samuelklit
Python error
Fri Jul 25, 2014 6:04 pm
Hi, iam pretty new to python and i wrote this code:
#!/usr/bin/python
# -*- coding: utf-8-*-
import RPi.GPIO as GPIO
import datetime
import time
GPIO.setwarnings(False)
#Blink
def blink():
   GPIO.output(4, GPIO.HIGH)
   time.sleep(10)
   GPIO.output(4, GPIO.LOW)
   time.sleep(1)
   return
GPIO.setmode(GPIO.BCM)
GPIO.setup(4, GPIO.OUT)
timeh = datetime.datetime.now().hour
timem = datetime.datetime.now().minute
if (timeh == 0 and timem == 00):
        blink()
        print (timeh +":" + timem + ":" + times)
    elif (timeh == 1 and timem == 00):
        blink()
    elif (timeh == 2 and timem == 00):
        blink()
    elif (timeh == 3 and timem == 00):
        blink()
    elif (timeh == 4 and timem == 00):
        blink()
    elif (timeh == 5 and timem == 00):
        blink()
    elif (timeh == 6 and timem == 00):
        blink()
    elif (timeh == 7 and timem == 00):
        blink()
    elif (timeh == 8 and timem == 00):
        blink()
    elif (timeh == 9 and timem == 00):
        blink()
    elif (timeh == 10 and timem == 00):
        blink()
    elif (timeh == 11 and timem == 00):
        blink()
    elif (timeh == 12 and timem == 00):
        blink()
    elif (timeh == 13 and timem == 00):
        blink()
    elif (timeh == 14 and timem == 00):
        blink()
    elif (timeh == 15 and timem == 00):
        blink()
    elif (timeh == 16 and timem == 00):
        blink()
    elif (timeh == 17 and timem == 00):
        blink()
    elif (timeh == 18 and timem == 00):
        blink()
    elif (timeh == 19 and timem == 00):
        blink()
    elif (timeh == 20 and timem == 00):
        blink()
    elif (timeh == 21 and timem == 00):
        blink()
    elif (timeh == 22 and timem == 00):
        blink()
    elif (timeh == 23 and timem == 00):
        blink()
    elif (timeh == 24 and timem == 00):
        blink()
GPIO.cleanup()
#!/usr/bin/python
import datetime
import time
#Blink
def blink():
   time.sleep(10)
   time.sleep(1)
   return
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
GPIO.cleanup()
#!/usr/bin/python
import datetime
import time
#Blink
def blink():
   time.sleep(10)
   time.sleep(1)
   return
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
        blink()
GPIO.cleanup()
But it keep getting errors.....
WHATS WRONG??? :?:
Douglas6
Re: Python error
Fri Jul 25, 2014 6:14 pm
samuelklit wrote:WHATS WRONG??? :?:
That would depend on the errors you are getting. Post them, and someone is more likely to respond with the answer.
samuelklit
Re: Python error
Fri Jul 25, 2014 6:23 pm
The error is
pi@raspberrypi ~ $ sudo python Lystimeblink.py
  File "Lystimeblink.py", line 21
IndentationError: unindent does not match any outer indentation level
PeterO
Re: Python error
Fri Jul 25, 2014 7:02 pm
samuelklit wrote:The error is
You asked "What is wrong?" The error message has told you exactly what is wrong. You need to understand that we are not here to fix problems in your code when the interpreter is telling you exactly what is wrong with your code.
Have you tried using google to find out what the error message means ?
PeterO
Douglas6
Re: Python error
Fri Jul 25, 2014 7:04 pm
Ah. Python is quite strict regarding indentation, it's not just for show. All lines at the same level of 'nesting' must have the same indentation. Typical practice is to use 4 spaces for each level (no tabs). ifs and elifs need to line up (same indentation). So something like:
    blink()
    blink()
PeterO
Re: Python error
Fri Jul 25, 2014 7:13 pm
Douglas6 wrote:Ah. Python is quite strict regarding indentation, it's not just for show.
it is not "quite strict" about it, the indentation and layout is a fundamental part of the language syntax.
PeterO
Douglas6
Re: Python error
Fri Jul 25, 2014 7:23 pm
PeterO
Perhaps simply 'strict' ("inflexibly maintained or adhered to") would have been more proper, if less conversational.
AndrewS
Re: Python error
Tue Jul 29, 2014 12:56 am
And of course because you're doing exactly the same in each of the if/elif branches (and you've covered all 24 hours), you can replace
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
    blink()
with just
if timem == 00:
    blink()
Return to “Python”
