GUI in Python
Posted: Wed Aug 20, 2014 11:25 am
by dan11
Hi!
I've been working in a project with my RPi. I've created a radio wifi that permits you to select between different countries playlist and you can control it with buttons and see it in a lcd. All is programmed in python and the python script is started when the RPi switches on.
I would like to create a easy gui that allows you to choose in a simple graphical user interface which country playlist you prefer while you can do it with the buttons too. Therefore the only thing that the gui has to do is to choose which function of the python script loads, because when I choose one playlist my programme loads its function and the music starts. My RPi is running Raspbian. I've seen that Tkinter can be a great option.
Please, anyone can help me with any tutorial or example? Because I have no idea how to do it.
Sorry for my English because I'm Spanish.
Thanks.
Re: GUI
Posted: Wed Aug 20, 2014 11:39 am
by AndrewS
Re: GUI
Posted: Wed Aug 20, 2014 11:44 am
by dan11
Thanks. I'll see it. One more question, is possible to do what I want with Tkinter?
Re: GUI
Posted: Wed Aug 20, 2014 11:56 am
by AndrewS
dan11 wrote:One more question, is possible to do what I want with Tkinter?
I can't see any reason why it wouldn't - it's just a generic GUI library used by hundreds of other Python projects...
Re: GUI
Posted: Mon Aug 25, 2014 8:41 pm
by dan11
I need some help please.
Finally I've decided to do it like a pygame. My project uses the script of python of Sheldon:
http://usualpanic.com/2013/05/raspberry ... net-radio/
Now I want to control it at the same time with the lcd or with the gui. I've created a code that shows a photo of the lcd and depending of which button you clik in the photo it will do one thing or another. But I dont know how to do that in the code after of each condition:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# Módulos
import sys, pygame
from pygame.locals import *
from WifiRadioV4 import *
# Constantes
WIDTH = 493
HEIGHT = 300
# Funciones
def load_image(filename, transparent=False):
try: image = pygame.image.load(filename)
except pygame.error, message:
raise SystemExit, message
image = image.convert()
if transparent:
color = image.get_at((0,0))
image.set_colorkey(color, RLEACCEL)
return image
def main():
screen = pygame.display.set_mode((WIDTH, HEIGHT))
pygame.display.set_caption("Raspberry Pi Radio Wifi")
background_image = load_image('fondo.jpg')
while True:
for eventos in pygame.event.get():
if eventos.type == QUIT:
sys.exit(0)
elif eventos.type == pygame.MOUSEBUTTONDOWN:
x, y = eventos.pos
if 283<=x<=307 and 238<=y<=264:
print "Select "
¿Function?
elif 338<=x<=363 and 239<=y<=265:
print "Left"
¿Function?
elif 391<=x<=416 and 223<=y<=247:
print "Up "
¿Function?
elif 392<=x<=418 and 260<=y<=287:
print "Down "
¿Function?
elif 445<=x<=468 and 242<=y<=268:
print "Right"
¿Function?
screen.blit(background_image, (0, 0))
pygame.display.flip()
return 0
if __name__ == '__main__':
pygame.init()
main()
Any help please?
Another issue is that when I run the pygame with the other script running in the RPi is too busy and the lcd shows nothing although I can change the radios and the volume with the buttons but I dont see anything in the lcd.
Re: GUI
Posted: Mon Aug 25, 2014 10:04 pm
by Sleep Mode zZ
dan11 wrote:I need some help please.
Now I want to control it at the same time with the lcd or with the gui. I've created a code that shows a photo of the lcd and depending of which button you clik in the photo it will do one thing or another. But I dont know how to do that in the code after of each condition.
Shouldn't you just put the function calls in the places marked with "¿Function?"? So, write the functionality that you want in function definitions (after the load_image funtion), and then call them from the main loop. The "¿Function?" placeholders shows where to place the calls.
