I have listed below the code, where I need to read every 1/10 of a second and display the reading. After approximately 1000 reads, the code crashed with the comment
"IOError: [Errno 24] Too many open files: "
I believe this is something to do with the read() staying open and not closing after each read. I would be appreciative if someone could advise how to correct this issue.
#!/usr/bin/python2.7
from __future__ import division
import spidev
import time
import random
def bitstring(n):
s = bin(n)[2:]
return '0'*(8-len(s)) + s
def read(adc_channel=0, spi_channel=0):
conn = spidev.SpiDev(0, spi_channel)
conn.max_speed_hz = 1200000 # 1.2 MHz
cmd = 128
if adc_channel:
cmd += 32
reply_bytes = conn.xfer2([cmd, 0])
reply_bitstring = ''.join(bitstring(n) for n in reply_bytes)
reply = reply_bitstring[5:15]
return int(reply, 2) / 2**10
WL = 1
while WL > 0:
P1 = read()
print P1
time.sleep(0.11)
P2 = read()
print P2
time.sleep(0.11)
P3 = read()
print P3
time.sleep(0.11)
P4 = read()
print P4
time.sleep(0.11)
P5 = read()
print P5
time.sleep(0.11)
P6 = read()
print P6
time.sleep(0.11)
P7 = read()
print P7
time.sleep(0.11)
P8 = read()
print P8
time.sleep(0.11)
P9 = read()
print P9
time.sleep(0.11)
P10 = read()
print P10
