thu Sep 11, 2014 7:38 am
PWM.cleanup() should be at the end of PWM operations, so it need not be at the end of the script.
But even if you put it there, the problem of script aborting after doing a subprocess call persists. Just try the sample code.
joan
Thu Sep 11, 2014 7:47 am
If I remember rightly it is a bug in RPIO. If I'm right it's something to do with the SIGCHLD signal not been handled.
My pigpio Python module offers similar functionality.
Return to “Python”