The script will run as fast as it can, taking all cpu resources that the operating system gives it. The program consists of a loop that runs again and again, checking if it gets some input and updating the screen. You have to make it pause for a few milliseconds during every round. The usual way in Python is to use the sleep() function from the module time but pygame has a similar function included that is probaly preferable to use. With pygame.time.Clock() you can create a clock object:
Do that before entering the loop. Then at the very end of the loop, under the line pygame.display.flip(), call the clock objects method tick():
The number is the framerate that you want. Smaller numbers conserve cpu cycles but also increase the latency of input.
Re: GUI
Posted: Tue Aug 26, 2014 7:39 am
by dan11
Thanks for your reply Sleep.
I know where I have to put the calls of the functions what I don't know exactly is what I've to write inside each function to achieve that clicking in the image will be the same that pushing the button on the lcd. Any help please? Because the function used only reads the state of the buttons but I don't know how I can set this state manually.
I will try all later, thanks very much.
Re: GUI
Posted: Tue Aug 26, 2014 10:57 am
by AndrewS
dan11 wrote:Because the function used only reads the state of the buttons but I don't know how I can set this state manually.
You don't "manually set the button state". Instead you need to separate out the code that actually "does something" from your button-press-detecting function, and put that in a separate function. And then in both your "button press" and "mouse click" detection functions, simply call your "action function"...
Re: GUI
Posted: Tue Aug 26, 2014 12:10 pm
by Sleep Mode zZ
dan11 wrote:Thanks for your reply Sleep.
The structure of Sheldon Hartling's program and the structure of the Pygame GUI program are the same, so it should be quite straightforward to combine them into one program.
Both have a main function that first sets up things and then goes into an event loop that reads the user input and does actions accordingly. Hartling's code reads the button press with "press = read_buttons()" and then according to the input it executes an action - e.g. changes the value of a variable and then calls a function. The Pygame GUI reads the mouse coordinates when the mouse is clicked and according to them can change the value of a variable or call a function. Your program's main loop should have both event loops combined into one loop
If you want the same action from a mouse click in the GUI as from a button press, just copy the code from one place to another. If you want new functionality, you have to write new functions that does what you want to do, and then call them from the event loop.
Hartling's code already has an "delay_milliseconds(99)" to slow down the loop in the same way the clock.tick() call does in Pygame. The tick() is better if consistency of the frame rate is important.
Re: GUI
Posted: Wed Aug 27, 2014 8:48 am
by dan11
Thanks for your answers, the gui is working.
The clock object solved the issue and I've attached the gui code into the radio code and now all is running.
Thanks very much.
Re: GUI
Posted: Thu Sep 04, 2014 10:23 am
by dan11
Hi guys! I need some help again.
If I run my program since terminal I dont have any problem all is working perfectly.
But now I want to start automatically my script when I turn on my RPi, I have done it. But when I do it the pygame starts and I see the image of my LCD but RPi is very busy and the mouse moves very slow however if I run it since termial all is ok.
I've followed this tutorial to start my RPi with a script:
http://www.raspberrypi-spanish.es/foro/ ... f=5&t=7338
What can I do?
Re: GUI
Posted: Fri Sep 05, 2014 10:34 am
by BMS Doug
Hi Dan,
I think you will need to post a link to your script before anyone can diagnose the issue for you.
Re: GUI
Posted: Sat Sep 06, 2014 10:56 am
by dan11
I solved the issue. I did this:
• Create the folder home/pi/.config/lxsession/LXDE
• In this folder put a file named autostart containing one line specifying the full path of the file to be executed:
e.g. python /home/pi/pipresents/pipresents.py <options>
• Make the autostart file executable by using the properties menu in the File Manager to alter the permissions on the file.
Re: GUI
Posted: Mon Sep 08, 2014 10:05 am
by dan11
Hi guys! I want to improve my gui.
I would like to show the same messages that are shown in my LCD in my gui.
