Frquency for GPIO.PWM without flickering
Posted: Mon Jun 23, 2014 2:45 pm
by Jakob Staudinger
Using some transistors, I connected LEDs to 3 GPIOs.
I wanted to dim them using GPIO.PWM, but I get irregular flickering from time to time.
Which frequencies are suitable to avoid flickering?
Re: Frquency for GPIO.PWM without flickering
Posted: Mon Jun 23, 2014 2:52 pm
by joan
Jakob Staudinger wrote:Using some transistors, I connected LEDs to 3 GPIOs.
By GPIO.PWM do you mean the RPi.GPIO Python module?
If that's the case you will always get flickering as it uses software timed PWM.
If you don't want flickering you'll have to buy extra hardware or use one of the Python modules which use hardware timing (RPIO.GPIO or pigpio).
Posted: Mon Jun 23, 2014 3:32 pm
by Gert van Loo
Use C-code.
I tried python for a LED matrix and had the same experience you described: flickering.
Going to C solved all my problems (At least 100x faster) .
Posted: Mon Jun 23, 2014 3:34 pm
by Jakob Staudinger
joan wrote:RPIO.GPIO
Even more flickering.
Gert van Loo wrote:Use C-code.
Please share an example to get started quickly.
Posted: Mon Jun 23, 2014 3:38 pm
by joan
Gert's C code will not be as good as using a Python module which uses hardware timing. It will still flicker for the same reason, it will use software timing.
Posted: Mon Jun 23, 2014 3:39 pm
by Jakob Staudinger
Currently I have
#!/usr/bin/env python
# import RPi.GPIO as GPIO, feedparser, time, sys, random, RPIO.PWM
import feedparser, time, sys, random
from RPIO import PWM
PWM.setup()
PWM.init_channel(0)
while True:
R = random.randrange(0, 255,1)
G = random.randrange(0, 255,1)
B = random.randrange(0, 255,1)
PWM.add_channel_pulse(0, 17, R, 255)
PWM.add_channel_pulse(0, 22, B, 255)
PWM.add_channel_pulse(0, 25, G, 255)
time.sleep(2)
# Shutdown all PWM and DMA activity
PWM.clear_channel_gpio(0, 17)
PWM.clear_channel_gpio(0, 22)
PWM.clear_channel_gpio(0, 25)
PWM.cleanup()
using an RGB-LED.
And it flickers even worse than before.
Posted: Mon Jun 23, 2014 3:59 pm
by Jakob Staudinger
Remove....
Posted: Mon Jun 23, 2014 4:03 pm
by joan
Perhaps you have a separate problem. RPIO should work.
pigpio version.
import time, sys, random
import pigpio
pi = pigpio.pi() # connect to local Pi
start_time = time.time()
while (time.time()-start_time) < 60:
R = random.randrange(0, 255, 1)
G = random.randrange(0, 255, 1)
B = random.randrange(0, 255, 1)
pi.set_PWM_dutycycle(17, R)
pi.set_PWM_dutycycle(22, B)
pi.set_PWM_dutycycle(25, G)
time.sleep(2)
pi.stop()
Video (webm).
http://abyz.co.uk/rpi/misc/jakob.webm
Posted: Mon Jun 23, 2014 4:41 pm
by Jakob Staudinger
Thanks, that finally works.
Posted: Mon Jun 23, 2014 4:46 pm
by joan
I don't understand why RPIO doesn't appear to work. It uses the same technology.
Are you using sound at the same time? The hardware timing is done using DMA paced by the PWM or PCM "peripherals". This usage conflicts with sound modules using the same peripherals at the same time.
