with thanks to information in this thread :
http://www.raspberrypi.org/phpBB3/viewt ... =64&t=4934
I have been able to get a LCD module to display messages using python directly from the GPIO
The code is not very clever, and also not very fast - I,m sure that some of you python experts can improve upon it, but it is clear (to me, at least!), and working !
#!/usr/bin/python
# -*- coding: utf-8 -*-
# gpio_play6.py
# Texy 2012
import RPi.GPIO as GPIO
import time
def main():
GPIO.setmode(GPIO.BCM) # use BCM I/O names
GPIO.setup(24, GPIO.OUT) # E
GPIO.setup(4, GPIO.OUT) # RS
GPIO.setup(18, GPIO.OUT) # DB4
GPIO.setup(21, GPIO.OUT) # DB5
GPIO.setup(22, GPIO.OUT) # DB6
GPIO.setup(23, GPIO.OUT) # DB7
GPIO.setup(17, GPIO.OUT) # LED
lcd_cmd(0x33) # $33 8-bit mode
lcd_cmd(0x32) # $32 8-bit mode
lcd_cmd(0x28) # $28 8-bit mode
lcd_cmd(0x0C) # $0C 8-bit mode
lcd_cmd(0x06) # $06 8-bit mode
lcd_cmd(0x01) # $01 8-bit mode
lcd_string("Hello Pi")
lcd_cmd(0xC0) # next line
lcd_string("Forum peeps!")
def lcd_cmd(bits):
bits=bin(bits)
bits=bits[2:]
zeros=(8-len(bits))*"0"
bits=zeros+bits
GPIO.output(4, False) # RS low
GPIO.output(18, False)
GPIO.output(21, False)
GPIO.output(22, False)
GPIO.output(23, False)
if bits[0]=="1" :
GPIO.output(23, True)
if bits[1]=="1" :
GPIO.output(22, True)
if bits[2]=="1" :
GPIO.output(21, True)
if bits[3]=="1" :
GPIO.output(18, True)
time.sleep(0.01)
GPIO.output(24, True) # E high
time.sleep(0.01)
GPIO.output(24, False) # E low
time.sleep(0.01)
if bits[4]=="1" :
if bits[5]=="1" :
if bits[6]=="1" :
if bits[7]=="1" :
time.sleep(0.01)
time.sleep(0.01)
time.sleep(0.01)
def lcd_string(message):
msg_len = len(message)
for i in range(msg_len):
lcd_char(message[i])
def lcd_char(bits):
bits=bin(ord(bits))
bits=bits[2:]
bits=zeros+bits
GPIO.output(4, True) # RS high
if bits[0]=="1" :
if bits[1]=="1" :
if bits[2]=="1" :
if bits[3]=="1" :
time.sleep(0.01)
time.sleep(0.01)
time.sleep(0.01)
if bits[4]=="1" :
if bits[5]=="1" :
if bits[6]=="1" :
if bits[7]=="1" :
time.sleep(0.01)
time.sleep(0.01)
time.sleep(0.01)
if __name__ == '__main__':
main()
Texy