How I could do it? Any idea?
Re: GUI
Posted: Mon Sep 08, 2014 11:30 am
by Sleep Mode zZ
Here is a small sample program of writing text to the display:
import pygame, sys
WINDOWWIDTH = 620
WINDOWHEIGHT = 480
FONT_SIZE = 50
FONT_COLOR = (255,255,255)
BG_COLOR = (0,0,0)
POSITION = (int(WINDOWWIDTH/2.0), int(WINDOWHEIGHT/2.0))
pygame.init()
screen = pygame.display.set_mode((WINDOWWIDTH, WINDOWHEIGHT))
fontObject = pygame.font.SysFont('dejavusans', FONT_SIZE)
frame_number = 0
while True:
for event in pygame.event.get():
if event.type == pygame.QUIT:
pygame.quit()
sys.exit()
if event.type == pygame.KEYDOWN:
if event.key == pygame.K_ESCAPE:
pygame.quit()
sys.exit()
frame_number = frame_number + 1
textSurfaceObj = fontObject.render(str(frame_number), True, FONT_COLOR)
textRectObj = textSurfaceObj.get_rect()
textRectObj.center = POSITION
pygame.draw.rect(screen, BG_COLOR, textRectObj)
screen.blit(textSurfaceObj, textRectObj)
pygame.display.update([textRectObj])
Re: GUI
Posted: Mon Sep 08, 2014 11:35 am
by dan11
Sleep Mode zZ wrote:Here is a small sample program of writing text to the display:
import pygame, sys
WINDOWWIDTH = 620
WINDOWHEIGHT = 480
FONT_SIZE = 50
BG_COLOR = (0,0,0)
pygame.init()
frame_number = 0
while True:
pygame.quit()
sys.exit()
pygame.quit()
sys.exit()
Thanks.
But is there any way to catch the content of the queue of my python script and then show it or I have to write each part of text manually?
Re: GUI
Posted: Mon Sep 08, 2014 11:54 am
by Sleep Mode zZ
I'm not quite sure what you are asking. You can render any string to a surface and then blit it into the screen. In the example program it is a int typed variable (frame_number) that is changed to a string and then rendered. If you have the content of your queue in strings (or something that can be transformed to strings), you can display it on the pygame screen. For more spesific instructions I would have to see your program and understand what content you want to display on the screen.
Re: GUI
Posted: Mon Sep 08, 2014 11:59 am
by dan11
Here is my code:
# -*- encoding: utf-8 -*-
#!/usr/bin/python
# IMPORTAMOS MÓDULOS
from Adafruit_I2C import Adafruit_I2C
from Adafruit_MCP230xx import Adafruit_MCP230XX
from Adafruit_CharLCDPlate import Adafruit_CharLCDPlate
from datetime import datetime
from subprocess import *
from time import sleep, strftime
from Queue import Queue
from threading import Thread
import os
import glob
import sys, pygame
# CONSTANTES IMAGEN
WIDTH = 493
HEIGHT = 300
# INICIALIZAMOS PLACA LCD
LCD = Adafruit_CharLCDPlate()
# DEFINIMOS VARIABLES GLOBALES
PLAYLIST_MSG = []
STATION = 1
NUM_STATIONS = 0
# BOTONES
NONE = 0x00
SELECT = 0x01
RIGHT = 0x02
DOWN = 0x04
UP = 0x08
LEFT = 0x10
UP_AND_DOWN = 0x0C
LEFT_AND_RIGHT = 0x12
# QUEUE
LCD_QUEUE = Queue()
#FUNCION IMAGEN
if transparent:
return image
# WORKER THREAD
def update_lcd(q):
while True:
msg = q.get()
while not q.empty():
q.task_done()
msg = q.get()
LCD.setCursor(0,0)
LCD.message(msg)
q.task_done()
return
# MAIN
def main():
global STATION, NUM_STATIONS, PLAYLIST_MSG
