File "thermo.py", line 92, in <module>
print insert_data()
File "thermo.py", line 77, in insert_data
outdoor=read_temp_2()
File "thermo.py", line 65, in read_temp_2
while lines[0].strip()[-3:] != 'YES':
TypeError: 'function' object has no attribute '__getitem__'
this error happens after 8-9 reading and the last photocell readin is much lower than the others (maybe its related with the errro)
import os
import glob
import time
import MySQLdb
import time
import RPi.GPIO as GPIO
DEBUG = 1
GPIO.setmode(GPIO.BCM)
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
base_dir = '/sys/bus/w1/devices/'
device_folder = glob.glob(base_dir + '28-0000060852e6')[0]
device_file = device_folder + '/w1_slave'
device_folder_2 = glob.glob(base_dir +'28-000006455868')[0]
device_file_2 = device_folder_2 + '/w1_slave'
db = MySQLdb.connect("localhost", "x", "x", "mysql")
cursor = db.cursor()
def RCtime (RCpin):
reading = 0
GPIO.setup(RCpin, GPIO.OUT)
GPIO.output(RCpin, GPIO.LOW)
time.sleep(0.1)
GPIO.setup(RCpin, GPIO.IN)
#this takes about 1 millisecond per loop cycle
while (GPIO.input(RCpin) == GPIO.LOW):
reading += 1
return reading
def read_temp_raw():
f = open(device_file, 'r')
lines = f.readlines()
f.close()
return lines
def read_temp_raw_2():
f_2 = open(device_file_2, 'r')
lines_2 = f_2.readlines()
f_2.close()
return lines_2
def read_temp():
lines = read_temp_raw()
time.sleep(0.2)
equals_pos = lines[1].find('t=')
if equals_pos != -1:
temp_string = lines[1][equals_pos+2:]
temp_c = float(temp_string) / 1000.0
return temp_c
def read_temp_2():
lines = read_temp_raw_2()
time.sleep(0.2)
return temp_c
def insert_data():
indor=read_temp()
sun=RCtime(18)
sql = """INSERT INTO temp_outside (temp,tempinside,sun) VALUES (%s, %s, %s)"""
try:
cursor.execute(sql, (indor, outdoor, sun))
db.commit()
except:
time.sleep(10)
db.commit()
return sun
while True:
print insert_data()
time.sleep(10)
