PIR Sensor + Email
Posted: Thu Aug 21, 2014 5:10 pm
by AmolV
Hello Everyone,
I am doing a project using a PIR sensor and the raspberry pi.
All I want to do is that when the PIR pin goes high i.e when the motion is detected , it should send an email suggesting that the motion is detected .
I have following code for the PIR sensor from raspberry spy http://www.raspberrypi-spy.co.uk/2013/0 ... pi-part-1/
# Import required Python libraries
import RPi.GPIO as GPIO
import time
# Use BCM GPIO references
# instead of physical pin numbers
GPIO.setmode(GPIO.BCM)
# Define GPIO to use on Pi
GPIO_PIR = 7
print "PIR Module Test (CTRL-C to exit)"
# Set pin as input
GPIO.setup(GPIO_PIR,GPIO.IN)      # Echo
Current_State  = 0
Previous_State = 0
try:
  print "Waiting for PIR to settle ..."
  # Loop until PIR output is 0
  while GPIO.input(GPIO_PIR)==1:
    Current_State  = 0
  print "  Ready"
  # Loop until users quits with CTRL-C
  while True :
    # Read PIR state
    Current_State = GPIO.input(GPIO_PIR)
    if Current_State==1 and Previous_State==0:
      # PIR is triggered
      print "  Motion detected!"
      # Record previous state
      Previous_State=1
    elif Current_State==0 and Previous_State==1:
      # PIR has returned to ready state
      print "  Ready"
      Previous_State=0
    # Wait for 10 milliseconds
    time.sleep(0.01)
except KeyboardInterrupt:
  print "  Quit"
  # Reset GPIO settings
  GPIO.cleanup()
And this is the code for sending email using smtp
#!/usr/bin/python
import smtplib
TO = '[email protected]'
SUBJECT = 'PIR'
TEXT = 'Motion is detected'
gmail_sender = '[email protected]'
gmail_passwd = 'mypwd'
server = smtplib.SMTP('smtp.gmail.com', 587)
server.ehlo()
server.starttls()
server.ehlo
server.login(gmail_sender, gmail_passwd)
BODY = '\r\n'.join([
       'TO: %s' % TO,
       'From: %s' % gmail_sender ,
       'Subject: %s' % SUBJECT ,
       TEXT
try:
   server.sendmail(gmail_sender, [TO], BODY)
   print 'email sent'
except:
   print 'error'
server.quit()
Both these programs work perfectly individually.
Now all I need is a little help in integrating these two codes together as all my previous attempts at doing so have failed.
Please help :roll:
Re: PIR Sensor + Email
Posted: Thu Aug 21, 2014 9:46 pm
by bartv
Didn't test it, but i think something like this should work?
import time
import smtplib
#GMAIL mail setup
SUBJECT = 'PIR'
#GMAIL user setup
#GMAIL stuff to login
server.ehlo()
server.starttls()
server.ehlo
#GMAIL Message
       'TO: %s' % TO,
       TEXT
GPIO_PIR = 7
# Set pin as input
Current_State  = 0
Previous_State = 0
try:
    Current_State  = 0
  print "  Ready"
  while True :
    # Read PIR state
      # PIR is triggered
      #Send mail
      Previous_State=1
      print "  Ready"
      Previous_State=0
    time.sleep(0.01)
  print "  Quit"
  GPIO.cleanup()
  server.quit()
Posted: Sat Aug 23, 2014 6:41 am
by AmolV
This was the first thing I tried but it shows invalid syntax for server.send mail :(
Posted: Sat Aug 23, 2014 7:43 am
by joan
AmolV wrote:This was the first thing I tried but it shows invalid syntax for server.send mail :(
You now have a learning opportunity. Study the documentation and use the correct syntax.
Posted: Sat Aug 23, 2014 2:09 pm
by davef21370
I may be missing something but why is TO in square brackets in the server.sendmail function?
Dave.
Posted: Mon Aug 25, 2014 3:06 pm
by AmolV
It worked. All I did was declared the email data after the pir gpio data.
Posted: Tue Apr 21, 2015 7:54 am
by memo-chan
You mean after declaring the pin?