# Paramos reproductor
output = run_cmd("mpc stop" )
# Configuración AdaFruit LCD Plate
LCD.begin(16,2)
LCD.clear()
LCD.backlight(LCD.ON)
# Creamos el worker thread y lo hacemos una herramienta
worker = Thread(target=update_lcd, args=(LCD_QUEUE,))
worker.setDaemon(True)
worker.start()
# Mensaje inicial
LCD_QUEUE.put('Bienvenido a\nRPi Radio Wifi', True)
# Cargamos la playlist
load_playlist_spain()
sleep(2)
LCD.clear()
clock = pygame.time.Clock()
# INICIAMOS LA MÚSICA
# Iniciamos el reproductor
LCD_QUEUE.put(PLAYLIST_MSG[STATION - 1], True)
run_cmd("mpc volume +100")
mpc_play(STATION)
countdown_to_play = 0
while True:
sys.exit(0)
x, y = eventos.pos
press=SELECT
press = LEFT
press=UP
press=DOWN
press = RIGHT
# Pulsamos botón izquierdo
if(press == LEFT):
STATION -= 1
if(STATION < 1):
STATION = NUM_STATIONS
countdown_to_play = 3
# Pulsamos botón derecho
if(press == RIGHT):
STATION += 1
if(STATION > NUM_STATIONS):
STATION = 1
# Pulsamos botón de arriba
if(press == UP):
output = run_cmd("mpc volume +2")
# Pulsamos botón de abajo
if(press == DOWN):
output = run_cmd("mpc volume -2")
# Pulsamos botón select
if(press == SELECT):
menu_pressed()
if(countdown_to_play > 0):
countdown_to_play -= 1
if(countdown_to_play == 0):
mpc_play(STATION)
clock.tick(3)
update_lcd.join()
return 0
# LECTURA BOTONES PULSADOS
def read_buttons():
buttons = LCD.buttons()
if(buttons != 0):
while(LCD.buttons() != 0):
delay_milliseconds(1)
return buttons
# TIEMPO DE DELAY EN MILISEGUNDOS
def delay_milliseconds(milliseconds):
seconds = milliseconds / float(1000)
sleep(seconds)
# CARGAMOS DIFERENTES PLAYLIST
def load_playlist_spain():
# Añadimos todas las emisoras a la playlist
output = run_cmd("mpc clear")
output = run_cmd("/home/pi/Python-WiFi-Radio/spain.sh")
# Cargamos playlist en PLAYLIST_MSG
PLAYLIST_MSG = []
with open ("/home/pi/Python-WiFi-Radio/spain.sh", "r") as playlist:
# Salta primera línea de la playlist
for line in playlist:
if line[0:1] != '#!':
break
# Carga las siguientes líneas
if line[0] == "#" :
PLAYLIST_MSG.append(line.replace(r'\n','\n')[1:-1] + " ")
playlist.close()
NUM_STATIONS = len(PLAYLIST_MSG)
def load_playlist_france():
output = run_cmd("/home/pi/Python-WiFi-Radio/france.sh")
PLAYLIST_MSG = []
with open ("/home/pi/Python-WiFi-Radio/france.sh", "r") as playlist:
break
if line[0] == "#" :
playlist.close()
def load_playlist_germany():
output = run_cmd("/home/pi/Python-WiFi-Radio/germany.sh")
PLAYLIST_MSG = []
with open ("/home/pi/Python-WiFi-Radio/germany.sh", "r") as playlist:
break
if line[0] == "#" :
playlist.close()
def load_playlist_italy():
output = run_cmd("/home/pi/Python-WiFi-Radio/italy.sh")
PLAYLIST_MSG = []
with open ("/home/pi/Python-WiFi-Radio/italy.sh", "r") as playlist:
break
if line[0] == "#" :
playlist.close()
def load_playlist_united_kingdom():
output = run_cmd("/home/pi/Python-WiFi-Radio/united_kingdom.sh")
PLAYLIST_MSG = []
with open ("/home/pi/Python-WiFi-Radio/united_kingdom.sh", "r") as playlist:
break
if line[0] == "#" :
playlist.close()
# MENÚ DE OPCIONES
def menu_pressed():
global STATION
MENU_LIST = [
'1. Temperatura, \n fecha y hora ',
'2. Seleccionar \n Playlist ',
'3. Silenciar \n audio ',
'4. Temperatura \n Raspberry Pi ',
'5. Reiniciar \n Raspberry Pi ',
'6. Apagar \n Raspberry Pi ',
'7. Salir del \n menu ' ]
item = 0
LCD.clear()
LCD_QUEUE.put(MENU_LIST[item], True)
keep_looping = True
while (keep_looping):
sys.exit(0)
x, y = eventos.pos
press=SELECT
press = LEFT
press=UP
press=DOWN
press = RIGHT
# Arriba
if(press == UP):
item -= 1
if(item < 0):
item = len(MENU_LIST) - 1
# Abajo
elif(press == DOWN):
item += 1
if(item >= len(MENU_LIST)):
item = 0
# Botón select
elif(press == SELECT):
keep_looping = False
if(item == 0):
# 1. Mostrar temperatura,fecha y hora
date_and_time()
elif(item == 1):
# 2. Seleccionar playlist
LCD_QUEUE.put("Seleccione una \nplaylist ", True)
sleep(2)
MENU_LIST = [
'1. France \n ',
'2. Germany \n ',
'3. Italy \n ',
'4. U.Kingdom \n ',
'5. Spain \n ',
'6. Salir menu \n playlist ' ]
cont = 0
LCD.clear()
LCD_QUEUE.put(MENU_LIST[cont], True)
select_country = True
while (select_country):
sys.exit(0)
x, y = eventos.pos
press=SELECT
press = LEFT
press=UP
press=DOWN
press = RIGHT
# Izquierda
if(press == LEFT):
cont -= 1
if(cont < 0):
cont = len(MENU_LIST) - 1
# Derecha
elif(press == RIGHT):
cont += 1
if(cont >= len(MENU_LIST)):
cont = 0
# Select
select_country = False
if(cont == 0):
sleep(2)
STATION = 1
mpc_play(STATION)
elif(cont ==1):
sleep(2)
STATION = 1
mpc_play(STATION)
elif(cont ==2):
sleep(2)
STATION = 1
mpc_play(STATION)
elif(cont ==3):
sleep(2)
STATION = 1
mpc_play(STATION)
elif(cont ==4):
sleep(2)
STATION = 1
mpc_play(STATION)
else:
elif(item == 2):
# 3. Silenciar audio
elif(item == 3):
# 4. Temperatura Raspberry Pi
temp_rpi()
elif(item == 4):
# 5. Reiniciar Raspberry Pi
LCD_QUEUE.put('Reiniciando \nRasbperry Pi ', True)
sleep(2)
LCD_QUEUE.join()
output = run_cmd("sudo shutdown now -r")
LCD.clear()
LCD.backlight(LCD.OFF)
exit(0)
elif(item == 5):
# 6. Apagar Raspberry Pi
LCD_QUEUE.put('Apagando \nRasbperry Pi ', True)
sleep(2)
LCD_QUEUE.join()
output = run_cmd("sudo shutdown now -h")
LCD.clear()
exit(0)
else:
# Restaura la pantalla
# TEMPERATURA,FECHA Y HORA
#Cargamos los comandos modprobe
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
#Encontramos el archivo desde donde leeremos la información
directorio = '/sys/bus/w1/devices/'
carpeta = glob.glob(directorio + '28*')[0]
archivo = carpeta + '/w1_slave'
#Esta función lee la información que obtenemos del sensonr de temperatura
def read_temp_file():
f = open(archivo, 'r')
lines = f.readlines()
f.close()
return lines
#La segunda función se asegura de obtener el mensaje YES de la primera línea
#obtenida del sensor y después devuelve los valores de temperatura leídos en
#grados centígrados
def read_temp():
lines = read_temp_file()
detect = 'YES'
if detect in lines[0]:
position = lines[1].find('t=')
if position != -1:
temp_cad = lines[1][position+2:]
temp_c = float(temp_cad) / 1000.0
return temp_c
else:
def date_and_time():
LCD.clear()
i = 29
keep_looping = True
#Cada medio segundo actualizar tiempo y temperatura mostrados
i += 1
if(i % 5 == 0):
date = datetime.now().strftime("%d %b %Y \nHora: %H:%M")
LCD_QUEUE.put(date, True)
delay_milliseconds(1500)
LCD.clear()
temp = read_temp()
LCD_QUEUE.put("Temperatura: \n"+ str(temp)+" "+ chr(223)+"C", True)
LCD.clear()
#Leemos los botones
sys.exit(0)
x, y = eventos.pos
press=SELECT
# TEMPERATURA RPI
def temp_rpi():
LCD.clear()
tempC = int(open('/sys/class/thermal/thermal_zone0/temp').read()) / 1000
LCD_QUEUE.put("Temperatura RPi:\n"+ str(tempC)+" "+ chr(223)+"C", True)
delay_milliseconds(3000)
LCD.clear()
def run_cmd(cmd):
p = Popen(cmd, shell=True, stdout=PIPE, stderr=STDOUT)
output = p.communicate()[0]
return output
def mpc_play(STATION):
pid = Popen(["/usr/bin/mpc", "play", '%d' % ( STATION )]).pid
main()
pygame.init()
I want to display the content of LCD_QUEUE.put in my gui when is shown in my LCD.
Thanks very much for your reply.
Re: GUI
Posted: Mon Sep 08, 2014 12:28 pm
by Sleep Mode zZ
Unfortunately I'm not familiar with these libraries at all and cannot test the program. On a quick inspection it seems that LCD_QUEUE is a queue where you put items into it with LCD_QUEUE.put and get items with LCD_QUEUE.get. If you want to display what you put into the queue, probably the best thing is to save the item that you are putting into the LCD_QUEUE at the same time into a variable, and then display the variable in the main loop. If you want to display the item when you are getting the item out of the queue, you would have to save it into a variable at that point.
Re: GUI
Posted: Mon Sep 08, 2014 2:17 pm
by dan11
Sleep Mode zZ wrote:Unfortunately I'm not familiar with these libraries at all and cannot test the program. On a quick inspection it seems that LCD_QUEUE is a queue where you put items into it with LCD_QUEUE.put and get items with LCD_QUEUE.get. If you want to display what you put into the queue, probably the best thing is to save the item that you are putting into the LCD_QUEUE at the same time into a variable, and then display the variable in the main loop. If you want to display the item when you are getting the item out of the queue, you would have to save it into a variable at that point.
Thanks, anyone can help me please?
Re: GUI
Posted: Wed Sep 10, 2014 6:21 pm
by AndrewS
I only had a quick scan through the code, but it looks like the update_lcd() function is the one you want to modify? I guess just underneath the LCD.message(msg) you need to add a function which also displays 'msg' on screen?
Re: GUI
Posted: Thu Sep 11, 2014 5:44 pm
by dan11
AndrewS wrote:I only had a quick scan through the code, but it looks like the update_lcd() function is the one you want to modify? I guess just underneath the LCD.message(msg) you need to add a function which also displays 'msg' on screen?
It isn't so easy. Because it is necessary to put the part of the function which displays the msg inside the main and it gets an error.
Any idea?
Re: GUI in Python
Posted: Fri Sep 12, 2014 1:26 pm
by AndrewS
Maybe a quick hacky solution would be to use global variables?
